Old Jul 12, 2004, 01:19 AM
Vince003 is offline
Find More Posts by Vince003
toronto.on.ca
Joined Jun 2004
Scratch built boat not criusing smooth.
Hi,
I've finally finished a boat that I started about 12 years ago, it runs faster than I thought it would but it could be better.
the boat pitches in a oscillation at full speed. I've tried adjusting the thrust angle down and also the CG and it didn't work. I was thinking of glueing some runners or rails I'm not sure what they're called but they're usually parallel with the keel which redirects water down. What do you think?
BTW here's my boat:
Vince003 is offline Find More Posts by Vince003
Old Jul 12, 2004, 01:53 AM
reaper is offline
Find More Posts by reaper
reaper's Avatar
Joined Feb 2004
Nice work!!,neat paint!,Is the hull porposing while running??,how deep is the lower leg of the outbord sitting in the water??,its hard to tell(there is no transom pic)by having the lower leg to low or too high can result in loose running.Adding strakes to the hull may help,adding trim tabs may help the situation but Its a tough call due to it is an outboard..It should plane out well with a properly adjusted outboard.I would mainly check the outboard depth first & then go from there...Cheers!.
reaper is offline Find More Posts by reaper
Old Jul 12, 2004, 09:13 AM
pacro is offline
Find More Posts by pacro
TOPDOG
Taiwan
Joined Oct 2003
where did the outboad come from
pacro is offline Find More Posts by pacro
Old Jul 12, 2004, 08:37 PM
Vince003 is offline
toronto.on.ca
Joined Jun 2004
Thanks and yes it's porposing.I just did a search on that and got some info to try to solve the problem.
Old Jul 12, 2004, 08:39 PM
Vince003 is offline
toronto.on.ca
Joined Jun 2004
I got the outboard 10 or more years ago new in a box.
Old Jul 12, 2004, 10:14 PM
pacro is offline
TOPDOG
Taiwan
Joined Oct 2003
what company
Old Jul 12, 2004, 11:21 PM
Vince003 is offline
toronto.on.ca
Joined Jun 2004
Kyosho
Old Jul 13, 2004, 09:45 AM
MeBluEyz99 is offline
Find More Posts by MeBluEyz99
Full Throttle and No Regrets!
MeBluEyz99's Avatar
Denville, New Jersey
Joined Jun 2004
Nice work looks small though and maybe thats why it reacts to the water the way it does maybe a little more weight in the center of the boat will keep it steady I once did that to one of my einstein projects and it did the trick but it didnt have an outboard. It was to light for the speed it was going and it would swing everywhere once it got a little air...
MeBluEyz99 is offline Find More Posts by MeBluEyz99
Old Jul 13, 2004, 03:00 PM
Swashmix is offline
Find More Posts by Swashmix
Dundas, Ontario, Canada
Joined May 2004
Vince,
Neat looking job! Are you running that boat up in cottage country??
We are about 20 minutes north of Parry Sound. Will be trying the Villian EX in August up on the lake.
Swashmix is offline Find More Posts by Swashmix
Old Jul 13, 2004, 09:01 PM
Vince003 is offline
toronto.on.ca
Joined Jun 2004
Thanks. We rented a cottage near Severn Falls in early June. thats where the pictures was taken, it was also the first time it touched water.
Old Jul 16, 2004, 01:58 PM
tsunami is offline
Find More Posts by tsunami
tsunami's Avatar
United States, CA, Victorville
Joined Apr 2004
try moving to out bord farther from the transom(standoff bracket) this is generally accepted in full scale out boards
tsunami is offline Find More Posts by tsunami
Build Log scratch built torpedo sterned lobster boat BG-boats06 Scale Boats 40 Aug 09, 2009 04:30 PM
Gallery 1920's scratch built lobster boat BG-boats06 Scale Boats 4 Apr 10, 2007 09:25 PM
Discussion First scratch built boat SDJ Scale Boats 7 Feb 04, 2007 11:18 AM
Discussion Amazing Scratch Built Electric!!...30Lb. China Clipper Flying Boat Splummer Scale Kit/Scratch Built 16 Nov 14, 2006 05:44 PM
scratch built ,not sure what to call it Marcuswhorley Foamies (Kits) 10 Dec 12, 2003 09:54 PM
