Old Dec 30, 2012, 10:35 PM
julianth is offline
Find More Posts by julianth
New Zealand, Waikato, Ngahinapouri
Joined Jan 2011
Bit more progress, covered in superflite 104 (similar to Koverall) and 104 weight pinked tape. Ready to roller on a couple of coats of dacproofer (dyed nitrate).
Then spray coloured butyrate. Looks like we are in for a warm dry spell.
Happy New Year to you all
Cheers
Julian
julianth is offline Find More Posts by julianth
Old Dec 31, 2012, 01:10 PM
Guizzo 17 is offline
Find More Posts by Guizzo 17
Guizzo 17's Avatar
Joined Sep 2007
I'm following with interest your building since the beginning of this thread but..... what's the full size plane in the background?
Guizzo 17 is offline Find More Posts by Guizzo 17
Old Dec 31, 2012, 04:06 PM
Ian Easton is offline
Find More Posts by Ian Easton
Ian Easton's Avatar
United Kingdom, Scotland, Fife
Joined May 1999
Julian, where's your tailwheel?
Ian Easton is offline Find More Posts by Ian Easton
Old Dec 31, 2012, 10:11 PM
julianth is offline
Joined Jan 2011
Hi
The full size plane is a Just Aircraft Escapade, built it a couple of years ago. Similar fabric to the Falcon covering just a bit heavier grade and a two part polyurethane coat.
Hi Ian here is the tailwheel, gets fitted when attaching the tail section to the fuse.
Just put on a couple of coats of nitrate with a roller
Cheers
Julian
Old Jan 01, 2013, 12:02 PM
Guizzo 17's Avatar
Joined Sep 2007
Originally Posted by julianth View Post
Hi
Julian
Gosh! ..And I bet you don't even need R/C gears to fly it!
You guys build big planes!
Old Jan 06, 2013, 01:45 AM
julianth is offline
Joined Jan 2011
Nearly there !
Windscreen and windows to do and a bit of weight up front to balance. Must have put on too much paint!! 34 deg C in the garage today !
Julian
Old Jan 06, 2013, 06:11 AM
Ian Easton's Avatar
Joined May 1999
That looks terrific Julian!
Old Jan 06, 2013, 11:34 AM
cpmcgraw is online now
Find More Posts by cpmcgraw
Experienced Balsa Mangler
United States, AL, Tillmans Corner
Joined Oct 2012
Very pretty, Julian!
cpmcgraw is online now Find More Posts by cpmcgraw
Old Jan 09, 2013, 04:27 AM
julianth is offline
Joined Jan 2011
Thanks, getting closer just setting the C of G at 30% which is slightly further than I would normally go but there are enough previous comments to suggest that this would be ok, anybody know different?
Have added silver strips between the blue and white and am just waiting on some logos, some fine weather and the weekend, maybe Sunday for the maiden flight.
Thank Goodness I don't live in Oz, 50 deg C + WOW!
Feeling a little apprehensive, as have sunk a fair amount of time and effort into this and having departed from the plans with the change in dihedral you never really know what will happen. !!!? but that's half the fun eh? and as somebody previously commented its ok for amusement, I am sure it will be!!
cheers
Julian
Old Jan 09, 2013, 02:24 PM
Ian Easton's Avatar
Joined May 1999
Julian,
You did a terrific job on the paintwork and finishing -I'm envious.
As for being apprehensive, I can relate to that after spending a couple of years putting my Falcon together. It'll be fine though.
Ian
Old Jan 11, 2013, 04:13 AM
julianth is offline
Joined Jan 2011
Tomorrow looking good weather wise, just collected the logos today
Julian
Old Jan 12, 2013, 08:44 PM
julianth is offline
Joined Jan 2011
Well at last, she flies and with a bit more weight up front very well!!
A short video
2013 01 12 The Flight of The Falcon (4 min 5 sec)
Cheers
Julian
Old Jan 12, 2013, 09:04 PM
Joined Oct 2012
Nice work, Julian!
Are you happy with the ailerons at the size you made them? They do appear to handle the turns rather well. Very smooth banking.
Old Jan 12, 2013, 11:43 PM
Teals1 is offline
Find More Posts by Teals1
Teals1's Avatar
New Zealand, Auckland, Papakura
Joined Nov 2006
Very nice Julian. Hope I get to see this model at some point. Lovely finish and nice smooth flying. Allen
Teals1 is offline Find More Posts by Teals1
Old Jan 13, 2013, 02:41 AM
julianth is offline
Joined Jan 2011
Handles very well, ailerons appear to be ok in size.
Had to add a lot of weight up front to get CG to about 27%, but flies beautifully at this, was definitely sensitive further back and flew tail down. Have had to add an elevator down to increase in throttle mix, as she we climb with throttle and I mean vertical!! Of course I assume that it what is was originally designed to do !
not sure whether I need more down thrust or less will try both and see what happens, the wing is at approx 2 deg to the tail
Julian
Repost: Keil Kraft Outlaw Plan required. Steve_Bennington Sport Planes 22 Jul 21, 2010 10:26 AM
Looking fo Keil Kraft plans Ian Easton Free Flight 12 Dec 30, 2009 02:57 PM
EP and R/C Keil Kraft Chief? Ragnar Electric Sailplanes 10 Oct 07, 2009 06:36 AM
Keil Kraft Senator Tony Oliver Free Flight 12 Nov 14, 2004 11:40 PM
