Old Jun 10, 2001, 06:01 AM
watts goin on is offline
Find More Posts by watts goin on
Melbourne, Victoria, Australia
Joined Jun 2001
Twin Speed 600 set up
I recently tried running two standard speed 600 can type motors (8.4v) each with it's own 2000mah battery pack and speed controller. The speed controllers were then connected through a Y lead to the reciever.
At full throttle, the 2 produced 156 watts each, but when I tried to transition from full throtle to idle, only one motor reponded proportionally to throttle movement, the other went to an idle speed. As I bought the throttle up again, one motor adavnced whilst the other remined at idle, until I reached full throttle, when they both delivered full power again.
The interesting part was, when I took one of the battery packs off, but left the whattmeter connected to the motor, I found it was actually showing half the voltage from the other pack, but no amps!
This arrangement should work and should give me fully proportional throttle control on both engines. I have seen the same set up in the Koyosho Learjet and on a balsacraft Blenheim.
Can any one help please? This is leaving me very frustrated.
watts goin on is offline Find More Posts by watts goin on
Old Jun 10, 2001, 02:14 PM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
If both controllers have BEC that can cause some strange results since they are both trying to feed 5V to the Rx. That cross coupling could do almost anything. Disconnect the red wire from one controller and see if that works any better.
Steve
steve lewin is offline Find More Posts by steve lewin
speed control set up twinsticks Micro Helis 2 Jul 18, 2004 10:40 AM
Advice Sought on Rigging Up A Twin Brushless Motor Set-Up for CL-415 ClipperBill Power Systems 0 Jul 10, 2004 07:20 PM
Speed 400 set-up for Omega 1.8 mlavell1 Electric Sailplanes 6 Dec 10, 2003 02:30 PM
Ace Simple Speed 400 Set-up Questions... Chris Rust High Performance 4 Jun 01, 2001 12:11 AM
