Old Jul 03, 2004, 06:31 PM
gbarc is offline
Find More Posts by gbarc
gbarc's Avatar
Jackson, Michigan, United States
Joined Nov 2002
How to build a good looking pager motor plane!
To address a certain thread with a similar name I thought that this might now be an appropriate time to start a thread like this. We'll limit it to pager motor plane contruction ,hints and plans.Also let's add a twist.....Semi scale,profile or full it doesn't matter. Soooo...bring em' on guys!!
Greg
gbarc is offline Find More Posts by gbarc
Old Jul 04, 2004, 04:21 AM
jmquetin is offline
Find More Posts by jmquetin
www.jmquetin.com
jmquetin's Avatar
Paris - France
Joined Aug 2003
Greg,
To answer your question I would say : Just carefully read this forum !
May be we could put it in a slightly different way and only concentrate on "best" hints, "easiest" or "most effective" solutions, etc... ? Of course, all that depend on your own skills and might differ from one modeler to another.
Jean-Michel.
jmquetin is offline Find More Posts by jmquetin
Old Jul 04, 2004, 05:26 AM
TimayTheToolman is offline
Find More Posts by TimayTheToolman
Kiwi's Can Fly's Son
TimayTheToolman's Avatar
New Zealand
Joined Dec 2003
Find a nice plane that is to be made from paper ie: Fiddler's Green planes, cut it out as if you were going to make it from paper, but instead trace it onto 2mm wallfoam, paint on all the markings while it's still on the flat sheet, when done, cut the peices out and assemble the plane. et voila:
Tim.
TimayTheToolman is offline Find More Posts by TimayTheToolman
Old Jul 04, 2004, 05:46 AM
jmquetin is offline
www.jmquetin.com
jmquetin's Avatar
Paris - France
Joined Aug 2003
Tim,
I like this method (I have to try it one day). You can print all the markings on a tissue paper and glue it on the foam. There are plenty of planes' descriptions made in a such way in this forum.
<<when done, cut the peices out and assemble the plane. et voila:>>
That is another story : You have to find proper balancing, proper motor and prop, proper gear, achieve a low wing loading and a good flight time. Then, trim the plane, et voila !
You have a nice model anyway. What is the weight of the airframe ?
Jean-Michel.
http://www.jmquetin.com
Old Jul 04, 2004, 10:10 AM
aeronutz is offline
Find More Posts by aeronutz
Leicester England
Joined Jun 2001
Micro planes that look like planes are reserved for indoor heros and should not be attempted by normal folks !
Also the indoor 3D fuselage builders are tall and handsome, stylish, whitty ..........
3D planes have DRAG which takes a little more power. They are goign to ahve smaller rudders and finsss if they are to look scale'ish. You have to put all the control parts inside which creates trouble. Its godda have some paint on it
But when its all done and the dam thing finally flies its a great buzz, no need for cocane
http://www.aeronutz.flyer.co.uk
aeronutz is offline Find More Posts by aeronutz
Old Jul 04, 2004, 02:09 PM
nanoflite is offline
Find More Posts by nanoflite
Belgium
Joined Jun 2004
Maybe this is some food for thought ...
Why do some people prefer wall-foam and some other others balsa? What are the benefits of the one against the other, and what does that mean for a 'pager-motor-plane'?
I prefer balsa, because it still is light and seems to have some more strength compared to foam. Also, for me, it is more easy to work with .... I can easily make a frame, cover it with thin sheet balsa (1mm or less) and sand it to get a nice curvature ...
Short, what is the best 'building' material?
Johan
nanoflite is offline Find More Posts by nanoflite
Old Jul 04, 2004, 02:44 PM
epilot is offline
Find More Posts by epilot
Remote island inhabitant
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
Tjena Johan
Look here to see why some of us use foam:
http://www.rcgroups.com/forums/showthread.php?t=118362
Michael
epilot is offline Find More Posts by epilot
Old Jul 04, 2004, 05:43 PM
jmquetin is offline
www.jmquetin.com
jmquetin's Avatar
Paris - France
Joined Aug 2003
<<Short, what is the best 'building' material?>>
I think the best material is the material you feel the most comfortable with to build a given model.
J.M.
Old Jul 04, 2004, 05:54 PM
LenBFP is offline
Find More Posts by LenBFP
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
Each material has it's strong and weak characteristics. The "best" material depends on the application. I use various kinds of foam and balsa, carbon fiber rods and tubes cloth and tape. I am just beginning to learn about the small stuff, but it is a very interesting aspect of modeling.
Len
LenBFP is offline Find More Posts by LenBFP
Old Jul 04, 2004, 06:09 PM
gbarc is offline
gbarc's Avatar
Joined Nov 2002
I use a variety of materials. But for quickness of build i use foam.(durovent from homedepot) For lightness(that being a relative term) 1/16 balsa and reynolds wrap is hard ta beat! Of course there's always carbon fiber(rods and such). To echo...it all depends on what you are comfortable with.
PAGER MOTOR PLANE-A plane whose locomotion is achieved by the means of a pager motor.(Webster-Greg )
Greg
Discussion How to build a SERIOUSLY small R/C plane Jaboi Scratchbuilt Indoor and Micro Models 9 May 14, 2007 05:10 PM
How To Reduce The Weight Of A 4mm Pager Motor... ALOT! TimayTheToolman Scratchbuilt Indoor and Micro Models 20 Jul 03, 2006 05:27 PM
Question How to mount 2508 on pager motor PlanesRcool Scratchbuilt Indoor and Micro Models 3 Mar 19, 2005 07:47 PM
Micro Pattern ~16.5g Pager Motor Plane Gordon Johnson Scratchbuilt Indoor and Micro Models 10 Nov 08, 2003 09:59 AM
Pager motor retract servo, how to build? JonB Scratchbuilt Indoor and Micro Models 1 Apr 04, 2002 01:29 AM
