Old Jul 08, 2004, 10:07 AM
Keennon is offline
Find More Posts by Keennon
Keennon's Avatar
California
Joined Oct 2002
A New 2.4gr 1/72nd Scale 3ch SE-5 Biplane
Just finished test flying this new model, so I thought I'd share it with the group. I built a 1/72nd scale SE-5 sport scale model from sheet balsa. It's total weight is 2.4gr, span is a bit over 4 inches. It uses muscle wire for rudder and elevator control, about 60 position resolution. A 2.5V regulator drives the actuator to keep the travel and current down. The motor is the 4x8mm pager, low resistance, from Didel. Pretty much everything is custom/scratch from the radio to the gears to the prop. Radio is UHF frequency. Battery is the 20 mahr Kokam. Basically similar setup as my Ryan, but this is smaller overall and has a smaller motor. It flies wonderfully, very responsive, lots of climb, don't have a endurance time yet, should be a few minutes at least. The wing loading is around 2 oz/sq ft.
Hope you find it interesting, thanks. -Matt Keennon
Keennon is offline Find More Posts by Keennon
Old Jul 08, 2004, 10:17 AM
petter is offline
Find More Posts by petter
Oslo, Norway
Joined Nov 2003
Matt,
Congratulation !
This is the coooolest model I have seen.
Love to take a closer look at it at NEAT.
Petter
petter is offline Find More Posts by petter
Old Jul 08, 2004, 10:19 AM
Higher is offline
Find More Posts by Higher
Nashville, Tennesse, United States
Joined Mar 2004
That is the coolest model I have ever seen.
Andrew
Higher is offline Find More Posts by Higher
Old Jul 08, 2004, 11:03 AM
nanoflite is offline
Find More Posts by nanoflite
Belgium
Joined Jun 2004
Matt, you're the master!
This is indeed one of the niciest planes I've ever seen. Do you have anything to share about the UHF radio? Do you have a custom Tx as well, or do you hijack the output of a standard RC Tx (master-student port?) and feed the data into a custom transmitter? I tink I can see an Rx module in the model (the metallic canister), does it run on 433MHz? The antenna length seems to indicate something around that ...
Johan
nanoflite is offline Find More Posts by nanoflite
Old Jul 08, 2004, 11:11 AM
gbarc is offline
Find More Posts by gbarc
gbarc's Avatar
Jackson, Michigan, United States
Joined Nov 2002
Very cool Matt! Very cool indeed!!
Greg
gbarc is offline Find More Posts by gbarc
Old Jul 08, 2004, 11:22 AM
Mike Taylor is offline
Find More Posts by Mike Taylor
Team 30 Micro EDF
Mike Taylor's Avatar
Camarillo, California
Joined Apr 2002
Matt,
Awesome. It seems you have found a way to make the KBA look big! How thin did you mill the wing surfaces?
Mike Taylor is offline Find More Posts by Mike Taylor
Old Jul 08, 2004, 11:28 AM
Uttam1 is online now
Find More Posts by Uttam1
Micro Brushless crazy
Uttam1's Avatar
India, Bangalore
Joined Jul 2002
Wow! Matt, each one of your planes is better than the rest!! Excellent SE-5 Bipe!
Uttam
Uttam1 is online now Find More Posts by Uttam1
Old Jul 08, 2004, 11:35 AM
-=SLaPPiE=- is offline
Find More Posts by -=SLaPPiE=-
Designer of Flying Things
-=SLaPPiE=-'s Avatar
Overland Park,Kansas
Joined Apr 2004
Matt,
Wow! is right, that is a great piece of work. Thank you for sharing it with us.
[scratches head...UHF radio...range must be global]
Please tell us all about the radio.
Rich
-=SLaPPiE=- is offline Find More Posts by -=SLaPPiE=-
Old Jul 08, 2004, 11:43 AM
Prashanth is offline
Find More Posts by Prashanth
Bangalore Hindustan, India
Joined Apr 2003
MAtt
Awesome... SE-5,great work
any videos?
Prashanth
Prashanth is offline Find More Posts by Prashanth
Old Jul 08, 2004, 01:07 PM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
Had to be done, Se5's are great!!! This one is not great, even better, small!!!
Cool as usual Matt.
Q: Gear ratio and prop diameter? Look like watch gears?
Graham
Graham Stabler is offline Find More Posts by Graham Stabler
Old Jul 08, 2004, 01:14 PM
dburley is offline
Find More Posts by dburley
Portland, Oregon, USA
Joined Nov 2003
Real Good Show, Matt. It looks like you are putting a logo on your props now ??
Dave
dburley is offline Find More Posts by dburley
Pete P. is offline
Find More Posts by Pete P.
Frequent Poster
Pete P.'s Avatar
South of Boston
Joined Mar 2004
WOW! Awesome!! Do you have a weight breakdown??? That thinks kicks ass.
Pete P. is offline Find More Posts by Pete P.
Old Jul 08, 2004, 02:19 PM
nihil is offline
Find More Posts by nihil
^-- breaks stuff
nihil's Avatar
Joined Apr 2004
absolutely *beautiful*
nihil is offline Find More Posts by nihil
Old Jul 08, 2004, 02:44 PM
chaitanya is offline
Find More Posts by chaitanya
chaitanya's Avatar
Pune-India
Joined Nov 2003
superb plane,
thats ur trademark
would love to see a video
chaitanya is offline Find More Posts by chaitanya
Old Jul 08, 2004, 02:48 PM
Gordon Johnson is offline
Find More Posts by Gordon Johnson
in persuit of low wing loading
Gordon Johnson's Avatar
Boston, Mass
Joined May 2001
Matt,
I'm with Mike on this one. This plane makes a 4mm pager motor look huge. Great job. Now if you can get your friend to do the companion Fokker you could re-create your dogfights, but this time with palm-sized planes.
Gordon
Gordon Johnson is offline Find More Posts by Gordon Johnson
New Brushless motor - 1/3 scale model? allan Electric Plane Talk 12 Jan 10, 2008 06:37 AM
Discussion New Schweizer 2-33 1:8 scale Short Kit mmartin55 Scale Sailplanes 35 Aug 13, 2007 11:03 PM
Discussion Jammin CRT.5. New Mini 4WD 1/12-scale ! z3usx5 Off-road Cars 2 Jan 16, 2007 01:14 PM
PRINTS F-11C-2 GOSHAWK- 1/12 Scale iker3 Aircraft - Fuel - Airplanes (FS/W) 0 Mar 07, 2004 08:44 PM
1/72nd scale pt boat running gear? sgonzo Scale Boats 6 Sep 30, 2003 02:02 AM
