Old Jul 05, 2004, 08:50 AM
meteor is offline
Find More Posts by meteor
meteor's Avatar
Ontario, Canada
Joined Nov 2002
Cool
Wattage Mig-15: CBP 650mAh and 16/7/7
Here's the results of a Wattage Mig-15 combined with a Mega 16/7/7 and a 10-cell pack of Cheap Battery Packs' 650mAh 2/3AA cells. (same as KAN 650's)
http://meteor.rchomepage.com/mig-15-jul04.wmv
This set-up will drop the AUW by about 3oz., and offer more RPM due to the conversion to brushless vs. the stock Speed 400. (but, the actual power to the motor is slightly -less- than the stock set-up!)
The video starts with a landing, to show the low-speed characteristics, and it was also the first time I launched it myself. (we didn't have another body for a "tosser", and a cameraman!)
The dip upon launch is -not- caused by lack of power, I simply didn't get on the stick quite quick enough!
Normally, it will climb away with no initial altitude loss.
Fun, and very cheap!
meteor is offline Find More Posts by meteor
Old Jul 05, 2004, 02:49 PM
bboydeezturb is offline
Find More Posts by bboydeezturb
bboydeezturb's Avatar
West Chicago,IL
Joined Oct 2003
Kool Video
What ESC did you used the CC P10 or the P25???
and also What kind of flight time can you get with this battery pack????
Thanx
bboydeezturb is offline Find More Posts by bboydeezturb
Old Jul 05, 2004, 03:07 PM
meteor is offline
meteor's Avatar
Ontario, Canada
Joined Nov 2002
Cc 25...
Oddly enough, I tried a Castle Creations Phoenix 10, but it seemed that there is too much resistance in the ESC and/or wire to allow the motor to reach the same RPM as the CC 25.
It was very weird; I sold my TMM 18 controller, and installed a CC 10, but there was not quite enough power to allow the plane to fly, it simply settled into the ground in about 50 feet (or less)
I swapped it out for the CC 25 and it flew exactly as you saw above, which was also the way it flew with the TMM 18.
The HOC load on the batteries/ESC is a bit over 10A, so there's a chance that the CC 10 just can't handle it, but the controller never shut down, or showed any other weird effects.
Sometime, I may do a bench-test with these two controllers to see if wiring and/or resisatnce is the issue.
Oh yeah, the flight time is almost 4 minutes, going flat-out. (you really can't throttle back too much with most EDF's!)
Old Jul 05, 2004, 03:35 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
Thats really cool! Heck might be fun to add 2 more cells and come in at a bit under 1 1/2 oz below stock but with almosr the same power as the 3T combo. I'm sure the 7T could handle the 14 to 15 or so amp load and the 150 something watts or so would be fun!
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Jul 05, 2004, 04:37 PM
meteor is offline
meteor's Avatar
Ontario, Canada
Joined Nov 2002
Diminishing returns...
Well, those little 2/3AA's are really capped out at 10A, and right HOC they are almost at 11A, so you wouldn't gain much by adding two cells.
On 12 cells at 14A-16A, the voltage would depress quite badly, and you really would get a proportional power gain for the weight penalty.
If you want more power (with the same weight), you'd be better off with a hotter wind and an 7/8-cell pack of the new GP 1100's, which can handle 20A+
I have yet to test it, but the 16/7/6 might be a good 7-cell combo. (the 16/7/5 might be a bit too hot a wind)
I'll be testing a Razor 2500 and 7-cell KAN 950's in the Mig soon! (almost the same power level as in the video)
Old Jul 05, 2004, 06:02 PM
West Chicago,IL
Joined Oct 2003
will any cheaper Himax motors work with this Mig???? I was reading something about the himaxx 2025-4200 working good up to 200watts......but I think the ampdrawn will be too much for these batteries right???
sorry, but I'm just starting to get in EDF. that's why all the questions
Old Jul 05, 2004, 06:56 PM
meteor is offline
meteor's Avatar
Ontario, Canada
Joined Nov 2002
Himax...
Dunno about the Himax motors, but the price difference is marginal...
From what I heard, Himax motors are lower-efficiency clones of the Hacker B20 series.
There also might be an issue with the Himax motors not having enough torque to turn the 64mm rotor efficiently. (for example, the Hacker B20S can't handle the load)
Old Jul 05, 2004, 10:07 PM
Joined Aug 2002
didint know the 650's were that touchy at those loads, your right then there would be no gain.
Old Jul 06, 2004, 03:55 PM
Mmarshall is offline
Find More Posts by Mmarshall
Hey... watch this...
Mmarshall's Avatar
Herndon, Virginia, United States
Joined Feb 2003
I use a Himax 2025-4200 in the stock fan unit with a P25 and 3S2P Etec pack for a total of 2400 Mah AUW is aorund 19.5 ounces.
The motor draws 19 amps simple math makes that 210 watts but its probably more like 190 watts.
The plane takes off in around 50-60 feet from asphalt using the stock landing gear and appears to be doing 70-80 mph (at least thats what my hotliner flying buddies think)
So far engine temps are around 110 degrees after 4 min flights and batts are just warm, been putting about 1000 MAH back in so should be able to do 8 mins full throttle no problem.
Can say enough good things about the Himax 4200 I started with a 3200 on a 3 cell Kokam then tried a 4 cell Kokam but both those setups lacked good vertical and the ability to do multiple loops was not there, once I change to the 4200 with the twin etec packs it became a much more fun plane to fly.... For those of you who have never flown these things on asphalt (with curbs!) it will definatly give a larger pucker factor
Mmarshall is offline Find More Posts by Mmarshall
Old Jul 07, 2004, 11:39 PM
mikesurfs is offline
Find More Posts by mikesurfs
Slim Shady
mikesurfs's Avatar
Henderson, NV
Joined Mar 2004
Meteor,
I was looking at the Mega 16/7/7 specs and it gives 21,000rpm at 9 amps with 8 cells. It further shows the 16/15/2 at 40,000 rpm and lists it as a ducted fan replacement, but drawing 35 amps. Think this could be run using a 3s2p Lipo?
Mike.
mikesurfs is offline Find More Posts by mikesurfs
Old Jul 08, 2004, 11:34 AM
meteor is offline
meteor's Avatar
Ontario, Canada
Joined Nov 2002
16/15/2 in a Mig!
Well, the Mig and F-86 are really just park-flyer 'planes...
You'd need a rotor replacement to run the 16/15/2, and the power draw would probably exceed 35A at 10V (3S Li-po).
That's simply too much power for this little foamy!
If you want more power than what's in the video, try a 16/7/6 or /5 and a 3S1P 1800/2200 Li-Po pack, but be careful not to exceed the motor's max amps (15A for the /6, 16A for the /5)
Good luck!
Old Jul 11, 2004, 11:25 PM
NoM'rcrashPlease is offline
Find More Posts by NoM'rcrashPlease
"Walk of shame" Master!!!
NoM'rcrashPlease's Avatar
West Chicago Il
Joined Jul 2004
(/quote)If you want more power (with the same weight), you'd be better off with a hotter wind and an 7/8-cell pack of the new GP 1100's, which can handle 20A+
I'll be testing a Razor 2500 and 7-cell KAN 950's in the Mig soon! (almost the same power level as in the video)[/QUOTE]
Have you tested this setups yet???
by the way! love the video
NoM'rcrashPlease is offline Find More Posts by NoM'rcrashPlease
Old Jun 02, 2005, 08:50 PM
meteor is offline
meteor's Avatar
Ontario, Canada
Joined Nov 2002
Video Back Up!!!
Check it out!
Old Jun 02, 2005, 09:48 PM
roccobro is offline
Find More Posts by roccobro
Watts your motivation
roccobro's Avatar
San Bernardino, CA
Joined Aug 2003
Thanks for update and posting the video again!
Justin
roccobro is offline Find More Posts by roccobro
Old Jun 28, 2005, 03:55 PM
PerfectStranger is offline
Find More Posts by PerfectStranger
one game away...
PerfectStranger's Avatar
Willoughby, Ohio
Joined Apr 2004
always good to see!
matt
PerfectStranger is offline Find More Posts by PerfectStranger
Video: Wattage Mig-15 + Mega 16/7/7 @ 80W! meteor Electric Ducted Fan Jet Talk 19 Jun 13, 2004 11:35 PM
mega 16/15/2 or 16/15/3 wattage Mig 15 Cliff Smith Electric Ducted Fan Jet Talk 20 Aug 11, 2003 07:51 PM
Wattage Mig-15 monkamarm2000 Electric Ducted Fan Jet Talk 26 Feb 04, 2003 04:24 PM
?? list of small EFD's??/Wattage mig 15??? Phillybaby Electric Ducted Fan Jet Talk 19 Sep 16, 2002 02:50 AM
Wattage Mig-15 - Anybody Have one Yet?? mrebman Parkflyers 1 Apr 27, 2002 04:01 PM
