Old Jul 14, 2004, 07:46 PM
MRI is offline
MRI
Find More Posts by MRI
MRI
Engineered RC Products
MRI's Avatar
Joined Jul 2004
Yippee!
Fusion ESC's: A LiPo Ready ESC with Built-In High Voltage BEC
Medusa Research’s Fusion ESC's are Lithium-ready, and are also compatible with NiMH and NiCd cells.
They feature an on-board 2 Amp switching-regulator BEC capable of handling up to 24 volts!
The Fusion line of ESC's provide leading-edge performance for an economical price, while compact designs and rich features make choosing the right unit for your model easy!
A multitude of user-programmable options allow you to easily tailor the ESC to your needs, while true short-circuit and over-temperature protection safeguard your investment.
On sale now!
Find them and other great products at
www.MedusaProducts.com
Medusa Research, Inc.
Engineered Products for the RC Enthusiast
MRI is offline Find More Posts by MRI
Old Dec 24, 2006, 09:40 PM
bcc1955 is offline
Find More Posts by bcc1955
bcc1955's Avatar
San Mateo
Joined Aug 2004
medusa motor question
I am running a Medusa 028-032-4200 with a CC45 speed control. During static testing with a 4.75x4 apc I am having the rpms waver a bit during run up and this occurs way before any volt or current limits are hit. Do you recommend any non-default timing settings. What might be causing this effect?
Also, are you going to make brushless ESCs?
Brian
bcc1955 is offline Find More Posts by bcc1955
Old Dec 25, 2006, 09:00 PM
MRI is offline
MRI
MRI
MRI's Avatar
Joined Jul 2004
Brian
There are a variety of reasons that can cause this issue such as noise getting into the receiver, too long of wires on the ESC, poor solder connections to name a few.
We have seen some issues with older versions of the ESC firmware which produce the exact problem you are describing but using Version1.54 seems to not exhibit the same wavering.
If you do not have V1.54 you should upgrade to that first.
The default or Normal timing should be fine although in some cases improvements can be gained with the Hi timing.
We have brushless ESC's in process but no release date.
Regards,
MRI
Old Dec 26, 2006, 12:28 PM
bcc1955 is offline
bcc1955's Avatar
San Mateo
Joined Aug 2004
I didn't realize it but I was running old firmware. I will test it out soon.
Cheers,
Brian
Fusion ESC's: A LiPo Ready ESC with Built-In High Voltage BEC MRI Product Announcements 0 Jul 02, 2004 04:02 PM
FS- Plantraco DSP4-SC Digital Signal Processing Rx with built in 10A ESC's Etonic Aircraft - Electric - Airplanes (FS/W) 8 Mar 05, 2004 10:15 AM
FS- (2) Plantraco DSP4-SC Digital Signal Processing Rx's with built in 10A ESC's-NIB Etonic Aircraft - Electric - Airplanes (FS/W) 4 Feb 12, 2004 07:15 AM
FS- (2) Plantraco DSP4-SC Digital Signal Processing Rx's with built in 10A ESC's Etonic Aircraft - Electric - Airplanes (FS/W) 3 Jan 18, 2004 08:12 PM
Does anyone make a microRx with a built in ESC/BEC? watersharer Power Systems 6 Aug 05, 2001 08:36 PM
