Old Jul 14, 2004, 03:56 PM
ericm is offline
Find More Posts by ericm
Vancouver WA
Joined May 2004
Piper Cheyenne PSS Project
Okay, so here's another build thread...
Civilian airplane, twin turbine, not a King Air... span will be about 67" with tip tanks (ooo, a hint ).
Fuse will be my first attempt at using the lost foam method. Since I don't trust my "eyeball alignment" carving, I put a ply keel in the center on both vertical and horizontal axis to help with the shaping. Goof number one was buying aircraft ply instead of lite ply by mistake. The aircraft ply is a lot harder to cut out with an x-acto! I cut out the inside of the profiles with a rotozip bit in my drill press. Worked well.
Lots of sanding and shaping to do, will post progress pics as things move along...
ericm
ericm is offline Find More Posts by ericm
Old Jul 14, 2004, 04:32 PM
SchiessCo is offline
Find More Posts by SchiessCo
SchiessCo's Avatar
North Hills
Joined Nov 1999
Looks like a Cheyenne to me - or maybe a Conquest? Do a bit more shaping and post some more pics.
SchiessCo is offline Find More Posts by SchiessCo
Old Jul 14, 2004, 07:03 PM
ericm is offline
Vancouver WA
Joined May 2004
Wow, good ident right off the bat! PA42-1000 to be exact... simpler engine nacelles on that model, plus the full-scale bird is awesome!
What, more shaping? Shucks, I was gonna just glass and go with the Flinstones look Just kidding, lol Will update as I make progress...
ericm
Old Jul 15, 2004, 03:53 AM
sloper dude is offline
Find More Posts by sloper dude
sloper dude
Vancouver, WA
Joined Jul 2004
Man, you just flew the Commander for the first time 2 weeks ago! (got video) The sawdust just rinsed out of your bathtub, the completed Commander finally takes up residence next to Lear 24, and a Cheyenne is already on the production line to join the fastest growing business fleet to hit the slopes. Amazing, keep it up. Breakaway tip tanks? Access hatch? Flaps? Will be cool to see its progress!
Sloperdude
sloper dude is offline Find More Posts by sloper dude
Old Jul 15, 2004, 11:52 AM
ericm is offline
Vancouver WA
Joined May 2004
The Lear is a more of a model 35, definately not a 24. But no biggie... And will deal with the details you asked about when the time comes. Stay tuned...
ericm
Old Jul 15, 2004, 02:07 PM
Jeff Charlot is offline
Find More Posts by Jeff Charlot
Insert custom witicism
Jeff Charlot's Avatar
San Diego
Joined Jun 2001
Looks like a great start Eric. I've yet to do the lost foam method, but am looking at trying it out later this year. This will be a great tutorial to watch. Keep up the good work and post as many pictures as you can!
Jeff
Jeff Charlot is offline Find More Posts by Jeff Charlot
Old Jul 15, 2004, 03:19 PM
ericm is offline
Vancouver WA
Joined May 2004
Tutorial? Haha, maybe "how not to" lol... Will post as much as possible. I will be gone for the weekend, but back into it next week. Wing cores just arrived, so plenty to do now! Lots of carving and shaping (my least favorite) first, gotta get this fuse going.
ericm
Old Jul 15, 2004, 06:31 PM
gorgeflyer is offline
Find More Posts by gorgeflyer
Slope Dog
gorgeflyer's Avatar
The Gorge
Joined Mar 2002
Eric,
You might want to use EPS foam if you are doing lost foam. It really melts out fast with a little acetone or laquer thinner. The inside of the plane will kind of rough though as the epoxy soaks in between the beads of the EPS and you can see individual bead marks once the foam is melted out. We used to do alot of Ninja fuses that way as we kept breaking them in half at East Ridge with just the wooden stock fuse. I'll give you a call later tonight and give you an update on the F 22.
Stubbs
gorgeflyer is offline Find More Posts by gorgeflyer
Old Jul 15, 2004, 08:49 PM
ericm is offline
Vancouver WA
Joined May 2004
Too late! I figured I was using the wrong stuff, but I had it in stock so away we go. I also figured the inside might end up rough, I'm thinking about clear-taping the foam before glassing the fuse. But the inside shouldn't really matter, right?
ericm
Old Aug 09, 2004, 03:47 PM
ericm is offline
Vancouver WA
Joined May 2004
Okay, got back on the Cheyenne project after lollygagging around for too long. Fuselage is ALMOST ready to glass. Seems like it's taken me forever to get this thing shaped... I think I will try taping the plug first as that seemed to work out really well for Brian C.
Got the outboard wing cores and the stab cores sheeted with 1/64 ply, I used West Systems epoxy to bond the sheeting. I much prefer epoxy to contact cement, as it gives the cores a chance to settle into the beds accurately before the glue cures. And even though I've read to scrape off as much epoxy from the skins as possible, I've had some debonds happen due to not enough glue. So I like leaving the skins a bit wet. It may add a whole ounce of extra weight all together, OOOOO, like I care. I'll bet it's not that much.
Will get more cores layed up tonight, also should finish shaping the fuse plug.
ericm
Old Aug 09, 2004, 04:03 PM
Brian Courtice is offline
Find More Posts by Brian Courtice
Free as a bird now.
Brian Courtice's Avatar
United States, FL, Punta Gorda
Joined May 2002
You do some really, really nice work Eric. It looks like you have another show stopper well under way, and I can't wait to see the finished product!
Brian Courtice is offline Find More Posts by Brian Courtice
TFLG is offline
Find More Posts by TFLG
TFLG's Avatar
United States, CA, Riverside
Joined Feb 2002
I've found that leaving too much epoxy can actually be worse since it can trap lots of air bubbles between the core and sheeting. I have found a way to eliminate this (I think). Lately I have been scoring the sheeting and the cores with 40 grit sandpaper before bonding them. This give the air a way to escape and give more teeth for the glue to grab onto. But the last few plywood wings I have sheeted with Gorilla Glue (PU glue). That stuff is da-bomb!
TFLG
TFLG is offline Find More Posts by TFLG
Old Aug 09, 2004, 04:07 PM
ericm is offline
Vancouver WA
Joined May 2004
Hey, great tip! I hadn't thought of the trapped air thing. I've been thinking about trying PU glue...so it works out okay then? I LOVE the stuff for attaching leading edges, also for gluing in lead ballast.
Thanks for the info!
ericm
Old Aug 09, 2004, 04:24 PM
TFLG is offline
TFLG's Avatar
Joined Feb 2002
I've done about 4 wings with it so far and have not had any problems. It's very popular with the large scale aerobatic guys. They've been using it for years. I used it to glue the leading edges onto the P-51 wing I am currently building and it worked good for that too. Normally I would be too impatient to wait 4 hours for the glue to dry but I did it right before I went to bed. It's great glue if you can wait for it to dry.
TFLG
Old Aug 09, 2004, 04:55 PM
Reed is offline
Find More Posts by Reed
Vitruvian JART
Reed's Avatar
San Francisco
Joined Mar 2003
I've got some of that Gorilla Glue but I haven't used on anything yet. Does it sand?
Reed is offline Find More Posts by Reed
Discussion New Scale PSS Project **RFB Fantrainer** the_canuck Slope 82 Jan 22, 2007 05:14 PM
F-16 PSS project noishi Slope 62 Dec 23, 2005 02:19 PM
Scale PSS Project Mr B.... Slope 10 Jun 12, 2003 01:13 AM
