Old Jul 05, 2004, 05:37 PM
Skygazer is offline
Find More Posts by Skygazer
Wollongong, NSW, Australia
Joined May 2004
Where to get Goop in Australia
Hi all,
I am new to sloping and am interested in trying goop to protect my sloper. Does anyone know where to get Goop, Marine Goop or Shoe Goo in Sydney Australia? I cannnot seem to find it anywhere. Also can I use it to cover a finisded plane covered in normal tape?
Skygazer is offline Find More Posts by Skygazer
Old Jul 05, 2004, 06:00 PM
alkoo is offline
Find More Posts by alkoo
speedfreek
alkoo's Avatar
Newcastle, Australia
Joined Apr 2003
Its called Shoo Goo and you will find it in any sports store for about $12.00 a tube. You thin it down with Slate & Concrete Sealer Solvent which is about 80% Xylene, which you can get in hardware stores like Bunnings for about $15.00. Thin it down to the consistancy of warm honey or varnish and apply it with a foam brush to avoid brush strokes.
I paint it on my planes over the solartex. You can see the results on my old Electron 54 at http://www.speedfreeks.com. It will also work over the tape, but it may peel off a little easier if you dont rough the tape up first.
Regards,
Waz
alkoo is offline Find More Posts by alkoo
Old Jul 05, 2004, 06:06 PM
Skygazer is offline
Joined May 2004
I have tried a couple of the shoe repair / key cutter people but they did not sell it anymore. I will try Rebel sports and see if they have it.
Nice build BTW.
thanks
Old Jul 05, 2004, 09:17 PM
JayF is offline
Find More Posts by JayF
Registered Luser
JayF's Avatar
Australia, NSW, Sydney
Joined May 2004
I got a tube of Shoe Goo at Rebel Sports for $12.50 - in QLD but I'm sure NSW stores would stock it.
Jason
JayF is offline Find More Posts by JayF
Old Jul 05, 2004, 09:23 PM
AntonL is offline
Find More Posts by AntonL
antipodean recalcitrant
AntonL's Avatar
Melbourne, Victoria, Australia
Joined Feb 2004
I bought a tube the other day for $10 at a shoe repair/engraving/key cutting shop in a shopping centre.
Anton
AntonL is offline Find More Posts by AntonL
Old Jul 05, 2004, 11:21 PM
Skygazer is offline
Joined May 2004
Thanks. Any idea how much would it take to cover a 48" PC9?
Old Jul 06, 2004, 02:55 AM
Skygazer is offline
Joined May 2004
Thanks I just bought some from Rebel for AUD $10.95
Old Jul 06, 2004, 03:13 AM
alkoo is offline
speedfreek
alkoo's Avatar
Joined Apr 2003
One tube should do the trick if you concentrate on applying more to the wear & tear areas such as the nose, wingtips etc (ie more coats) and less on the rear section of the plane. Even though it doesnt weigh a lot after drying (which may take up to a couple of weeks to totally cure) it will add up and make your plane tail heavy, so you will have to re-balance the COG.
You can apply more after that if need be. At first it will appear as if you have heaps of runs and beading under the smooth finish, but dont worry, it eventually shrinks down after drying and you can hardly see them. You wont get a perfect "glass" finish with more coats of goop, but if you can put up with minor "ripples" on an otherwise smooth shiny surface, it certainly is the way to go for strength.
Regards,
Waz
Old Jul 06, 2004, 09:57 AM
AntonL is offline
AntonL's Avatar
Joined Feb 2004
It's worth searching for and reading Ian's advice on this forum (user name Daemon) re using thinned goop. It varies depending on the plane but with the Moths and M60s, the best approach seems to be as follows:
Fuse: EPP/1 coat thinned goop/fiber tape (ironing down each strip smooth)/1 coat thinned goop/solartex/1 or 2 coats thinned goop
Wings: EPP/1 coat thinned goop on LE + wingtips/fiber tape on LE + spars + tips/solarfilm (or other similar iron-on film)/1 coat thinned goop on LE + spars + tips
The idea here is that this "composite" method is supposed to be far more durable and tear/impact-resistant than simply building up many layers of thinned goop on EPP.
I just used this method on my Moth and have yet to maiden it but it certainly does seem very tough.
Anton
Old Jul 06, 2004, 02:53 PM
steve wenban is offline
Find More Posts by steve wenban
Crikey never leave beer behind
steve wenban's Avatar
Mt Annan Sydney Australia
Joined Dec 2003
Brad see what Waz said it takes a few weeks to cure fully .Do you think you can hold yourself back from flying it for that long lol
steve wenban is offline Find More Posts by steve wenban
Old Jul 06, 2004, 04:36 PM
Daemon is online now
Find More Posts by Daemon
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
It cures enough to fly in only a day or two. But yes it takes a week or so before it's 100% cured. Thinner coats cure faster which is why the
old 15 coats of Goop technique is no longer preferred.
ian
Daemon is online now Find More Posts by Daemon
Old Jul 06, 2004, 05:23 PM
Skygazer is offline
Joined May 2004
Thanks all. I will have to work out the best time to do this as I don't want to miss any good fying time !
What is Minwax Polycrylic - where can I get it from in Australia Inflexo Hand Launch 10 Sep 29, 2014 07:14 PM
Discussion Where to get SuperTron in Australia Psionic001 Dynamic Soaring 2 Jan 30, 2007 05:32 AM
Where can you get IPS A in Australia Loopy GWS (Grand Wing Servo) 9 Dec 09, 2003 07:56 PM
Anyone know where to get 1100HECells in UK/Europe? Herky-Bird Parkflyers 0 Oct 27, 2002 02:07 PM
Where to get foam in England? awood12345 Foamies (Kits) 4 Jul 30, 2002 06:40 AM
