Old Jan 13, 2013, 03:56 AM
owlsabie is online now
Find More Posts by owlsabie
owlsabie's Avatar
South Africa
Joined Feb 2009
Julian - she's magnificent!
Owl
owlsabie is online now Find More Posts by owlsabie
Old Jan 13, 2013, 01:22 PM
Ian Easton is offline
Find More Posts by Ian Easton
Ian Easton's Avatar
United Kingdom, Scotland, Fife
Joined May 1999
Excellent Julian - great job. Another beauty in the air. Obviously no shortage of power. Beautiful flying field you have too, much nicer than the desert I have to fly in.
Ian Easton is offline Find More Posts by Ian Easton
Old Jan 13, 2013, 10:37 PM
julianth is offline
Find More Posts by julianth
New Zealand, Waikato, Ngahinapouri
Joined Jan 2011
Definitely no shortage of power, flies at third to half throttle quite happily.
We are very lucky to have an airfield in amongst paddocks with no one to upset with noisy planes!
Just so happens that one of the club members was filming with his quadrocopter, you can see the Falcon landing and taking off. El Presidente was doing a maiden flight on the rather large yellow cub, and showing off his one wheel landings!
Hamilton Model Aero Club - Jan 13th 2013 (3 min 44 sec)
cheers Julian
julianth is offline Find More Posts by julianth
Old Jan 16, 2013, 03:20 AM
julianth is offline
Joined Jan 2011
Added more downthrust to 3 deg , that seems to have cured the climb with throttle.
Flies like a dream now.
Julian
Old Jan 16, 2013, 10:33 PM
Ian Easton's Avatar
Joined May 1999
I think I should add a bit extra downthrust to mine too as mine climbs a lot under throttle.
Old Jan 23, 2013, 11:28 PM
sparks59 is offline
Find More Posts by sparks59
Sic itur ad Astra
sparks59's Avatar
United Arab Emirates, Abu Dhabi, Abu Dhabi
Joined Aug 2009
Like the quad video. Thanks for posting it.
sparks
sparks59 is offline Find More Posts by sparks59
Old Feb 07, 2013, 10:45 PM
Chris Jenkins is offline
Find More Posts by Chris Jenkins
Chris Jenkins's Avatar
United Kingdom, Wales
Joined Feb 2005
More Progress
Still plugging away at the Falcon as time allows between work and other projects. Here are some shots of the progress so far on the fuselarge, and my method of dealing with the cabin area uprights using spruce and balsa. Seems to have worked fine.
Chris Jenkins is offline Find More Posts by Chris Jenkins
Old Feb 08, 2013, 12:10 AM
Ian Easton's Avatar
Joined May 1999
Excellent Chris. Looks like you've got some wire there too ready to do some bending.
Ian
Old Feb 08, 2013, 02:51 PM
ol Timer is offline
Find More Posts by ol Timer
Oxford, UK
Joined Mar 2009
Beautiful craftmanship Chris and improvisation to the cabin.
Have replied to your email.
Ray
ol Timer is offline Find More Posts by ol Timer
Old Feb 09, 2013, 03:13 PM
Tim Trick is offline
Find More Posts by Tim Trick
Tim Trick's Avatar
The Netherlands
Joined Apr 2004
Looking great Chris. I agree that the enhancements to the cabin will be worthwhile - the structure sees a lot of stresses there.
Keep up the good work.
Cheers
Tim
Tim Trick is offline Find More Posts by Tim Trick
Old Feb 09, 2013, 09:28 PM
Joined Feb 2005
Thanks for the replies and nice comments...
Looking forward to making some more progress when work allows
Old Feb 26, 2013, 03:39 PM
BalsaBasher is offline
Find More Posts by BalsaBasher
United Kingdom, England, East Horsley
Joined Dec 2004
The Falcon has flown at last
It weighed in at just over 8 lbs with ASP80 FS up front. Despite having 3 mini servos at the back no ballast was required, I've even got the battery on the COG. It took off without any rudder correction required, but needed a lot of down elevator to prevent excessive climbing. I'm thinking about raising the rear edge of the wing to compensate. No rudder trim was required so side thrust must be spot on. It does reasonably large loops without screwing out. The landings are a bit bouncy though.
Shame about the yellow exhaust extension, but at least there was no oil on the plane after 3 flights. It is certainly not over-powered by an 80 FS
BalsaBasher is offline Find More Posts by BalsaBasher
Old Feb 26, 2013, 07:49 PM
Ian Easton's Avatar
Joined May 1999
Congrats BB, that looks brilliant. Haven't had the chance to get mine back out but it is a climber too. My landings were also very bouncy but I put that down to too high an idel on my engine.
C'mon Chris, youre up next!
Old Feb 27, 2013, 10:28 AM
ol Timer is offline
Oxford, UK
Joined Mar 2009
A beautiful achievement and very pleasing aerial photography. Congratulations.
One question. If the wing bands are one piece, what size are they? The largest I can find are 8 inches and thatís not big enough. So I am using 7-inch bands joined together with a Ĺ-inch split ring.
My model has been ready for some while but because of snow /rain /wind and overcast sky I am waiting for suitable weather to take photographs.
Ray
Old Feb 27, 2013, 10:43 AM
Joined Dec 2004
Thanks for the comments guys.
Ray,
I've used 8-inch bands, I used 4. They are definitely not too short, no damage has been done to the wing. They need stretching first.
Robert
Repost: Keil Kraft Outlaw Plan required. Steve_Bennington Sport Planes 22 Jul 21, 2010 09:26 AM
Looking fo Keil Kraft plans Ian Easton Free Flight 12 Dec 30, 2009 01:57 PM
EP and R/C Keil Kraft Chief? Ragnar Electric Sailplanes 10 Oct 07, 2009 05:36 AM
Keil Kraft Senator Tony Oliver Free Flight 12 Nov 14, 2004 10:40 PM
