Old Sep 11, 2004, 02:48 AM
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Outrunners would need to be geared anyway - these things presumably swing big props slow.
The spirit of the age would be a sparker. And no radio. Covered in silk, made of split cane...how far do you want to go?
I simply like light slow models and whatever it takes to get them in the air
Old Sep 11, 2004, 09:35 PM
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
Ian, what is the original spark motor specified on the plans? If it was a .60 size then your .52 has many times more horsepower than the original. Also, the original ignition powered model had to carry the extra weight of an ignition coil, battery, cutoff timer, etc. so with R/C gear yours would probably weigh comparably. The .52 would therefore fly the plane with much more authority than the original.
Gerald is offline Find More Posts by Gerald
Old Sep 12, 2004, 07:17 PM
Ian Easton's Avatar
United Kingdom, Scotland, Fife
Joined May 1999
The plans show a "Dennymite" and says "any diesel or petrol engine 10-15cc"
I agree that my 52FS wouldn't have a problem with this one and I think it's the way I'll go. Next choice: Free flight or RC!
Ian Easton is offline Find More Posts by Ian Easton
Old Sep 13, 2004, 03:03 AM
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
build it RC and don't touch the sticks unless it looks like flying away ?
Old Sep 13, 2004, 08:38 AM
Ian Easton's Avatar
Joined May 1999
Vintage,
That's two votes for RC as my wife said the same thing as you.
Old Sep 13, 2004, 04:37 PM
Joined Mar 2004
Freeflight With A Big Slow Revving Sparkie Up Front!!
I Have An Ohlsson 60 And It Runs With The Slowest Sweetest Tickover You Have Ever Heard!!
bolmas is offline Find More Posts by bolmas
Old Sep 13, 2004, 08:39 PM
ὅπερ ἔδει δεῖξαι
Gerald's Avatar
Joined May 2000
Does it look something like this?
What size prop do you use on your Ohlsson?
Old Sep 14, 2004, 02:14 AM
Joined Mar 2004
certainly does, i dont have it in a model but it runs on a 14x6 wooden prop.
Old Sep 14, 2004, 10:59 PM
Ian Easton's Avatar
Joined May 1999
Gerald,
You wouldn't mind if I borrowed that engine would you
It would look really good - I'd even put your name on the side of the cowl as an official sponsor
Old Sep 15, 2004, 03:23 AM
Joined Mar 2004
i wouldnt lend it out, but its for sale. rebuilt using brand new parts, complete with plug and test run on the bench £100
Old Sep 20, 2004, 05:22 PM
grybeard
Belvedere Greater London
Joined Sep 2004
Originally Posted by Ian Easton
Just purchased a set of plans for a Keil Kraft Falcon on e-bay. 8ft span - wow
It should be interesting when they arrive.
Anybody have any photos or comments about the Falcon?
Ian
I bid on that plan, no time to build yet, too many other projects on the go.
The KK Falcon was free flight, I wanted to establish when it was available from KK. I looked at some old KK catalogues (hard to date but Two Shillings and Sixpence) and though they had early digital propo gear they also listed rubber driven escapements and the Super Sixty. The Falcon had already fallen from the list. My recollection was that they were available in the 50s and were free flight.As to power, that depends on what you want to do with the model. The Junior Sixty was definately underpowered with an ED 2cc but a Competition Special was considered just enough. An ED Racer was plenty powerful enough. We flew largely when it was windless, early am or just before dusk, that way it was calm. I would think that a modern .40 Glow would be plenty powerful for a KK Falcon. I know however that modern fliers would want to fit a .60 Glow.
grybeard is offline Find More Posts by grybeard
Old Sep 23, 2004, 08:32 AM
Ian Easton's Avatar
Joined May 1999
I think I have an Aeromodeller from 1947 that shows it - I'll check again though.
Old Aug 31, 2007, 06:43 PM
Joined Aug 2007
Ian
Ian, I have just bought a Falcon on E-bay. I can remember the Falcon indicated on an early keil kraft models list I had when I was about 12 years old. (1959) but it was not available at that time. There was also another large model indicated but I cannot remember its name. it was bigger than the Southerner or Junior 60
The Falcon which is nylon covered and weighs 7lb 7oz without engine or radio fitted. it will probably chug around the sky much the same as the Junior 60 is my guess
mike etheridge is offline Find More Posts by mike etheridge
Old Aug 31, 2007, 08:03 PM
williame3590's Avatar
Canada, ON, Caledonia
Joined Aug 2007
Falcon
I have a OS 60 open rocker in mine with loads of power. The 52 would be just as powerful as the old 60 with even more rpm's. The fuse of the Falcon is kind of neat being round and the stab and main wing just dwarf the fuselage. Excellent flyer and must have a four stroke up front have fun with it....Bill
williame3590 is offline Find More Posts by williame3590
Old Sep 09, 2007, 03:40 AM
Joined Sep 2007
Hi Ian,
Have you built the falcon yet? I used to be the fetcher for the local model shop owner's falcon back in the mid 50s, furthest fetch was about 5 miles out.
In 2003 I retired and a friend built me the ben buckle kit covered with solartex and with a laser 70 four stroke up front. This gives the model a very steep climb and I had to use about 8 degrees of down thrust to sort it.
It flies beautifully and this year is the only year since then that I haven't flown it, reason being I have a Southerner Major that I've re-engined with a saito 62 and I just love that shape.
I also have a junior 60 with an os 26 fs, a Black Magic with another 26, a windy aint it ( a plan built model, shoulder winged) with another 26 that I haven't flown since putting the engine in.
I'll see if I can get a few pictures to upload.
john gibbs is offline Find More Posts by john gibbs
Repost: Keil Kraft Outlaw Plan required. Steve_Bennington Sport Planes 22 Jul 21, 2010 09:26 AM
Looking fo Keil Kraft plans Ian Easton Free Flight 12 Dec 30, 2009 01:57 PM
EP and R/C Keil Kraft Chief? Ragnar Electric Sailplanes 10 Oct 07, 2009 05:36 AM
Keil Kraft Senator Tony Oliver Free Flight 12 Nov 14, 2004 10:40 PM
