Old Feb 24, 2004, 09:30 PM
Uttam1 is offline
Find More Posts by Uttam1
Micro Brushless crazy
Uttam1's Avatar
India, Bangalore
Joined Jul 2002
Nice work Billy! I seem to have a funny problem with my programmed ( JDM ), I tried burning Koichi's TX code onto the PIC 12c509A, it tok ages, and then said verify failed at address 000h! The device was blank before writing. I then tried a 16f84, and it wrote the code perfectly! My OS is Windowz XP Professional, I use IC-Prog to interface with the programmer, does anyone know what's happening, or has anyone else had such problems?
Thanks,-Uttam
Uttam1 is offline Find More Posts by Uttam1
Old Feb 24, 2004, 09:46 PM
joe price is offline
Find More Posts by joe price
Peotone,Il USA
Joined Oct 2000
Try your chip it may work, I had this
problem and was told by someone on list
to go to hardware interface under ic-prog
and select API rather than Direct IO.
this worked for me.
joe price is offline Find More Posts by joe price
Old Feb 24, 2004, 11:21 PM
billystiltner is offline
Find More Posts by billystiltner
billystiltner's Avatar
United States, VA, Clintwood
Joined Nov 2002
Uttam Pat and Rick
Thanks I was just seeing if I could drill a hole in some 26AWG copper wire I had the idea I could make some really lightweight homemade plugs.
Uttam
I have had the same thing happen when programming RXs. When I got the address failed at 000h error I checked my connection from PIC pins to the pins on the JDM programmer most of the time it was a bad connection. Another thing you might want to check is your zener diodes. I replaced my diodes with ones that came off the shelf at Radio Shack. If you do have a good connection with your PIC to DIP adapter and the chip doesnt work when you plug it into the TX and you have replaced the zeners then you might also want to check your transistors hfe. But as Joe says it may work fine.
Has anyone built a working JDM programmer with the zener diodes on the Digikey partslist?
Allthough I may have messed up my Digikey diodes when I had the pins wrong on the transistors.
Billy
billystiltner is offline Find More Posts by billystiltner
Old Feb 24, 2004, 11:59 PM
Koichi Tanaka is offline
Find More Posts by Koichi Tanaka
Koichi Tanaka's Avatar
Japan
Joined Dec 2002
Uttam,
It seems that writing may not be exactly made depending on the kind of PIC unless the power supply supply to a JDM programmer from PC is enough. Supposing you use the cable for the connection with a writer from PC, please remove the cable and use direct, connecting a writer to PC. A good result may be obtained.
Koichi
Koichi Tanaka is offline Find More Posts by Koichi Tanaka
Old Feb 25, 2004, 12:40 AM
JMP_blackfoot is offline
Find More Posts by JMP_blackfoot
JMP_blackfoot's Avatar
United States, OH, Galena
Joined Jul 2003
One little trick I use for my prototypes :
Solder the piece of wire first on the side where it will be under a component.
Then put the PCB on a piece of glass, and solder the wire on the other side, while keeping the PCB flat against the glass. In this manner, the solder will melt also on the bottom side and be flattened to the thickness of the wire. No need to file down. Of course, always use a clean and sharpened iron tip and the very minimum amount of solder. Tinning the whole PCB beforehand, then removing the solder with solder wick helps a good job, as well as pretinning the wire used for through holes. Works for me
JMP_blackfoot is offline Find More Posts by JMP_blackfoot
Old Feb 25, 2004, 02:28 AM
JohnnyB is offline
Find More Posts by JohnnyB
UK
Joined Jan 2004
Dud diodes, a quick and dirty check
Billy,
You may already know this.
A crude method of testing diodes is to test forward and reverse resistance using a multimeter. With my analogue meter it can usually drive the diode when in the forward conduction mode, but shows no conduction when the connection to diode is reversed. When you considered the polarity of transistors you can use the method check the bipolar types as well.
Cheers,
Johnny
JohnnyB is offline Find More Posts by JohnnyB
Old Feb 25, 2004, 10:42 AM
Uttam1 is offline
Uttam1's Avatar
India, Bangalore
Joined Jul 2002
Joe, Billy, Koichi, Thanks for all your inputs. There seemed to be a bug with the IC-Prog I had installed. I downloaded a different version, it's working fine, and guess what, all the pics I wrote are fine Good excuse to build more IR units, eh?
I'm going to start work on the RX now. Got a couple of small sensors, but the leads are more or less at the rear surface of the detector ( Offset to the rear ), dunno how I'll sand them. Do the sensors with the "oval" globe work at wider ranges than the spherical globes?
-Thanks,
Uttam
Old Feb 25, 2004, 08:34 PM
Japan
Joined Dec 2002
Uttam,
It is unsuitable when it carries the sensor of an oval lens, and a spherical sensor in an indoor plane. The infrared light of the large range is receivable by shaving off a lens.
Koichi
Old Feb 25, 2004, 09:25 PM
Uttam1 is offline
Uttam1's Avatar
India, Bangalore
Joined Jul 2002
Thanks Koichi, Prashanth had mentioned this, I thought he was joking I just tested the DIP RX and TX, all working fine!
-Uttam
Old Feb 26, 2004, 09:35 AM
gbarc is offline
Find More Posts by gbarc
gbarc's Avatar
Jackson, Michigan, United States
Joined Nov 2002
Another IR/RX
Here's a drawing of a IR/RX based on the Z-Tron system. I have the old system and started playing and came up with this cleaned up version of the frankenstein system i have. It has a really low part count and should be suitable for really light weight flyers.
Currently i'm using the Z-Tron TX and original PIC's Once i learn how to program a PIC i'll really start rockin!
Greg
gbarc is offline Find More Posts by gbarc
Old Feb 26, 2004, 10:56 PM
Joined Nov 2002
Uttam
Be careful when sanding the back of the oval sensor.
I sanded mine as close as the Panasonic sensor and it broke when I was grinding the legs. Maybe grind the legs firstr and connect your wires then leave about .3mm on the back and only sand it to .15mm thick total. This is asuming you can sand it as thin as the Panasonic sensors.
gbarc
Thanks for the schematics.
Billy
Old Feb 27, 2004, 12:14 AM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
Greg,
you should add a Schottky diode at the motor terminals, and perhaps also a capacitor.
Regards, Jochen
jberg is offline Find More Posts by jberg
Old Feb 27, 2004, 08:57 AM
gbarc is offline
gbarc's Avatar
Joined Nov 2002
Jberg,
Yep, your right i forgot to add the cap betwwen the sensor leads.
Billy,
No problem
Greg
Old Feb 27, 2004, 09:07 AM
Japan
Joined Dec 2002
Super lightweight IR RX
The 3 channel receiver containing a sensor is only 0.25g!
sensor:0.09g
board:0.16g
Koichi
Old Feb 27, 2004, 09:09 AM
gbarc is offline
gbarc's Avatar
Joined Nov 2002
Updated Scematic
I've updated the schematic with the CAP added between sensor leads.
Greg
airwars "infra-red combat system for planes" Tree_Magnet Power Systems 15 Jan 08, 2008 09:41 PM
Discussion DIY conversion to infra red Tom Harper Aerial Photography 46 Jun 25, 2006 05:43 PM
Infra-Red Thermometer for Helis rscamp Electric Heli Talk 7 Jan 08, 2002 06:11 AM
airwars "infra-red combat system for planes" Tree_Magnet Foamies (Kits) 4 Aug 02, 2001 12:15 AM
Infra red transmitter and receiver for micro size aircraft Ron MIller Power Systems 2 May 28, 2001 09:51 AM
