Old Jan 20, 2002, 03:37 PM
wallasan10 is offline
Find More Posts by wallasan10
wallasan10's Avatar
United States of Texas
Joined Dec 2001
what prop should I use
I only have one short test flight on this plane, the wind just wont die down!
It climbs pretty well but I wonder if it could do better with a different prop.
Moter is out of a litestick and has a 10x4.7 prop.
The plane has 48in. span and 9in. cord and the AUW is 8.68oz with a qualcom battery pack.
Big plane, small motor, light weight and low drag (this thing really float's with power off)
Thanks for any help Randy
wallasan10 is offline Find More Posts by wallasan10
Old Jan 20, 2002, 04:03 PM
LuckyArmpit is offline
Find More Posts by LuckyArmpit
Rehab is for quitters
LuckyArmpit's Avatar
West Middlesex, PA, US
Joined Jun 2001
Wallason, what is the name of that plane? I like the looks of it!
Dave...
LuckyArmpit is offline Find More Posts by LuckyArmpit
Old Jan 20, 2002, 04:16 PM
wallasan10's Avatar
Joined Dec 2001
name
I never gave it name, it's my first tailless plane and I didnt know how it would fly. It flys great, but still no name.
Old Jan 20, 2002, 06:10 PM
Pierre Audette is offline
Find More Posts by Pierre Audette
RPV builder & operator
Pierre Audette's Avatar
Canada, QC, Gatineau
Joined Jan 2001
If you running the DX-A motor, you can use up to 8 cells for short flights, with a heat sink and the same prop. What's in a qualcom pack? 6 cells?
A 9x7 prop may give it some more speed, but not necessarily better climbing, but better in windy conditions.
Looks great by the way.
Pierre Audette is offline Find More Posts by Pierre Audette
Old Jan 20, 2002, 09:45 PM
wallasan10's Avatar
Joined Dec 2001
qualcomm cell's
Sorry about that. My battery pack is 2 lithium ion cell's from a surplus Qualcomm cell phone battery pack, a lot of people use them now so I sometimes just call them "qualcomm packs". If you havent tried them I hope you get to soon because they are cheap and will fly a lite-stick till you get tired of looking up! The down side is you only get the punch of a six cell pack.
The 9x7 prop sounds like a good idea tho and it's one I'll try.
Old Jan 21, 2002, 06:20 AM
Aspen is offline
Find More Posts by Aspen
Aspen's Avatar
Kingsport Tn.
Joined Nov 2001
I'm flying DX-A's and Qualcomms exclusively on my 3 planes now (TM, TIFO, and MiniPleaser). I've had great performance from the 10x8 GWS and 10X7 APC (SF). You might try one of these higher pitched props. Probably stesses the motor a little, but I've not had any problems in cool weather with a heat sink.
BTW, I like the plane! How about some details!
John
Aspen is offline Find More Posts by Aspen
Old Jan 21, 2002, 08:58 AM
Chris G Hansen is offline
Find More Posts by Chris G Hansen
Spokane, WA
Joined Nov 2001
props
you may want to give the ARC-1 with the 3mm hub a try... It works great on the A or B motors. With a rebuild fixture you can also change the pitch and the diameter of your props too.
Check us out at www.anythingrc.com
Chris,
Chris G Hansen is offline Find More Posts by Chris G Hansen
Help! What prop should i use on HXT 35-42A 1450kv martseger63 Power Systems 12 Jun 11, 2007 02:33 PM
What prop should I use? GalantVR4 Parkflyers 3 Jun 06, 2004 09:19 AM
hacker c40 12s with a 5.0 gear ratio what prop should i use please help falcon41176 3D Flying 7 Apr 02, 2004 03:56 PM
What size prop should I use? ErnieR Foamies (Kits) 1 Sep 17, 2001 11:10 AM
What prop should I use on a Jeti Brushless 15/4 powered Zagi? Ryan Nau Foamies (Kits) 0 Jul 03, 2001 06:11 PM
