I can't wait to see the video. It will probably show me flying it like an 80 year old women. I got to be better than Kevin at something.
Bob[/QUOTE] ROFL, Are you refering to me? Werent you there when I crashed into that succulent plant on the left side? I was just flyin from right to left, no one near me, no distractions..lol..... and for no other reason than bad pilotage I plow right into a bush. Then it flopped over once and landed on the face, almost 90 deg. and just stuck there........ like it was glued to the cliff face. It shoulda dropped the hundred or so feet and exploded. Luck I guess. At least you were willing to roll yours...lol Kevin |
Hey Doc--- so ya got a floater?? No problem-- send the gear into the manufacturer for a rebuild-- DON'T trust the reciever!! Too bad-- but I've flown a few--"boats" myself over the years-- be sure and spray out the torque rods real good with WD or something to be sure there is no salt water in there!! A little corosion really makes for tight ailerons!! Then--- hoist the main sail and fly on!!!
LOL, You guys crack me up. And thanks for all the great tips.
Use about negative 70 percent exponential on your ailerons. It's very easy to set this up on the 9C. TFLG turned me onto that a while back and I fly all my planes that way now. It makes the the roll rate nice and gentle in the middle of the stick so you can fly "gracefully" , but still gives you a nice snappy roll rate when you want it. Russ, I did use expo on this flight, but unfortunately I only used -35% on both ailerons and rudder. This helped a little a -70 wow thats alot I may try that and reduce the end points a little until I get more use to it. I use expo on my moth and it helps a lot especially on the pitch. Tim that is good a floater. back int the 70's that meant a big thermal type plane. I will spray the rods with WD for sure that is a good tip. Thanks. This is probably the wrong forum to ask this but, does anybody have any experience in sending stuff to Futaba? If not I will go to the radio forum and post the question there. Bob |
| Thread Tools | |
| Whoops! What do build next ? CSD P51 or Prodij | Kai@UCSB | Slope | 18 | Feb 22, 2005 08:54 AM |
