Old Jan 22, 2002, 10:55 PM
slowflyer is offline
Find More Posts by slowflyer
Flying slowly along..
Northern Ca.
Joined Dec 2000
How do you cut long straigt lines in foam?
This is one for you hot wire guys... How the heck do you cut the long straight lines when cutting out the panels for your wings? What I'm getting at is when you're cutting your blocks of foam to shape before you actually cut the airfoil, how do you make the long straight line cuts?
I've tried it with a bow, but the wire keeps wanting to wander and I don't get nice clean cuts.
Thanks for your help--Rob
slowflyer is offline Find More Posts by slowflyer
Old Jan 22, 2002, 11:14 PM
Craig Logan is offline
Find More Posts by Craig Logan
Craig Logan's Avatar
Manchester, TN USA
Joined Nov 2001
I use a shelf board with L-shaped metal corner reinforcing brackets (standard hardware store item) screwed in each end. The foam sits weighted-down flat on the board, and the brackets act as templates to guide the hot wire. Sometimes, if my table saw isn't buried in the corner of the shop by too much junk, I'll just blast the foam through it.
Craig Logan is offline Find More Posts by Craig Logan
Old Jan 22, 2002, 11:24 PM
All__talk is offline
Find More Posts by All__talk
Hairy E-Pilot
All__talk's Avatar
Ellensburg, Wa, USA
Joined Dec 2000
Table Saw is great for squaring up the stuff.
Gary
All__talk is offline Find More Posts by All__talk
Old Jan 23, 2002, 05:47 AM
drewjet is offline
Find More Posts by drewjet
drewjet's Avatar
Central Florida
Joined Oct 2001
I use a japanese pull saw makes a nice cut
drewjet is offline Find More Posts by drewjet
Old Jan 23, 2002, 09:04 AM
Flypaper is offline
Find More Posts by Flypaper
kingston Ont, Canada.
Joined Nov 2000
I screw 2 pieces of wood vertical to the front of my workbench with countersunk screwholes almost as wide as my bow. Slide the foam in between and let 'er rip.
Gord
Flypaper is offline Find More Posts by Flypaper
Old Jan 23, 2002, 12:48 PM
Brian Nixon is offline
Find More Posts by Brian Nixon
Brian Nixon's Avatar
Clifton, Va., USA
Joined Sep 2000
Squaring Cuts
I use two carpenter's sliding squares clamped to my workbench to guide the hot wire bow when making the squaring cuts for a set of wing cores.
Brian Nixon is offline Find More Posts by Brian Nixon
Old Jan 23, 2002, 04:46 PM
Manchester, TN USA
Joined Nov 2001
FWIW, Brian's solution with the carpenter's squares is how my setup I posted previously works... just think of my reinforcing brackets as tiny little carpenter's squares... ;-)
Old Jan 23, 2002, 04:56 PM
Avro is offline
Find More Posts by Avro
Pacific Models
Vancouver, BC
Joined Dec 2000
Foam cutting
Hang a piece of foam over the edge of a table with marks on either side of the foam. Then center you bow upside down by wire portion hanging on the foam. Centre the bow and turn the power on. I use a fan control with the dimmer switch running 2 Amp Radio Shack 24Volt transformer. Gravity does its job and it is clean cut every time. By controling amount of cerrent going to the wire you will control speed of the cut. 2" cut aprox. 30 secunds.
PS. Cutting wire -- 0.020 Stainless Steel safety wire or locking wire used on a full size aircraft.
John
Avro is offline Find More Posts by Avro
Old Jan 24, 2002, 03:41 PM
sk8 is offline
sk8
Find More Posts by sk8
sk8
Portland
Joined Dec 2001
Straight line
I make 90deg formica T. Hold this to foam with pins.
Have been using SS fishing leader 18mil for wire.
Dave
sk8 is offline Find More Posts by sk8
Old Jan 24, 2002, 08:48 PM
Northern Ca.
Joined Dec 2000
Boy you guys are great!! I actually used two pieces of l shaped aluminum for a guide and just run the bow along it, this works great now that i have the proper wire. I have also purchased a small band saw, that works great also.
I should have mentioned that I'm using epp foam and am trying to gear up for production runs of a small wing.
Any good info on making up templates quick??
Thanks again all of you---Rob
Old Jan 24, 2002, 08:53 PM
J Morgan is offline
Find More Posts by J Morgan
EB-66C Team Member
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Check out the thread in modeling science forum on templates.
J Morgan is offline Find More Posts by J Morgan
Question How do you cut foam wings? Daniel11 The Builders Workshop 5 May 21, 2014 09:24 PM
How do you cut holes in EPP? TopDog Foamies (Kits) 8 Feb 05, 2010 10:06 PM
Discussion How do you Cut Slots for Spars in Foam? FlyingW The Builders Workshop 9 Nov 21, 2006 01:23 PM
how do you cut or form foam ? Briggs Foamies (Kits) 37 Jan 27, 2005 11:58 AM
How do you cut holes in the horizontal stab? Slow Riser Hand Launch 3 Aug 27, 2002 11:45 PM
