Blythewood, SC USA
Joined Mar 2000
Sure, here are some pictures that may make it a little clearer. The nuts are actually couplers for threaded rod. I felt that they would provide more bite at only a minimal weight gain. Not pictured in the pictures are the, yet to be installed, lock washers.
That's how I thought it was.
I don't see anything to keep the rods from moving rearward in the firewall. Looking at the front, the rods appear to go through a drilled hole in the firewall with the nuts on the back side of the firewall. Another possible issue is the 8 screws on the front that go into the drive. With them being in just plywood I would keep a close check on them. Bill |
You need to take them out and put them on the front side, or use flanged nuts on the front and back side of the firewall. The latter is what I would do. The flanged nut would spead the load out some on the ply which would be better. I'll bet you had some fun threading those rods through all the T nuts. Bill |
Blythewood, SC USA
Joined Mar 2000
Yup Bill, you're absolutely right. Duh! What was I thinking. They started to pull back last night as I was adjusting the thrust line. I'm going to do just as you suggest, and while I'm at it, also fiberglass the front motor mount.
And boy howdy do my fingers hurt from all of that threading. The nice thing about this system is its adjustability, but crap is it a pain in the rear end to get those 8" rods from the front ALL OF THE WAY TO THE BACK. A slight misalignment of the plates and they are *tight*. Fortunately, I only have that problem on one corner. Me thinks version 2 is around the corner. |
Claremont, SD, USA
Joined Sep 2001
First let me say I don't know much about these things, I'm just a farmer, and maybe it's stronger than it looks, but there will be a lot of torque and gyroscopic forces acting on the mount during aerobatics so will it be able to resist them? I would think it would be a lot stronger if you tied the back ply mount to the fire with a ply box, or at least some diagonal braces.
I need to build a couple mounts for some bigger planes I'm building, though not this big, so if your mounts work out good I may borrow the design if it's ok with you. Of course if your plane crashes because the motor comes off??? I may have to keep an eye on this thread! ![]() James |
Blythewood, SC USA
Joined Mar 2000
Yes, the cowl clears just fine.... I had the foresight to build the front mount based on the cowl. At least, the second time I did.. <grin>
I've since added flanged nuts to the firewall as well as a top and bottom plywood plate which has stiffened it even more. I've had a helper hold the front of the fuselage while I've tried to move the mount and I've been unsuccessful. I can't imagine needing anymore than this. I'll snap some more pics once I get home this evening. |
As for the gyroscopic forces, the plywood will probably fail before the threaded rod(s) could buckle under compression. I worry more about the small dia aluminum attachment point behind the gear drive breaking on the C50. Quote:
Make sure you have plenty of air flowing to the motor, ESC, and batteries. Bill |
Yes the motor.
look just behind the gear drive, you should see a small gap between the motor front plate and where the drive screws back to. Now look at how small the base is. Think about where all the gyroscopic torque will end up applying load with the rear of the motor held secure.. All the load not taken up by the front motor mount plate is transfered to this point. it's something to think about IMO. I wouldn't worry too much though because there are lots of 3D applications out there with the motor mounted this way without any reported failures. Bill |
| Thread Tools | |
| Ho strong should a motor mount for an AXI 4120/18 be? | steve crewdog | Power Systems | 2 | Jul 24, 2005 08:38 PM |
| How Do I Remove the Tail Motor Mount From the End of the Boom? | wannabe | Micro Helis | 2 | Nov 12, 2003 06:17 PM |
| ? motor mount How to make?? | big-john-48 | Sport Planes | 2 | Dec 05, 2001 08:18 AM |
| How do I fix a broken motor mount on my E-Boomerang? | dano | Foamies (Kits) | 5 | Jun 26, 2001 09:43 PM |
| T-52 Motor Mount #3, Easy and strong. | hoppy | Foamies (Kits) | 2 | Jun 26, 2001 04:15 PM |
