Old Jul 05, 2004, 09:04 PM
ElvisLivesOn77 is offline
Find More Posts by ElvisLivesOn77
Joined Jul 2004
Too high of voltage?
I am currently building a UK Antweight (but I do live in the states) and am planning on using the GW/R-4PII 4CH FM PICO reciever. Would it be able to handle the 7.4volts my lipolys are putting out?
ElvisLivesOn77 is offline Find More Posts by ElvisLivesOn77
Old Jul 06, 2004, 02:59 AM
steve lewin is offline
Find More Posts by steve lewin
N. Staffs, UK
Joined Jan 1997
Not directly no, but doesn't your robot (assuming that's the Antweight you mean) have a speed controller with BEC ? The BEC cct cuts the main motor voltage down to 5V for the receiver.
Steve
steve lewin is offline Find More Posts by steve lewin
Old Jul 06, 2004, 01:53 PM
Joined Jul 2004
It is an UK antweight but I'm using modified servos for drive to cut down on weight. Where could I find a reglator to cut my voltage down to 6 volts?
Discussion Output voltage too high (hyperion 1210i)? expertzx Batteries and Chargers 0 May 14, 2007 08:40 PM
If 3s voltage is too high? ICRSHLTS Batteries and Chargers 7 Oct 17, 2003 05:49 PM
10/12/20/24 cell High Voltage Panasonic 3000s and loose cells too! Jason M Aircraft - Electric - Airplanes (FS/W) 17 Sep 16, 2003 09:33 PM
Endo current draw seems too high? Herky-Bird Sport Planes 8 Sep 08, 2001 09:47 PM
jeti 140 high voltage cut-off berniep1 Electric Plane Talk 7 Apr 25, 2001 11:34 AM
