Old Jul 09, 2004, 01:11 PM
wim5150 is offline
Find More Posts by wim5150
illinois
Joined Jun 2001
Mabuchi S400 Model Numbers Again?
What are the Mabuchi model numbers for 6V and 7.2V speed 400 motors?
wim5150 is offline Find More Posts by wim5150
Old Jul 11, 2004, 12:31 PM
Hobbygroup is offline
Find More Posts by Hobbygroup
I'm Earl
Hobbygroup's Avatar
Home
Joined Apr 2004
Mabuchi Does not make single voltage motors they are in a range i.e. 1.5-3V, 3-6v. They also have High and low rpm motors but I found out that the SH400 series is a pretty good motor, for up to 3S packs.
Hobbygroup is offline Find More Posts by Hobbygroup
Old Jul 12, 2004, 03:40 AM
Bruce Abbott is offline
Find More Posts by Bruce Abbott
We want... Information!
Bruce Abbott's Avatar
Hastings, New Zealand
Joined Jan 2001
RS-380PH-5020 = Graupner #3320 Speed 400 4.8V
RS-380PH-4535 = Graupner #3321 Speed 400 6V
RS-380PH-4045 = Graupner #1794 Speed 400 7.2V
The last 4 digits of the Mabuchi code refer to the wire diameter (eg. 45 = 0.45mm) and number of turns per pole (eg. 35 = 35 turns).
Bruce Abbott is offline Find More Posts by Bruce Abbott
Old Jul 12, 2004, 07:50 AM
wim5150 is offline
illinois
Joined Jun 2001
Bruce, Thank you!
This is very good info!
Much appreciated!
Gets me to thinking though - can a brushed motor be re-wound to get better performance?
Old Jul 12, 2004, 10:35 AM
wrenwright is offline
Find More Posts by wrenwright
Battery Junkie
wrenwright's Avatar
Athens, GA
Joined Apr 2004
Bruce,
I bought a couple of Mabuchi RS-380 motors off ebay that don't have any other designation other than the rs-380 and a serial number.
I took one of them apart and they had about 72 windings per pole. They didn't seem to be very powerful and would require about 10 cells to do anything with a 6x3 prop DD.
Any comments/suggestions?
wrenwright is offline Find More Posts by wrenwright
Old Jul 12, 2004, 06:49 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Try 20 cells ?
Old Jul 12, 2004, 07:59 PM
Joined Jan 2001
They are probably RS-380PH-3270. This motor has maximum efficiency at about 2A, and needs 14V to match the performance of a 6V Speed 400 at 7V.
They could be useful in a large multi-engined model, eg. a B-36 Peacemaker might have 6 motors running on 16 cells, drawing about 30A total. The advantage of high voltage motors is that they can all be wired in parallel, which is more reliable and less complicated than a series/parallel combination.
Old Jul 14, 2004, 10:53 AM
Battery Junkie
wrenwright's Avatar
Athens, GA
Joined Apr 2004
Bruce,
How do you recon these motors would do in a twin with, say, a couple of 6x3 props DD? How many cells would I need?
Thanks.
Wren
Old Jul 14, 2004, 01:20 PM
Battery Junkie
wrenwright's Avatar
Athens, GA
Joined Apr 2004
Bruce,
Wired up the motor with 10 1300scr's and got 13,000 with 10x3. Seems like it doesn't quite match up with the 3270, as motocalc predicted only 11,000 with the 3270 and 10 cells. Maybe I'll see what 16 cells does.
Old Jul 14, 2004, 02:50 PM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Originally Posted by wrenwright
Bruce,
Thanks.
Wren
I reckon 5-6s LIPO, or 16-20 cells basically. But very low current cells - n=maybe 700mA/h or so.
Problem might be finding ESC for them.
Old Jul 14, 2004, 04:54 PM
Battery Junkie
wrenwright's Avatar
Athens, GA
Joined Apr 2004
I think the practicality of this proposition has reached about nil that this point.
Old Jul 14, 2004, 10:46 PM
Hotnewton is offline
Find More Posts by Hotnewton
Newton
S-Korea
Joined Apr 2004
I wanna find out some nice 500 euqal motor (Blushed motor) Which is best one please recommend for me~
Hotnewton is offline Find More Posts by Hotnewton
Old Jul 15, 2004, 02:42 AM
vintage1 is offline
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Best 500 class brushed motor is probably astro cobalt 05.
Old Jul 22, 2004, 09:12 PM
Battery Junkie
wrenwright's Avatar
Athens, GA
Joined Apr 2004
Anyone know a supplier in the US that carries the various Mabuchi motors like mentioned above (RS-380PH-5020, et al)? Especially interesting to me is the 4.8V motors. Paying Hobby Lobby $16 for a $2 motor is too much to bear for this tightwad.
Old Jul 23, 2004, 12:56 AM
Bare is online now
Find More Posts by Bare
Canada
Joined Nov 2000
Sometimes you can find the Mabuchis at an Electronics Supply House.. usually for $2 or $3.. but supply is 'iffy' and I've yet to spot a 4.8v variant.. 6 v are Rare enuff :-).
Could try rewinding.. it's definitely not Rocket Science.. and with a Magnetic Balancer you could actually Balance the Finished Armature. Few of which come from the Factory Balanced.. BUT some do.. look for the green blobs of Epoxy on the windings :-)
Bare is online now Find More Posts by Bare
Bengtson Fokker D.VII S400 Model Rodd Perrin Scale Kit/Scratch Built 126 Feb 21, 2005 10:32 AM
Esprit Model is awesome, again! Bill Germanson Vendor Talk 4 Feb 08, 2005 12:06 PM
Westland Wyvern s400 model? plane_spotter Scale Kit/Scratch Built 3 Sep 10, 2004 02:59 AM
Two Meter S400 model options Dave Moore Electric Sailplanes 10 Jul 24, 2003 12:46 PM
