Jul 03, 2004, 11:46 PM
United States, CA, Stanton
Joined Jan 2004
FS Hitec Eclipse 7 with Spectra Module
Ok Guys I'm selling my Hitec Eclipse 7 with the Spectra Module
7-Channel QPCM/FM Transmitter/Spectra
I paid 240 for it back in April.
Just bought a Futab 9CHF so that why I'm selling my Eclipse 7, There's nothing wrong with it the charger comes with it in the orginal box and you get all the paper work to boot.
Can be used for planes and helis.
Asking 180.00 Shipped pm if your interested
FEATURES: Four separate programming loops; one for fixed wing (glow, gas or
electric aircraft); one for helicopters; and, two sailplane -
(one for basic and one for advanced sailplanes).
Large LCD display screen.
All switches and knobs are at fingertip control.
7 model memory.
Programmable shift.
Three conditional mixes per model memory.
7 character model naming.
Model copy.
Spectra frequency synthesizer module is included.
Digital trims.
Sub trims.
Five programmable mixes (two in helicopter mode).
In-flight timer and alarm.
Low transmitter battery warning.
End point adjustments for all channels.
All channel servo reversing.
Dual rates on channel 1,2 and 4.
Exponential rates on channels 1,2 and 4.
Data reset to defaults.
Trainer jack and trainer switch.
Throttle cut switch.
Three flight modes of Fixed Wing Power, Glider and Helicopter.
Helicopter specific features:
Throttle cut
Throttle hold
Rudder-throttle mix
3 idle-up stunt modes
5 point throttle curve
5 point pitch curve
Gyro gain adjust
Revolution mix
Hovering pitch knob
Hovering throttle knob
Engine lock switch
Swash mode mix, 90, 120 and 180 degrees
ACRO (Airplane w/glow, gas or electric) fixed wing specific features:
Landing mix
Flap trim adjust
Elevator-flap mix
Aileron-rudder mix
Elevon mix
V-Tail mix
Flaperon mix
Flaperon differential
Glider (Two Servo Wing Mode) specific features:
Aileron differential
V-Tail mix
Elevator-flap mix
Aileron-rudder mix
Flap-aileron coupling
Flap-elevator coupling
Flap-aileron trim
(Four Servo Wing Mode) Same as above plus:
Crow mix
Aileron-dual flap trim
Aileron-dual flap coupling
Dual flap-aileron trim
