Old Jan 19, 2002, 08:34 AM
jayboy is offline
Find More Posts by jayboy
Mad Scientist
jayboy's Avatar
South west, Va
Joined Nov 2001
Litestik questions for a New Stik owner =)
Hey guys i finnaly got me a stick I have a few simple questions for anyone who can help me out.
1 Would it be better to do the diehdral mod on the wing first or try it as it is? I have flown before but not a whole lot.
2 where should the CG be? I have the instructions but sometimes people find the plane does better with a diffrent CG.
3 Where is the best place to get replacement parts, I plan on getting at least one motor and a few props so that i have them just in case.
4 I have a few 9 volt rayovac batteries, How many do you guys use together to fly the stik?
5 I also have some batteries for my Megatech skyliner will these work in the stik? Here is the URL to the plane i have along with the battery http://megatech.com/Skyliner%20RTF.html#
The batteries that i have are diffrent than the picture, The Packs I have are 7 cell and the cells are actually shorter than the AA and a tad bit fatter. Not sure what they are called LOL
Thanks for helping me out, I am getting ready to get a radio and rec as soon as i can find the best deal, so if you know of a good cheap place to get these let me know =)
thanks so much
Jay
jayboy is offline Find More Posts by jayboy
Old Jan 19, 2002, 09:34 AM
VWtechie is offline
Find More Posts by VWtechie
Columbia, MO USA
Joined Feb 2001
Many LS's fly fine without the dihedral mod so I think you should try it without it. The instructions list the CG at 6cm back from the leading edge and that worked fine for me. Start there and experiment moving it forward and backward a mm at a time until you find how you want it to handle. Some people fly with 1 Ray-O-Vac but I found it has better performance if you use two wired in parallel. Make sure to cycle the 9V's 4 or 5 times before you try to fly it or you will be disappointed. The Megatech battery is too heavy for a LS. I try to use 300mAh NiCd's or smaller. Anything heavier and it doesn't want to climb.
VWtechie is offline Find More Posts by VWtechie
Old Jan 19, 2002, 09:49 AM
Majortomski is offline
Find More Posts by Majortomski
dusty bible = dirty life
Majortomski's Avatar
Oklahoma City OK USA Where fakts still exist even if they are ignored
Joined Aug 2000
What he said. mine worked just fine completely stock. After a year I've moved up to the 8 cell pack, a heat sink and the smaller diameter prop from the tiger moth. In a year of rough flying I've never broken a prop. the motor has held out quite well. My major broken parts were the big batter holder thingie broke at the front support. and i broke an aft wing holder right at the base when trying a baloon poping contest, the baloon won
If you snoop around the posts you will see some folks dispence with GWS' plastic parts altogether. but try it stok firist
Majortomski is offline Find More Posts by Majortomski
Discussion TTe Questions for new motorcycle BOZINATOR Motorcycles 29 Mar 19, 2006 11:01 PM
Discussion Slow Stick Questions for a new guy. Rimfire on a slow stick? Bmr4life Parkflyers 1 Feb 23, 2006 10:42 PM
A Couple Of Quick Questions For A New Beginner phil_013 Foamies (Kits) 3 Jan 16, 2004 12:18 AM
A Couple Of Questions For A New Beginner phil_013 Parkflyers 1 Jan 15, 2004 08:05 PM
Best wing joining method for new Stik FD?? WrongwayFeldman Parkflyers 10 Jul 24, 2002 04:57 AM
