Old Jul 10, 2004, 02:28 AM
Bernoulli~Bros is offline
Find More Posts by Bernoulli~Bros
Gettin' Lifted
Bernoulli~Bros's Avatar
Hole In The Earth, CA
Joined Feb 2004
Overlord Build Thread - My first wing.
Well, I have searched and searched, cannot find any good extensive threads on the Overlord, reputably a good beginners wing.
So I guess I will try to document this build, w/ photos, the best I can.
I ordered the Overlord on Thursday, havent received any shipping notification ( nor can I find anything on edgeRC on shipping methods?) , but this gives me some time to re-supply for a new build
Directly from the site, the items I need are:
1. Glue-epoxy, shoe goo, goop or welder, or polyurethane glue
2. Fiberglass reinforced strapping tape (1 inch)
3. 3M Super 77 spray adhesive or equivalent
4. Covering material of your choice (econocote, ultracote, colored packaging tape, etc.)
5. Radio system with elevon/V-tail mixing, receiver,
6. HS-81 servos or equivalent
7. Motor-(speed 400 min.), props (Gunther or zagi)
8. Speed control-15amp min.
9. Batteries-8 cell AA or 8-10 cell 2/3 A or 8 cell 4/5 A
10. Basic hobby tools (exacto knife, small screwdrivers, etc.)
Bernoulli~Bros is offline Find More Posts by Bernoulli~Bros
Old Jul 10, 2004, 03:08 AM
Gettin' Lifted
Joined Feb 2004
#1 How about 4 minute epoxy??(w/ some microballoons maybe??) I am becomming really efficient with the stuff, but have never worked with EPP. shoo goo where do I find this, Wal Mart? shoe store?
#2 Strapping tape, got that
#3 Dont have any, but have used it before, Wal-mart right??
#4 I think its gonna have to be colored packing tape for me, will save my first real covering experience for my first MM balsa build sometime soon.
#5 Hitech Laser 4, Has a couple/few mixing settings, including v-tail, I know I know,
not great, I keep saying I am going to upgrade, but one thing at a time I guess eh?
#6 How about all-e-rc's micro 18's ?? suggestions here?
#7 zagi reverse timed and balanced 400---will I be running the motor leads in reverse for a pusher, like my GWS planes w/ gearbox's?? (seems like a dumb question I know)
#8 Wattage IC380 30a cont. 40a burst.
#9 8s CBP 1050's 2/3 A
#10 Yep yep...
Old Jul 10, 2004, 03:09 AM
Gettin' Lifted
Joined Feb 2004
Thats all for right now, any suggestions are very welcome!
Jay
Old Jul 10, 2004, 07:46 AM
Launchpad is offline
Find More Posts by Launchpad
Launchpad's Avatar
Athens, GA
Joined Jul 2003
#3 Yes walmart, and don't buy the cheap stuff, get the 3M. The other stuff fries the foam.
I just ordered an overlord on wednesday, so I will be following along with you.
Launchpad is offline Find More Posts by Launchpad
Old Jul 10, 2004, 10:13 AM
ScYcS is offline
Find More Posts by ScYcS
Just fly the darn wing!!!
ScYcS's Avatar
Germany, NRW, Herford
Joined Oct 2003
#10 Yep yep...
Ad #1: Yes, Wal-MArt in the shoe department
Ad #2: you got it
Ad #3: already answered
Ad #4: packing tape can be found for nice pricetag at www.fastpack.com in various colors.
Ad #5: Laser 4 is a solid, good radio. No need for more for the Overlord
Ad #6: Micro-18 servos are OK to use i would think. Allerc.com sells quality stuff and he knows what he's doing. I personally stick with Hitec servos or Bluebird/Waypoint servos.
Ad #7: If you buy the original Zagi Pusher motor from Zagi, it'll come with instructions. For every other motor that is not specifically mentioned as reverse timed, put the "black" cable on the "red" dot on the motor.
Ad #8: I don't like the Wattage ESCs personally. I had a very bad experience with them in the past and won't use them anymore. If you need a good ESC, get the pixie 20 from castle creations. Other than that, the Electrifly ESCs or Jeti are good choices.
Ad #9: best choice. With a 48" wing, you can even go with bigger packs like the CBP 1400 AA cells.
Ad #10: ...
ScYcS is offline Find More Posts by ScYcS
Old Jul 16, 2004, 07:43 PM
Gettin' Lifted
Joined Feb 2004
It has arrived!!!
As usual I wasted no time getting started....
Wing halves glued together w/ shoo goo in the center, and 5 minute epoxy around the gaps/edge's.
A mistake was made, and my kit was shipped without the spar slot pre-cut But thanks to the help of Justins wife(Justin is out of town), and a member here , I got the correct measurments and cut the slot myself, beings this is my first time working with EPP, turned into kind of a butcher job, but it worked out ok, I think(does it look about right?) .
I hope I can do better cutting this stuff when I cut out my servo bays any suggestions for clean cutting EPP without a dremel??
Jay
Old Jul 16, 2004, 08:09 PM
ScYcS is offline
ScYcS's Avatar
Joined Oct 2003
Look good to me.....couldn't have done a better job with the spar.
EPP cutting can be done with either a soldering iron (melting away the foam; kinda tricky and nothing for your first build) or by outlining the shape with a sharpie, then cutting around the line with a BRAND NEW razor blade, then cutting inside the shape to make relatively small cubes (a chessboard pattern) and then simply pry the pieces out with a needle nose plier.
Old Jul 16, 2004, 09:31 PM
Gettin' Lifted
Joined Feb 2004
ooooh I like that idea..
The spar looks crooked in the picture, but that is an optical illusion(I went back out to the garage and checked like 4 times after seeing the picture ), the wing is also tilted slightly in the picture.
Will update again in a couple hours, after work.
Jay
Old Jul 17, 2004, 03:42 AM
Gettin' Lifted
Joined Feb 2004
Well, made some progress..
COULD have done more, but ran out of strapping tape about 5 beers into it Doh! I knew I should have bought a fresh roll before starting this project.
I still havent picked up the servo's for her yet, so I cant do much on the top now, and still have a few 'X' s to do on the bottom, once I pick up more strapping tape tommow.
Only question I can think is to ask; how much tape is too much?? what are the weight issue's with this plane, I would like to go all out with the strapping tape, for extreme durability, but fear the weight..any advice here??
Thanks for the interest and replies,
Jay
Old Jul 17, 2004, 09:17 AM
ScYcS is offline
ScYcS's Avatar
Joined Oct 2003
strapping tape can weight a lot. I would not do more than the instructions for the wing say to use. EPP is really durable and will last a long time.
Old Jul 17, 2004, 07:01 PM
L Jenkins is offline
Find More Posts by L Jenkins
United States, FL, Inverness
Joined Jan 2001
Jay,
I can't tell from your pictures, but did you spray 3M77 on the wings before adding the strapping tape?
Lew
L Jenkins is offline Find More Posts by L Jenkins
Old Jul 17, 2004, 11:28 PM
Gettin' Lifted
Joined Feb 2004
Ok thanks, will do.
Originally Posted by L Jenkins
Jay,
Lew
Yup, sprayed, then waited about 5 minutes before applying tape.
Thanks guys.
Will update later tonight,
Jay
Old Jul 18, 2004, 03:52 AM
Gettin' Lifted
Joined Feb 2004
Well, got a little bit more done, finished the strapping on the bottom, and started some covering w/tape.
Weekends are very busy for me, so I havent had a chance to do much.
Jay
Old Jul 18, 2004, 10:15 AM
ScYcS is offline
ScYcS's Avatar
Joined Oct 2003
I like the colors. Looks great.
Old Jul 18, 2004, 01:20 PM
Scoobyvroom is offline
Find More Posts by Scoobyvroom
Jack of all trades!
Scoobyvroom's Avatar
Rockford, MN
Joined Jul 2003
Did you find this one??
http://www.rcgroups.com/forums/showthread.php?t=233665
Just wondering granted it's not very detailed, but it gives you a pretty good idea. Also notice how I installed the battery just velcro, then when you want the battery out just use a credit card and slip it between the male and female velcro and vwala...
Chris
Scoobyvroom is offline Find More Posts by Scoobyvroom
Yippee! Build This! ( My First Forward swept wing) cytochrom Flying Wings 34 Nov 30, 2007 06:22 PM
Yippee! Sharing pics of my first wing,(Overlord) nakman8 Flying Wings 3 Apr 15, 2006 02:00 AM
Trying to build my first wing... built up FFF? Newberry Parkflyers 3 Jul 16, 2004 04:53 PM
Yippee! Suggestions For My First Wing??? Overlord?? Bernoulli~Bros Foamies (Kits) 3 Apr 20, 2004 06:54 PM
My First Wing The OverLord by Edge RC S'portFlyer Foamies (Kits) 34 Jul 16, 2003 12:44 PM
