Old Jul 13, 2004, 10:25 PM
Julian537 is offline
Find More Posts by Julian537
Master and Commander
Julian537's Avatar
Bedford, Tx
Joined May 2004
How windy is too windy?
I tried to fly my RV-4 in 10 mph winds and it was all over the place.
AUW is 16 oz.
The wind was blowing it all over the place?
Does it need to be really really calm to fly?
I am used to fuellies I guess?
Julian537 is offline Find More Posts by Julian537
Old Jul 13, 2004, 10:28 PM
brianb10 is offline
Find More Posts by brianb10
brianb10's Avatar
Joined Nov 2003
i dont know what that plane is but wing area is usually a large factor. i usually fly in 5-10 mph winds and it is harder to control but i just try not to bank too hard or it will get blown around more
brianb10 is offline Find More Posts by brianb10
Old Jul 13, 2004, 11:11 PM
temacc is offline
Find More Posts by temacc
H2OFLY
Portland Oregon USA
Joined Feb 2000
Once I got fairly good, I kept flying in more and more wind...up to 25 miles per hour...to give me better skills. This was with a Telemaster and a slimer, 20+ years ago.
With something lighter - and depending on wing area/loading - wind can completely overpower either or both the power (can't get it back to the field) or the control-ability.
Except for dead calm, the more wind the harder it is for me to tell if the model is even trimmed correctly. Only with large (5+ pound) aerobatic models will I do a test flight in anything but calm weather.
It is not the fuel, it is other factors.
Just my opinion. Sometimes I'm right. (Stole that line ;p
Terry
temacc is offline Find More Posts by temacc
Old Jul 14, 2004, 01:32 AM
pfm is offline
pfm
Find More Posts by pfm
pfm
Patrick Mahoney
Fort Collins, CO
Joined Sep 2002
It depends on the plane for me. I occassionally flew my Hangover in winds up to 20mph (as measured by the Wunderground.Com weather station that was less than 1/4 mile away). I've flown my Slow Stick up to about 15mph. The biggest problem with a light model for me is running over to it after it lands to keep the wind from picking it up and cartwheeling it across the field. Removing the landing gear helped with this a bit, but this was always the biggest danger.
My Speedwing 400 was up in winds into the low 20's and barely seemed to notice them. For flying in wind, I prefer a wing with a fast motor.
pfm is offline Find More Posts by pfm
Old Jul 14, 2004, 01:42 AM
yogorilla is offline
Find More Posts by yogorilla
Falling with style
yogorilla's Avatar
Sydney Australia
Joined Dec 2002
I have flown in wind before without problems but last time I tried (at a different flying site) the plane was tossed around a lot, it left me wondering about turbulence as the air moves over the trees and into the clear space where I was flying.
yogorilla is offline Find More Posts by yogorilla
Old Jul 14, 2004, 01:50 AM
Hepdog is offline
Find More Posts by Hepdog
Registered Plan-a-holic
Hepdog's Avatar
Stonewall, MB, Can
Joined Jul 2004
I beleive there is a difference between "windy" and "gusty". Gusty plain out sucks no matter how light the prevailing winds are. Gusts down low like on landing can ruin an otherwise nice flight with very hard landings. I find sunny hot calm days the worst for unexpected gusts. Windy is fine so long as its fairly constant. However, when the wind speed exceeds my forward speed and the plane is going backwards at full throttle, that is generally too windy for me!
As a rule if the plane won't sit on the ground by itself without getting blown away (moving), stay at home and avoid a wreck.
Hepdog is offline Find More Posts by Hepdog
Old Jul 14, 2004, 03:27 AM
m4mm is offline
Find More Posts by m4mm
Dayton, Ohio
Joined Feb 2004
You need to compare amount of wind to weight of model...my experience that models around 12-16 oz weight start losing good & safe flying qualities around 10-12 mph. You can fly at higher winds but you become a Kite or rocket (down wind)...instead of an airplane. Depends on how you want to fly...Kite like or Airplane like. Thats why I fly early AM or late PM when winds are light (5mph). In light winds for a light park flyer you get airplane response and good flying qualities. Mike
m4mm is offline Find More Posts by m4mm
Old Jul 18, 2004, 01:53 AM
Julian537's Avatar
Bedford, Tx
Joined May 2004
thank you guys for all the advice. I will try to fly in calm winds for a while until I get used to it. I fly all the time in 15- 20 mph winds with my glo trainer. it handles very well. But it also weighs about 4 and 1/2 pounds.
Old Jul 18, 2004, 02:08 AM
Tram is offline
Find More Posts by Tram
Fly it like you stole it..
Tram's Avatar
Florence, Al
Joined Oct 2000
Hmm.. how much wind is too much wind? That's a good question.
Tram is offline Find More Posts by Tram
Latest blog entry: Wow.. 3 years..
Old Jul 18, 2004, 04:20 AM
ArcherAce is offline
Find More Posts by ArcherAce
GRAVITY... Just Say NO!
ArcherAce's Avatar
Toledo, OH
Joined Apr 2002
When you put your plane on the ground for take off, and the wind blows it over, it's to windy
ArcherAce is offline Find More Posts by ArcherAce
Old Jul 18, 2004, 07:33 AM
mpj220 is offline
Find More Posts by mpj220
Joined Apr 2001
It's all a balance of weight, power and airframe.
My IFO will fly in windy conditions but, when you pull up, it turns into a kite. My little 24" wing will cut through 30mph winds faily easily.
It's been so windy every weekend up here, you just need to get used to it or not fly at all. Last year was the heat index, this year has been the wind.
Mark
mpj220 is offline Find More Posts by mpj220
Old Jul 18, 2004, 09:46 AM
PerfectStranger is offline
Find More Posts by PerfectStranger
one game away...
PerfectStranger's Avatar
Willoughby, Ohio
Joined Apr 2004
Hey, it's never that windy in my opinion. Read the quote under my username!!! I live in Cleveland. If I waited for a windless or near-windless day, I would NEVER fly.
matt
PerfectStranger is offline Find More Posts by PerfectStranger
Old Jul 18, 2004, 10:18 AM
Foamaholic is offline
Find More Posts by Foamaholic
Electric since 1990
Foamaholic's Avatar
East Central Ohio, United States
Joined Jun 2004
Depends a lot on the type of plane. More important to take off into the wind.
I can fly my foam wing in ANY wind, and it thinks it's calm.
With other planes if you can keep it upwind so it won't blow away then it's okay.
The trickiest part of flying in the wind is landing. Have to come in faster and try to land into the wind.
Foamaholic is offline Find More Posts by Foamaholic
Old Jul 18, 2004, 10:57 AM
Basketcase is offline
Find More Posts by Basketcase
an earth bound misfit, I
Basketcase's Avatar
St. Pete, Florida
Joined Sep 2001
Just be glad you don't live in Wyoming.
pic originally posted by Acer
Basketcase is offline Find More Posts by Basketcase
Old Jul 18, 2004, 11:33 AM
Vindicator! is offline
Find More Posts by Vindicator!
JustGoFly
Vindicator!'s Avatar
Rochester, NY
Joined Sep 2003
Oh man - almost fell of my chair ! Hysterical !
Vinnie
Vindicator! is offline Find More Posts by Vindicator!
How to have fun with your MM Cessna when it's too windy to fly Martin Hunter Parkflyers 14 Aug 12, 2002 06:26 PM
Too Windy in Texas: Need Heavier Trainer kelvin Beginner Training Area (Aircraft-Electric) 22 Mar 15, 2002 09:57 AM
Too windy Frank B Beginner Training Area (Aircraft-Electric) 12 Feb 15, 2002 02:56 PM
You know when it it too windy to fly when... spored Parkflyers 1 Feb 04, 2002 05:29 PM
Too windy to fly?? Crete1 Life, The Universe, and Politics 10 May 23, 2001 09:32 AM
