Old Jan 22, 2002, 04:31 PM
brudford is offline
Find More Posts by brudford
Western PA
Joined Dec 2001
Question
Can I wrap ESC,receiver bubble wrap?
Can I wrap my ESC and Hitech receiver in bubble wrap
to protect them? will it effect reception or performance?
brudford is offline Find More Posts by brudford
Old Jan 22, 2002, 05:45 PM
barn buster 50 is offline
Find More Posts by barn buster 50
tyler, texas, united states
Joined Mar 2001
Good question!
It all depends on the application. If your flying a VERY weight sensitive slowflyer then there would be no need to " un " pad the electronics. if its a larger plane where weight is not a huge concern and flying speeds are alot faster then yes, but you would only want to rap the RX as wrapping the ESC would not let it vent properly. In my big Greaser planes i pad the entire RX and RX battery to pretect from harmonic vibrations caused by the engine.
oh, pading the RX will not harm reception so long as you have your antenna stretched out.
hope this helps
barn buster 50 is offline Find More Posts by barn buster 50
Old Jan 22, 2002, 05:53 PM
Leonard is offline
Find More Posts by Leonard
Leonard's Avatar
Tyler, Texas, United States
Joined May 2001
ESC's can get very hot, so I wouldn't use bubble wrap (it might melt).
Bubble wrap is fine for the RCVR, but on an e-plane, there is little vibration, and just velcro-ing it to a convenient spot is fine.
Leonard
Leonard is offline Find More Posts by Leonard
Old Jan 23, 2002, 09:10 AM
Buran is online now
Find More Posts by Buran
Buran's Avatar
Huntington Beach
Joined Aug 2000
I wrap my receivers in light foam (~1/4 thick), then wrap them in aluminum foil and mount as far away from the motor as possible. Guess how I learned that?
Buran is online now Find More Posts by Buran
Old Jan 23, 2002, 03:52 PM
russ6421 is offline
Find More Posts by russ6421
russ6421's Avatar
ny
Joined Dec 2000
I would have to go with Buran on the foam, Alum Foil optionial. But don't cover the ESC like the man said they can get very warm On my litestiks and small parkflyers I don't bother but the bigger they get the harder they crash.
russ6421 is offline Find More Posts by russ6421
Question Can ESC and Receiver be mounted in close proximity Sctholson Micro Helis 1 May 04, 2007 10:20 PM
Shrink Wrap for Receiver jatt5abdaa 3D Flying 1 Aug 11, 2004 09:54 AM
Can a burned ESC effect the receiver? CptMike Power Systems 1 Aug 08, 2004 06:36 AM
Help Needed: Can I plug-in a receiver battery while using a ESC with a BEC? CheeseWing Parkflyers 3 Sep 26, 2003 07:22 PM
