Old Jul 13, 2004, 07:57 PM
hbielich is offline
Find More Posts by hbielich
Madison, WI
Joined Oct 2003
There are good days and there are...
BAD DAYS!
Went to Fairmont Ridge to slope today. Just seconds after I launched it, the Hoot was going crazy! I could not control it. It would not respond. I have had radio glitches there before, but that was on Ch45. I had switched to another channel, an didn't have any problems the last time I flew there. The Hoot did a spiraling dive and hit hard. The brand new AXI 2820/12 motor is still fine. Battery and radio are ok too. The prop and spinner are toast. The fuse is in very bad shape, although I think repairable. Both wingbolts sheared off, but the front glass dowels have pulled away from the wing. I will have to disect these areas to see what I can do to repair them. Other than a few other minor dings on the wings, they are in surprisingly good shape! However, 2 flap servos (Hitech 81's) are stripped and both aileron servo (D60's) arms are broken and maybe worse.
Fairmont Ridge is off my "Places to Fly" list. Need to find another slope that's not surrounded by such high density population (noise sources).
hbielich is offline Find More Posts by hbielich
Old Jul 13, 2004, 09:37 PM
Andy W is offline
Find More Posts by Andy W
Andy W's Avatar
Marietta, GA
Joined Jun 1999
The fuse is an easy repair.. 15 minutes and it would be good to go. the wing hold-downs - well, look at the recent thread on repairing a Filip Sport wing.
Next time, please reduce your picture size.
..a
Old Jul 13, 2004, 10:33 PM
hbielich is offline
Madison, WI
Joined Oct 2003
Sorry about the images... Hope this is better.
Where would that Filip Sport wing repair thread be?
Old Jul 14, 2004, 04:30 AM
GliderGuideMan is offline
Find More Posts by GliderGuideMan
Kite flying SCRAPS member
GliderGuideMan's Avatar
Hampshire, UK
Joined Apr 2004
Sorry about the Hoot - I know how you feel I did the same thing to my Filip 600 Sport and Omega 1.5e recently (don't ask )
here is the thread on repairing a leading edge dowel dowel repair
here is one on repairing a glass fuz bandit repair
good luck with the repairs
Dave
GliderGuideMan is offline Find More Posts by GliderGuideMan
Old Jul 15, 2004, 06:23 PM
hbielich is offline
Madison, WI
Joined Oct 2003
Now that I am trying to repair the Hoot, I'm beginning to realize that the painful part of crashing a plane isn't the crash itself, but the GD mess of rebuilding the thing. You all make it look so easy in the threads! I have just semi-finished with the first phase of repairing the fuse. What a mess! I stripped everything out of the fuse. Then sanded rough edges on all the cracks inside after tacking the plane together with fast CA. Using a stiff tape I taped some of the major cracks on the outside where there were holes so epoxy wouldn't leak through when aplying to the fiberglass inside. There were so many large cracks that I thought it best to use one large piece of fiberglass cloth to the inside. This was a big mistake. My first problem was after I layed the cloth in the fuse, I mixed 30 minute epoxy with half epoxy and half hardener as per directions. Well let me tell you, it didn't take any 30 minutes to harden! As soon as I mixed the 1oz of epoxy, it started to heat up quickly. I applied it as fast as I could but only got through about 1/3 of the cloth.
Old Jul 15, 2004, 06:33 PM
hbielich is offline
Madison, WI
Joined Oct 2003
By that time I had a block of epoxy sitting in the mixing cup. So I tried again only this time I mixed in equal parts of epoxy, alcohol and hardner. OK this seemed to work better, but since I used one large piece of cloth I got a big buble/wrinkle right in the middle. So as of now, I'm giving up and letting it dry with the wrinkle. I guess I'll try to sand it away when it dries and apply another piece afterward. I started out with latex gloves, but by the time I quite I took them off and had epoxy all over my hands. If I die from the toxins I just hope I get a chance to finish the repair and fly this plane a few times first!
I guess I'm just all thumbs (and all stuck together) when it comes to repair work!
Old Jul 15, 2004, 06:42 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
Lay the glass on a piece of wax paper, and paint it with as little epoxy as it takes to wet it. Press a piece of paper towel onto it to soak up the excess. Then paint the inside of the fuse with epoxy - again, just enough to make it wet, NOT slapping it on so it could run anywhere. Then lay the glass onto the painted area - it will stick well enough right away. Piece of cake, as you commented..
..a
Old Jul 15, 2004, 06:59 PM
hbielich is offline
Madison, WI
Joined Oct 2003
Here's a photo...
Old Jul 15, 2004, 07:01 PM
hbielich is offline
Madison, WI
Joined Oct 2003
I will do that - next time.
hbielich is offline
Madison, WI
Joined Oct 2003
What mix for the epoxy do you use?
Old Jul 15, 2004, 08:16 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
I usually use "finish cure" as it dries to a hard, sandable finish. It's rated 20 minutes.
Your image doesn't make it look all that bad..
..a
Old Jul 15, 2004, 08:19 PM
Andy W is offline
Andy W's Avatar
Marietta, GA
Joined Jun 1999
As an FYI, I reinforced the nose of my Joker - it was not holding up well to spot landings for LMR/F5J.. I glued the cracked pieces with CA, sanded it smooth inside and out, then added 8" x 1" unidirectional carbon mat (looks like 1/8" strips of carbon tow all laid neatly next to each other) to each side of the fuselage (inside) from the nose to the second wing hold-down bolt. I also added a 1"x3" strip of heavy glass underneath and onto the forward wing-mount bolt, to reinforce that section. The entire repair added 8g! .. and I removed more than that by taking off the decals!
..a
Old Jul 15, 2004, 08:34 PM
soholingo is offline
Find More Posts by soholingo
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
man you sound like me and my first repairs. A few things you will learn the hard way (as I have) is leave the modeling store epoxy alone. Go to the boat store and buy the marine epoxies like west systems, MAS, MGS... Next, if you have to use the modeling epoxy 3 hour is your friend for these sort of repairs. Also after you mix the epoxy, pour it in a plate so that it doesn't heat up and exotherm so fast. This is less of a problem with the marine epoxies. Don't mix alcohol and epoxy as it WILL weaken the finished product. Use the higher grade epoxies and you won't need to thin them as they are fairly viscous and aare the consistancy of thin dish soap. I hope this helps...
j
soholingo is offline Find More Posts by soholingo
Old Jul 15, 2004, 08:43 PM
down_shift is offline
Find More Posts by down_shift
down_shift's Avatar
United States, VA, Leesburg
Joined Feb 2003
Ready to take the plung myself!
down_shift is offline Find More Posts by down_shift
Old Jul 15, 2004, 08:46 PM
BANNED!!!
soholingo's Avatar
Laurel, MD
Joined May 2001
Russ, post your repairs in composite fabrication. You will get topical coments from there...
Are there any good lipo sales? taekwondo Batteries and Chargers 23 Aug 06, 2005 02:54 PM
NF stock tire, are there any good? tom4 Motorcycles 1 Jan 18, 2005 09:59 AM
Are there any good places to fly in the Vancouver, WA area? ManWithNoName Electric Plane Talk 1 May 17, 2004 07:11 PM
are there any good EDF parkflyers? jstevens Electric Ducted Fan Jet Talk 8 Apr 29, 2004 12:33 AM
are there any good brushed 3d planes out there? flying4fun 3D Flying 18 Mar 29, 2004 06:53 PM
