Old Apr 21, 2003, 11:34 PM
Koichi Tanaka is offline
Find More Posts by Koichi Tanaka
Koichi Tanaka's Avatar
Japan
Joined Dec 2002
Airplane "Push-E" made newly was flown with 3-channel IR receiver.
The 60-ohm coil used for "Push-E" was rolled by hand. The coil is driven by the operational amplifier.
Two IR sensors were set to right and left of the fuselage.
Koichi Tanaka is offline Find More Posts by Koichi Tanaka
Old Apr 27, 2003, 01:10 PM
gbarc is offline
Find More Posts by gbarc
gbarc's Avatar
Jackson, Michigan, United States
Joined Nov 2002
simple plans
Could somebody send my a copy of some simple schematics for a ir tx and rx? i want to build a simple two channel system to control rudder and throttle. i have some idea on how it should work but need a "push" in the right direction.
thanks-Greg
gbarc is offline Find More Posts by gbarc
Old Apr 27, 2003, 01:13 PM
gbarc is offline
gbarc's Avatar
Joined Nov 2002
forgot to post my email address-MREMALE4U@YAHOO.COM
Old Apr 28, 2003, 07:22 PM
jcatron is offline
Find More Posts by jcatron
Joined Dec 2001
Great Thread!
Any suggestions on how to use Koichi's setup without a Tx that has a buddy cord or a buddy box? (All I have is a Focus 3ss from Hitec).
I have built severa IR circuits not having to do with RC, and would like to build somthing similar to the Z-tron system.
Thanks!
jcatron is offline Find More Posts by jcatron
Old May 11, 2003, 06:20 PM
jberg is offline
Find More Posts by jberg
jberg's Avatar
MSC Rödinghausen, Germany
Joined Feb 2001
Hi all,
I tried my IR system outside today. In bright sunlight at noon it was totally unusable, as expected. The range was about 5m.
After sunset things changed dramatically: We had a calm evening, and I was able to fly around my neighbourhood with my 20g "Phoenix Mite". I have used only one sensor in original shape (with the moulded lens) and pointing downwards. There were short glitches when I made tight turns far away because then the sensor was looking away from me, but otherwise the model was quite controllable as long as I pointed the TX box towards the model. The range was about 25m which is enough for a model this small and slow.
Regards, Jochen
jberg is offline Find More Posts by jberg
Old May 12, 2003, 01:48 AM
j8m8l is offline
Find More Posts by j8m8l
Thats NOT indestructible
j8m8l's Avatar
London UK
Joined Apr 2002
That is fantastic to hear Jochen. I may have to try out my Z-tron outside !.
I am doing D&T (Design and Technology) next year, and have decided on my project...
...i am making a DIY IR system, and putting it on a living room flyer. Cant wait till the summer holiday is over! LOL. The teacher was very interested too (he used to work for one of the helicopter companies over here).
Josh
j8m8l is offline Find More Posts by j8m8l
Old May 26, 2003, 03:05 PM
joe price is offline
Find More Posts by joe price
Peotone,Il USA
Joined Oct 2000
After reading Jochen's post and finally
getting a calm evening I tried my IR system
outside also using two sensors back to back
with 48 emitters on tx, I couldn't tell much
difference between IR or radio system worked
ok in backyard so I tried in the front was able
to ROG from driveway and fly across the street.
Im not sure what range I have will continue to
experiment.
joe price is offline Find More Posts by joe price
Old May 27, 2003, 04:45 PM
Trikster is offline
Find More Posts by Trikster
Zoom, zoom...
Trikster's Avatar
Roseville, CA (Sacramento area)
Joined May 2003
I just stumbled on this link. If you scroll to the bottom, they are using IR and 2 motors. The motors steer the plane and I assume the speed of the motors governs altitude.
http://www.aeronutz.flyer.co.uk/twins.html
Trikster is offline Find More Posts by Trikster
Old Jun 08, 2003, 05:07 PM
Peotone,Il USA
Joined Oct 2000
Any chance one of you software guru's could write
code for 12c509's to allow differentail steering as used in above thread?
Old Jun 08, 2003, 05:40 PM
aeronutz is offline
Find More Posts by aeronutz
Leicester England
Joined Jun 2001
Twin motor steering
Joe, you can just buy the twin steer Rx kit if you want to you know?
Its small and fiddley so I usually make them up for folks
I can't remember the price but its about $30 for two Esc, the Rx and two sensors
It is proportional, weighs about 2g on a ciruit board, dies at about 2.8v, each Esc can handle one amp.
Sergio just sent me a new batch and these have an output for retracts too so a B25 or B17 is not far off ..........
Anyone got any Z Tron mk 3 transmitters for sale ?
Sergio told me he sold about 500 kits so there must be lots of them somewhere in the world?
Mark
I was making a P38j this afternoon but that was for two capacitors F/F.
aeronutz is offline Find More Posts by aeronutz
Old Jun 30, 2003, 10:17 PM
Japan
Joined Dec 2002
The palm-size infrared transmitter was made using the joy stick supplied from DIDEL.
It decomposed and joystick was converted into the mode 1.
It is compatible with a Futaba transmitter.
38kHz and 56.9kHz are switched.
Assembler sauce is exhibited by my homepage.
http://www.cityfujisawa.ne.jp/~toko/pic/
Old Jul 04, 2003, 03:19 AM
Prashanth is offline
Find More Posts by Prashanth
Bangalore Hindustan, India
Joined Apr 2003
Could all you infrared gurus pleas help me.... I dont understand japanese and the altvista translation is of no use.
I need the schematic of a simple 3 channel ir TX and RX and the codes for the pic chip
I cant wait to put the thistle on ir
thanx to all in advance
Prashanth is offline Find More Posts by Prashanth
Old Aug 25, 2003, 07:21 AM
Japan
Joined Dec 2002
The rubber power indoor plane which carried the infrared control system first flew.
air frame:4.45g
rubber: 2g
IR control system: 1.55g (Battery 0.84g + RX 0.465g + Actuator coil 0.14g + Magnet 1.035g)
Flight weight is 8g.
The airplane flew so that it might drift very slowly, and its control was also enough.
Seven sets of simultaneous flights are possible for this infrared control system.
Old Aug 25, 2003, 08:36 AM
moto is offline
Find More Posts by moto
Zama city, Kanagawa, Japan
Joined Dec 2002
Kohichi, very impressed flight !
I think it came from nice collaboration of professionalism between R/C slowflyer and Indoor rubber FFer.
Fantastic RX and F/F plane were combined now !
moto is offline Find More Posts by moto
Old Aug 25, 2003, 08:46 AM
david_dewit is offline
Find More Posts by david_dewit
Australia
Joined Sep 2001
Very nice work Koichi, what is duration.
Dave
david_dewit is offline Find More Posts by david_dewit
airwars "infra-red combat system for planes" Tree_Magnet Power Systems 15 Jan 08, 2008 09:41 PM
Discussion DIY conversion to infra red Tom Harper Aerial Photography 46 Jun 25, 2006 05:43 PM
Infra-Red Thermometer for Helis rscamp Electric Heli Talk 7 Jan 08, 2002 06:11 AM
airwars "infra-red combat system for planes" Tree_Magnet Foamies (Kits) 4 Aug 02, 2001 12:15 AM
Infra red transmitter and receiver for micro size aircraft Ron MIller Power Systems 2 May 28, 2001 09:51 AM
