Jun 30, 2004, 10:51 AM
Joined Oct 2001
Why? Because your flight pack has more than 10 cells in it. The built in BECs in most speed controls can't handle more than 10-cell packs because the voltage difference is too great. BECs reduce the pack voltage to 5 Volts for the receover and servos by turning the excess energy into heat. As the difference between pack voltage and 5 Volts gets greater, the BEC has to generate more heat. Something's got to give at some point, and the point is 10 cells on most ESCs.
Since you're running 12 cells, there's no point in buying a speed control with a built-in BEC, so you may as well get an OPTO speed control and an SBEC.
An OPTO electronic speed control is optically isolated, meaning that there is no direct electrical connection from the receiver to the ESC for the control signal. It passes through a gizmo that translates the electrical signal from the receiver into light, shoots it across the gizmo, then translates it back into an electrical signal on the other side. Electronic interference cannot pass down the signal wire to the receiver. Isolating the receiver from the speed control this way can be important on higher-power applications.
The SBEC is a "switching" battery elminator circuit. Built-in BECs are of the "linear" type, meaning they expend excess energy as heat. A switching BEC simply switches the power on and off very rapidly at regular intervals to simulate a lower voltage. This is the exact same way an electronic speed control works to simulate lower throttle levels. A switching BEC can theoretically handle any number of cells. You don't see switching BECs built into speed controls because they're relatively expensive (raises the price of the speed control and makes it less attractive to the typical R/C consumer who is only looking for the cheapest price), and they're relatively bulky (compared to the tiny chip linear BECs that you'd be hard-pressed to locate on a speed control).
