Old Jun 30, 2004, 09:57 AM
AP WannaBe is offline
Find More Posts by AP WannaBe
Joined Apr 2004
Help a Newbie Girl Understand OPTO ESC & S-BEC? Pics Attached
Hello All,
Aircraft World is recommending an OPTO ESC and an S-BEC for my:
1. 104" Flying Wing
2. 12-cell Sub-C pack
3. AXI 2820-12
4. 4 Standard Full-Sized Servos for Flight Control, plus 1 for Steerable Nose Gear, plus 1 for triggering Camera Shutter.
Why go OPTO and S-BEC?
What IS OPTO?
How do OPTO ESC's and S-BEC's connect into the Radio/Power System?
Attached are the specs of my Flying Wing and a pic of Ming with a similar Electric setup on the same Flying Wing.
Thank you for the benefit of your experience to this very INexperienced, but very enthusiastic Newbie,
Julie ;o)
AP WannaBe is offline Find More Posts by AP WannaBe
Old Jun 30, 2004, 11:39 AM
mmormota is offline
Find More Posts by mmormota
mmormota's Avatar
Budapest
Joined Jul 2003
The reasson of the S-BEC: there are 12 cells, the battery voltage is higher then average, about 15V. The usual built-en BEC in a controller is a simple analog stabilisator. The BEC makes 5V from the 15V battery. The more the battery voltage above 5V, the more the heating power on the stabilisator. There are 4 servos, a high Amps load in combination with high battery voltage is too much for a usual analog stabilizator.
Opto means that the receiver input is opticallu isolated, but in the rc scene it means that "no BEC in the motor controller" too.
The S-BEC is a switching mode power supply, it is not dissipating so much power, but converts the battery voltage to the 5 or 6V for the servos in amuch more efficient way.
mmormota is offline Find More Posts by mmormota
Old Jun 30, 2004, 11:45 AM
mmormota is offline
mmormota's Avatar
Budapest
Joined Jul 2003
Using the S-BEC, take a look to the datasheet:
http://www.aircraft-world.com/prod_d...sbec/s-bec.htm
Here is the connection diagram (if there is no battery connector on your receiver, you should connect it to a not used channel too, if there is no free channel, use a Y cable... ) :
Old Jul 01, 2004, 09:03 AM
Joined Apr 2004
Thank You So Much . . .
. . . for the benefit of your experience and knowledge. I now have a very good understanding of WHY I need an OPTO ESC and S-BEC as well as how they work and how they connect into they system.
Thanks again!
Julie ;o)
For Sale 2 new dynam 70 amp opto esc's (no bec) yucafrita Aircraft - Electric - Power Systems (FS/W) 2 Aug 15, 2007 09:38 AM
Help a Newbie Girl Understand OPTO ESC & S-BEC? Pics Attached AP WannaBe Power Systems 3 Jul 01, 2004 09:04 AM
Help A Newbie Girl Out? Sources for Components? Pics of 100" Flying Wing AP WannaBe Power Systems 16 Jun 04, 2004 11:45 AM
UBEC, ESC's BEC, Rx Pack in your Heli? JKos Electric Heli Talk 8 Sep 06, 2003 12:09 PM
ESC's BEC cut out RiBell Power Systems 20 Aug 10, 2003 06:33 PM
