Old Jul 15, 2004, 07:13 PM
bobandris is offline
Find More Posts by bobandris
LSF 004 - AMA 5055
bobandris's Avatar
United States, CA, Saratoga
Joined Dec 2000
How to Set Your Headspeed and Blade Pitch Properly
Would like to see Fred Bronk, jaggies, Hoverup, OzzieFlyer, and some of the other more experienced heli flyers address this topic. Basically, it is how do you setup the proper headspeed and blade pitch for achieving hover?
Say you've got a brand new set of blades that are different than any you've used on your particular heli. Maybe the weight, stiffness, chord, span are all a little different. Or maybe you swapped out the motor with a different one.
We all know that for any particular reasonable headspeed you can select a blade pitch that will allow it to hover; but you also may 'bog' the motor down, which is not good for it. How do you actually go about setting these two critical parameters?
Many Thanks,
Bob
bobandris is offline Find More Posts by bobandris
Question How do you set your cp2 pitch links? xmod heli alloy Micro Helis 5 Sep 10, 2006 02:50 PM
Discussion How heavy is your HB - Blade CP2 ? Perulv Micro Helis 11 Mar 30, 2006 02:15 PM
Cool how to set pitch for your zoom 400 Volcano Mini Helis 2 Oct 13, 2004 05:32 AM
How to Set Your Headspeed and Blade Pitch Properly bobandris Micro Helis 9 Jul 16, 2004 12:00 AM
Mini-HowTo How to set/tune your engine Homebrewer Engines 5 Apr 27, 2004 03:05 AM
