Old Jul 02, 2004, 10:31 AM
Tony D. is offline
Find More Posts by Tony D.
Joined Nov 2002
Cross country glider using Drela airfoils.
I posted this at the Yahoo Allegro site as well:
I have been thinking of building a cross country ship for a while now
and I am planning on using the AG40 to AG43 series with a 4 or 4.5
metre span.
Carbon capped spar, Kevlar skin 4 tapers per side and a large cross
section fuselage I have drawn up.
Mark or anyone else care to comment on the suitability of these
sections for this task?
T.D.
Tony D. is offline Find More Posts by Tony D.
Old Jul 03, 2004, 01:46 PM
AustinTatious is online now
Find More Posts by AustinTatious
AustinTatious
AustinTatious's Avatar
Hurst, Texas, United States
Joined Jul 2003
only comment I can offer is that after flying a Drela airfoil, it is amazing how responsive it is to camber changes... It really moves out when you set it to reflex, but when you drop down to camber settings, it jsut turns into a whole new airplane and floats around.
Having never done X-c ... Take what I say now with a grain of salt.. I suspect that these airfoils would be a great choice.. you can thermal in camber settin to get max altitude as fast as possible before say the thermal burn s out.. then go to reflex and haul arse to the nex thermal, then repeat...
my .02
AustinTatious is online now Find More Posts by AustinTatious
Old Dec 08, 2004, 09:50 PM
steelhead is offline
Find More Posts by steelhead
TROUT OR THERMALS
steelhead's Avatar
Eureka, Ca
Joined Sep 2002
So far, I've learned a few hundred things about XC airfoils. Out of 100 pilots, there are 100 different choices. Everyone learns to fly a specific way, and you need to match your airfoil/wingloading to your flying style.
One paper says stay away from traditional sailplane airfoils- E205, S3021, etc and go with S6060, Rg15 others say go with thickend E205's for floatability.
Some say dont go for anything that is considered "unproven" makes me wonder who decides to jump off and test the untested Go ahead- make the tests- lket us know how it turns out- maybe we'll all be flying drelas next year
Dean
steelhead is offline Find More Posts by steelhead
Old Dec 09, 2004, 08:32 AM
Robglover is offline
Find More Posts by Robglover
LSF V,LSF Secretary,AMA Lifer
Robglover's Avatar
Huntsville
Joined Oct 2003
The Drela foils sound interesting for XC, but I'd look at them a bit first.
They are optimized for very lightly loaded planes, which may not be appropriate for XC. I've flown XC with light planes, and they can work if you aren't in a hurry and there isn't any wind, but going to higher wing loadings is much more stylish these days.
Drela foils are typically optimized for a particular Reynolds number, some of his best are aimed at very low Reynolds numbers. XC airfoils operate at higher Reynolds numbers.
They are very thin - the spar doesn't have much depth, meaning that you will have to be very careful to get the spar strength to handle 150 inches of span.
All that being said, I'd probably ping Dr. Drela and see if he might be interested in collaborating on an XC design. Actually, I'd try and talk him into doing the whole thing, but be happy to take whatever he was willing to do.
You should also keep in mind that XC is probably the best test of piloting skills that exist in RC soaring. It ain't the plane, it's the pilot. The worlds record holder and pretty much the undisputed king of XC is Joe Wurts. He likes a "big dumb airplane".
On the other hand, there aren't many XC designs out there - should be room for improvement!
happy trails - Rob
Robglover is offline Find More Posts by Robglover
Old Dec 09, 2004, 09:51 AM
DLD is offline
DLD
Find More Posts by DLD
DLD
David Layne
Tracy, Ca
Joined Jun 2004
Xc
Having flown some XC, I would agree with Rob, you need to go for airfoils suited to higher Reynolds numbers and thick enough to give the spar strength needed for a large span aircraft. My personal favorites are the Quabeck airfoils, they were designed for camber changing and have a very wide speed range. I would use a 1.5% camber, 9-10% thick at the root and transition it to about 75 thickness at the tip with maybe 2-2.5% camber. This would give you the speed you need, but with camber changing it will thermal quite well. At the higher Reynolds numbers that these large, heavy models fly, high cambered airfoils are not necessary or even desirable. They will slow you down when you need to step out and go fast. It's not unusual to be chasing you plane at 60-80mph.
David Layne
DLD is offline Find More Posts by DLD
Old Dec 09, 2004, 11:09 AM
Robglover's Avatar
Huntsville
Joined Oct 2003
David knows the Quabeck pretty well. He was the manufacturer of the Saturn series of planes a few years ago, they did quite well with the Quabeck airfoil. I can remember him launching and zooming forever with them.
His numbers sound like a good cut at the 'foil, although I'm pretty sure he means 7.5% thickness at the tip.
There are a couple schools f thought on camber changing. One school likes the camber changing profiles, with flaps and ailerons. SBXC is the prime example.
The other school likes the "big dumb plane" approach. Basically a very large Gentle Lady. Poly birds are typically easier to see and more stable. If you do actually fly cross country the plane sometimes gets to fly itself while it disappears behind treelines or into clouds.
The airfoil would be different for each of these approaches. After having had a few cross country planes of both styles I've come to the conclusion that there is a lot to be said for simplicity.
happy trails - Rob
Old Dec 09, 2004, 12:00 PM
ChuckA is offline
Find More Posts by ChuckA
Tennessee
Joined Sep 2003
It's been a long time since I last flew cross country but one thing I do remember. Speed greater than you can drive is useless. I remember dropping flaps to slow the model down to the maximum speed we could drive on the back roads used for the course.
ChuckA is offline Find More Posts by ChuckA
Old Dec 11, 2004, 08:51 AM
Lance Prior is offline
Find More Posts by Lance Prior
Salt Lake City, Utah
Joined Nov 2004
8% is pretty thin!
Lance Prior is offline Find More Posts by Lance Prior
Old Dec 11, 2004, 12:18 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
How about upwind?
Sparky Paul is offline Find More Posts by Sparky Paul
Old Dec 13, 2004, 08:47 AM
Ollie is offline
Find More Posts by Ollie
Punta Gorda, FL
Joined Apr 2002
A Dr. Drela 'Ne "Supra" Ultra' ( 25% linears, 100 Dia. pod and low Wt. 50% and ballast 4.5 lead). It would be very nice for a cross country plane.
Ollie is offline Find More Posts by Ollie
Old Dec 14, 2004, 02:06 PM
Tony D. is offline
Joined Nov 2002
Exaclty what I was thinking Ollie, something along the lines of a scaled up Supra.
Rob and David,
I've built a few wings with the Drela airfoils from 60" to 132" on my own designs and they respond to camber extremely well and excel in just about any conditions, one interesting thing is that they also respond well to ballast. I think a CC ship using these airfoils will be an excellent bet.
With a properly designed carbon capped spar the 8% thickness is not really a worry.
I thought about using the HQ2.5/9 - 2.5/8.5 - 2.5/8 which I like a lot but the Drela sections have been so good to me that i think I will stick with them.
T.D.
Using different airfoils from root to tip on glider wing. HaiDang Modeling Science 3 Feb 14, 2005 06:59 AM
Electric-Powered Cross-Country Glider ShredAir Electric Sailplanes 16 Jan 09, 2005 02:00 AM
Electric Glider for 30 mile cross country fun race dawsonh Electric Sailplanes 2 Jun 18, 2004 12:34 PM
Washout required when using Drela airfoils? Yochim Thermal 5 Sep 19, 2003 01:47 PM
Cross Country Flying MMangus Electric Plane Talk 3 Mar 07, 2002 06:29 PM
