Old Jul 08, 2004, 01:23 AM
Chris Nicastro is offline
Find More Posts by Chris Nicastro
Chris Nicastro's Avatar
Post Falls, ID United States
Joined Feb 2004
Mr. Lin, a question about making planes.
Mr. Lin,
Can you explain how your planes are made? I was curious about the molds and how they work. I have tried to find some info online or maybe a company that has a site to explain it but I thought I would ask you.
Why are there so many bumps on the surface of the planes?
What is the difference between your style and the extruded foam used by Flying Styro and Alfa Models? Are they the same foam? Their skins are so much thinner, is it more expensive to manufacture in that way?
I would like to learn more about this topic and anything you could share would be appreciated.
I have an A-10 and its so cool, I put Vassa 55 fans with the Speed 300's in it though.
Chris...
Chris Nicastro is offline Find More Posts by Chris Nicastro
Old Jul 08, 2004, 11:47 AM
indybudd is offline
Find More Posts by indybudd
OV-102 Columbia
indybudd's Avatar
Southwest Florida
Joined Feb 2003
I think it's fairly obvious that the GWS planes are made by the foam injection molding method.
The foam is EPS, Expanded Polystyrene, just like the el cheapo foam coolers that 7-11 sells for $5 more then they should cost...
you will probably find out more info then Mr Lin can supply by simply searching google for "foam injection molding"...
It might be interesting for the tech junkies to know what brand/model machines GWS is currently using in the foam molding dept.
I'm not sure about the 'meat tray' style wings that are skinned with plastic(ky) material on one side. Maybe heated sheet EPS vacuum formed over a mold and bonded to the skin in one step?
indybudd is offline Find More Posts by indybudd
Old Jul 08, 2004, 12:09 PM
larsy87 is offline
Find More Posts by larsy87
Lookin' Good. Real Good.
larsy87's Avatar
London, Canada
Joined Aug 2002
Flying Stro's are made out of Depron. My guess is they heat it over a mold and vacuum form it.
larsy87 is offline Find More Posts by larsy87
Mr. Lin: Thought about any WW I planes? Highlander GWS (Grand Wing Servo) 17 Jul 22, 2004 07:41 PM
Hey Mr. Lin, how about a sneak peek at the Hellcat? splatman GWS (Grand Wing Servo) 1 Jul 05, 2003 04:43 AM
question about making a 2s2p li-po pack? Kwesdog Batteries and Chargers 4 Jun 09, 2003 04:48 PM
Mr Lin- a question of logivity... Scratchbuilder Parkflyers 2 Feb 24, 2003 08:04 PM
Quick Question about foam planes ratman Parkflyers 3 Jun 19, 2002 02:13 PM
