Old Jul 06, 2004, 07:10 AM
Vtol Builder
Lewist's Avatar
High Wycombe, Great Britain (UK)
Joined Jul 2004
Harrier Jump Jet
Hi, i am sure this has been asked a thousand times before, but i ahd a look back over the last 10 pages and couldn't see anything on it so i thought i would ask.
I have no flight experience at all, so please bear with me, i am getting my first plane in a few days (or whenever it turns up) so i am making a start, but i was wondering about the feasability of a Harrier.
I was thinking about having 4 small edfs. one connected to each thrust tube. you could then use 2 gyros to controll the 4 motors to keep the plane level in hover mode. to move left and right you could vary the speed of the motors to tilt the plane and move it. as for forwards and backwards you could use a combination of motor speed and duct angles.
would that even be possible, or would it be just too heavy and overly complex to build and setup??
thanks
Lewis
Lewist is offline Find More Posts by Lewist
Old Jul 06, 2004, 07:15 AM
EDF Head
Haldor's Avatar
Stavanger, Norway
Joined Feb 2000
In theory its a piece of cake, in real life no one have made it happen yet. Weight is your main enemy/challenge.
Haldor is offline Find More Posts by Haldor
Old Jul 06, 2004, 07:33 AM
Vtol Builder
Lewist's Avatar
Joined Jul 2004
ok, what sort of thrust would a edf for a 300 motor have running a really hot brushless on 11.6 volt Lipos.
it guess the main construction would have to be foam to save weight!
Lewis
Old Jul 06, 2004, 07:41 AM
310mph Kolibri T25 Swist
henke's Avatar
Sverige, Kronobergs Län, Ljungby
Joined Jan 2001
thinking Minifans with Mega /2 should be able to burst to 400watts/fan giveing the power to lift... say 7lb
with two 3s3p TP6000 it could be done
300fans are a bit too small I think... (kind of the same weight for the motor but in a smaller fan)
henke is offline Find More Posts by henke
Old Jul 06, 2004, 07:47 AM
Vtol Builder
Lewist's Avatar
Joined Jul 2004
I was thinking 300 sized motos to keep the fan units small, to keep the overall size of the model smallish, bearing in mind there would be 4 fan units! also need to have large enough intake to feed them whilst still maintaining scale!
i think it is possible, but as has been said weight is the enemy! i think i might have a crack at this but it will be a long haul project,
i think using 4 fans would be better than 1 huge one because of the ability to alter the speed of each unit to keep it stable in a hover. if one were used i guess either thrusters would be needed to stablise it or flow controll on each nozzle would be required!
Old Jul 06, 2004, 08:22 AM
Fe Fi Fo Fum
Large One's Avatar
Useless Loop, Australia
Joined Apr 2001
What about an all depron airframe, cdrom (or small brushless) motors and lipos..
If you were willing to put up with small batteries/short flights, I reckon control in hover may be the hard part...
Large One is offline Find More Posts by Large One
Old Jul 06, 2004, 08:44 AM
Bill Glover's Avatar
Bracknell, Berks, UK
Joined Nov 2000
It's not a big problem to build something that hovers (for a short time) using ducted fans. All you need are some clever mixers and a few gyros, once you have the power to weight issue resolved.
The difficult bit is building a Harrier (or anything else) that will transition from hover to forward flight and back again. This has been done a couple of times, but only with very non-scale models using big vanes in the prop/fan wash for control (and usually IC motors rather than electric).
Bill Glover is offline Find More Posts by Bill Glover
Old Jul 06, 2004, 08:59 AM
Vtol Builder
Lewist's Avatar
Joined Jul 2004
Why can't the model use the same idea as the real one, rotate the nozzles from facing rearwards to facing down (or slightly forwards) and let the gyros hold it steady while it slows!
Old Jul 06, 2004, 09:22 AM
Gimme the whole 11 blades baby
stumax's Avatar
Sydney, Australia
Joined Aug 2002
The 50Hz update rate from an Rx is too slow to consider making a closed loop control system for something as complex as hovering an aircraft. It has been done, but the aircraft are always on the verge of tipping over, unless you can make something that has a minute moment of inertia in all three axes. It needs a micro controller to accept inputs from the gyros and send modified outputs to the stability control devices, and the update rate would ideally be in the kHz range to allow a high proportional gain without instability. With the advent of lipos it will be possible to do it thrust/weightwise, but it's not a weekend project to sort out the control system.
Stu.
stumax is offline Find More Posts by stumax
Old Jul 06, 2004, 09:37 AM
Vtol Builder
Lewist's Avatar
Joined Jul 2004
Stumax.. sorry you will have to bear with me on this... 50Hz update rate? does the gyro not deal with the stability controll, what is the refesh rate of those?
also would this end up being a complete pig to hover.. i can fly helicopters, but i guess this is a totaly different ball game!
this would be a long term project, i would plan to make a test rig first to test the gyros and controll systems before i even consisdered making the model
Old Jul 06, 2004, 10:31 AM
Joined Nov 2000
The real one uses compressed air bleeds to both wingtips, nose, and tail for control in the hover.
Old Jul 06, 2004, 11:46 AM
Vtol Builder
Lewist's Avatar
Joined Jul 2004
i had heard that (you can tell i have done a huge ammount of research!)
i am sure however that the same sort of effect could be gained by varying the speed of each EDF on each nozzle.
The one area of concern that i do have, is will i need to turn the gyros off in fight mode. now in hover mode if you push the aerlon (spelling!) stick to the right it would speed up the EDFs on the left of the plane, causing it to bank slightly and move to the right. in flight if this were to happen it would cause the left EDFs to increase speed thus pushing it towards the deck in a hard turn. now the difference in trust between left and right would only have to be fairly small becuase in hover mode you would not need a lot. but in filght mode would this cause odd or bad handling charactoristics??
thanks
Lewis
Old Jul 06, 2004, 11:47 AM
Lithium Member
Herb's Avatar
Irvine, Calif USA
Joined Feb 1999
... this would be a long term project ...
Indeed it is ... Sorting out the control system takes quite a bit of time and patience, with LiPos power is not so much an issue anymore, provided you are willing to have fairly short flights. A test rig is of course the way to go, but I am pretty sure you can do it with standard off-the-shelf electronic components .
http://www.rcgroups.com/forums/showt...&highlight=X35
Herb is offline Find More Posts by Herb
Latest blog entry: BAe Hawk 90mm EDF
Old Jul 06, 2004, 12:09 PM
Joined Sep 2002
50 hz.... ??? AAAHHH.... why not control hovering stability on its own (no user input)... you simply tell it to go up down or left, and then hook up a PIC controller w/ a PID loop (u probably only need prop and integral....deriv is not so important) so basically you flip a switch to go in hover mode... moving elevator up would increase the EDF power, down would decrease, moving it left or right would increase power on one side and decrease on the other then once you let go of the stick the PID kicks in to correct the plane to stable hovering positioN!
I think making the plane fly forward will be your next big challenge...you probably have to rotate the 4 fans 90 deg.. unless you are using nozzles (but then i think u'd lose efficiency becasue of the air having to make a 90 degree turn while hovering...and u still need to turn the nozzles!!!!)
So you will need at least 1 motor to control that!
Pretty complex i'd say but probably possible
ssyed is offline Find More Posts by ssyed
Old Jul 06, 2004, 01:56 PM
Joined Nov 2000
So how would you get yaw control? Apart from that I don't think the nozzles would be far enough apart to get positive pitch or roll control anyway, and I doubt the fans would be able to speed up and slow down fast enough to maintain control.
now in hover mode if you push the aerlon (spelling!) stick to the right it would speed up the EDFs on the left of the plane, causing it to bank slightly and move to the right. in flight if this were to happen it would cause the left EDFs to increase speed.
Assuming you have now rotated the fans aft (if not, what is making the plane move forward?) speeding up the left fans will give right YAW, not right roll.
Harrier Jump Jet Plans? P6Mole Fuel Jet Talk 9 May 05, 2011 05:47 PM
Build Log AV8/GR7 Harrier jump jet PSS Henry V Slope 181 May 22, 2008 05:20 PM
Discussion harrier jump jet Jb45 Foamy EDFs 1 Jul 10, 2007 08:49 PM
Harrier Jump Jet Plans?? P6Mole Electric Ducted Fan Jet Talk 4 Feb 08, 2005 10:08 AM
Av8 B Harrier Jump Jet balsaduster Electric Ducted Fan Jet Talk 45 Dec 29, 2002 04:40 PM
