Old Jul 01, 2004, 06:56 AM
dpoles is offline
Find More Posts by dpoles
Crash and Build
dpoles's Avatar
United States, NY, Ithaca
Joined Oct 2001
Smoothie Maiden and Mixing question
Well, I finally maidened my Smoothie last night.
Razor 400
GWS C box
APC 10x7
8 cell 950 Kans
I think this is the first straight plane I have ever built. The result being the first maiden without any drama!
I haven't flown since last Sept. so my knees were knocking. Guess it's like a bike though, it just climbed right out, straight and true. Easy circuits. Effortless loops and benign stalls. It is my new favorite plane. Just the right blend of stability and performance for my current skill level. I love this plane. The only thing I struggled with was the landing, it just kept gliding and didn't want to slow down. I kept going round and round and starting further out!
My question, I have a fancy new computer radio, don't know how I lived without model memories! Should I mix some rudder in with the ailerons to fix my crabbing turns? How much? Any other channels to mix?
thanks MM
D
dpoles is offline Find More Posts by dpoles
Old Jul 01, 2004, 09:05 AM
NeuronBasher is offline
Find More Posts by NeuronBasher
Mark Imbriaco
Chesapeake, VA
Joined Apr 2003
I can't answer your question, but I just wanted to comment that that's a great looking SmoothE. Is that wing covered in tape or Solite?
-Mark
NeuronBasher is offline Find More Posts by NeuronBasher
Old Jul 01, 2004, 09:20 AM
dpoles is offline
Crash and Build
dpoles's Avatar
Joined Oct 2001
all solite, lots of strapping tape underneath on the wing.
If I were doing it again I would sand the wing before covering.
Old Jul 01, 2004, 11:10 AM
WSEN is offline
Find More Posts by WSEN
McCarthy, Alaska
Joined Jun 2004
I used quite a bit of mixing on my SmoothE (aileron-rudder) and it helps a lot as far as co-ordinated turns.
Rick
WSEN is offline Find More Posts by WSEN
Old Jul 01, 2004, 11:15 AM
dpoles is offline
Crash and Build
dpoles's Avatar
Joined Oct 2001
Rick
I have never used mixing before, so I have no idea if "quite a bit" is 10% or 90%?
Old Jul 01, 2004, 01:05 PM
SKYPILEIT is offline
Find More Posts by SKYPILEIT
Minekraft & RCG for me
SKYPILEIT's Avatar
Novi, Michigan
Joined Nov 2002
Smooth-E...very sharp..!!
dpoles,I think you could experiment when turning just add a bit of rudder input and go from there...maybe start with 20% rudder/aileron mix....you re using the exact same motor/GB I am using for my Smooth-E (except batts)and I can't help wonder..did you build the sport version and what is the all up weight..??Thanks..
SKYPILEIT is offline Find More Posts by SKYPILEIT
Old Jul 01, 2004, 02:07 PM
WSEN is offline
McCarthy, Alaska
Joined Jun 2004
dpoles,
I started with 25% and worked up. Now I have 75% and it it not too much.
Rick
dpoles is offline
Crash and Build
dpoles's Avatar
Joined Oct 2001
thanks!!
50 minute maiden, Li question. DeaninMilwaukee Batteries and Chargers 0 Jul 13, 2003 09:04 AM
8UHS Mixing question LJH Radios 0 Nov 27, 2002 01:18 PM
CM Rudder Aileron Mixing Question HavingFun2002 Parkflyers 15 Apr 21, 2002 09:42 AM
CM Rudder Aileron Mixing Question HavingFun2002 Beginner Training Area (Aircraft-Electric) 15 Apr 19, 2002 02:09 PM
Pleaser 3 Mixing Question Mel Duval Parkflyers 2 Jul 21, 2001 09:44 PM
