Old Jan 20, 2002, 01:28 PM
JimF is offline
Find More Posts by JimF
Ellington, Connecticut, United States
Joined Apr 2001
Expert 6ch Micro Receiver GLITCH Problems
I just purchased an "Expert Electronics" 6channel, dual conversion micro receiver #650 and put it in my Zagi to the side of the battery cuttout just like I've seen in some of the posts here. I was flying yesterday and experience significant glitching when only about 600 or 700 feet away. I went back in and replaced it with my standard size Hitec receiver, same place, just a bigger hole, and routed the antenna in basically the same place. NO PROBLEMS. I also had aluminum foil around the ESC in both cases.
Any ideas? I was told that this was a full range, dual conversion rec.
Jim
JimF is offline Find More Posts by JimF
Old Jan 21, 2002, 03:26 AM
Silver is offline
Find More Posts by Silver
T-52 over Seattle
Silver's Avatar
Seattle
Joined Jun 2001
I've been using the Expert 650 for a couple of months now and haven't had any problems.
The Expert 650 is a repackaged JR 610M and uses the same single conversion crystals as the JR. Dual conversion receivers are used to eliminate cross-talk between channels which JR's single conversion RX does using a clever engineering design in their patented ABC&W circuit (Anti-Blocking Cross-modulation and Windowing).
I know a lot of people using the 650 and 610M in their planes and gliders without range problems. It sounds like 'your' RX is suspect, but I would suggest trying a different 650 in the same plane before dropping all 650s. A cold solder joint on the antenna, for example, would certainly give you problems.
Anyway, those are my experiences with the 650. I have found them to be a good, inexpensive, very light-weight RX. Your LHS might be able to swap your suspect one for a new one.
Silver
Silver is offline Find More Posts by Silver
Old Jan 23, 2002, 10:31 AM
JimF is offline
Joined Apr 2001
Thanks Silver,
It's been a disappointment so far. I ordered the Rx and crystal, and when they arrived the crystal was the wrong freq., even though the big red and white label on the package was the correct one. Not the LHS error though, because when I phoned, he looked through his stock and had several mislabelled.
I guess I'll try it again on the bench and see what happens. Like I said, I put my std size hitec in the same spot, same day and it worked great.
I'm using the JR crystal. It fits in two orientations, so I'm guessing there's no polarity to the plug.
Jim
JR R610M 6CH micro receiver localbuyer Aircraft - General - Radio Equipment (FS/W) 4 Apr 23, 2005 06:46 PM
FS: JR R610M 6ch micro receiver Lance Aircraft - Electric - Airplanes (FS/W) 2 Mar 09, 2004 06:57 AM
For Sale JR Quatro, 6ch Micro Receiver, 2 NES241 Servos swr@pobox.com Aircraft - Electric - Airplanes (FS/W) 0 Mar 26, 2003 09:09 PM
GWS Micro Receiver Glitch Fixed! ls77 Parkflyers 19 Jul 18, 2002 12:35 PM
Expert 6ch micro receiver questions JimF Parkflyers 0 Jan 20, 2002 01:39 PM
