Old Jun 29, 2004, 02:09 AM
Eljimb0 is offline
Find More Posts by Eljimb0
ni'ihau
Joined Nov 2003
Idea
contra rotating prop brushless
I had this great idea this afternoon. and it works
Eljimb0 is offline Find More Posts by Eljimb0
Reply With Quote  (Disabled)
Old Jun 29, 2004, 02:18 AM
Eljimb0 is offline
ni'ihau
Joined Nov 2003
The drive shaft for the back rotor is inside the front rotors prop. I found a pair of opposite pitch props as a replacement part for one of those aero wanker birds with two motors. ONE cc phoenix 10 drives both motors.
Both motors start about 1/2 the time the other half one or the other starts only. It makes a wonderfull sound. I don't know how to read the prop rpm?
do I set the tach for 4 blades or 2. It rips all the way to WOT.
jimbo
Old Jun 29, 2004, 02:24 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
wow
That looks great you have to do an in depth on the build ,ive had a play with back to backs and 2 on a common shaft but that a great inovative application just think no torque reaction no fuz twist and the dreaded wing tuck under. are they standard winds? some motor tests would be great also.
olmod is offline Find More Posts by olmod
Old Jun 29, 2004, 02:37 AM
ed_khan is offline
Find More Posts by ed_khan
ed_khan's Avatar
USA, WA, Bellevue
Joined Dec 2002
It actually works
Please do post some more pics, especially how the two shafts tie up!
Goof luck
ed_khan is offline Find More Posts by ed_khan
Old Jun 29, 2004, 02:45 AM
Eljimb0 is offline
ni'ihau
Joined Nov 2003
The motors are from mini disc players (17mm. dia stator) For the sake of simplicity and speed I used the stock winds on the motors (I knew they would be the same).I cut the aluminum mount up and ca glued it to the back of another
Mats is offline
Find More Posts by Mats
Mats's Avatar
Trollhattan, Sweden.
Joined Oct 2002
T(w)ooCool! *all thumbs up*
Mats is offline Find More Posts by Mats
Old Jun 29, 2004, 02:55 AM
Eljimb0 is offline
ni'ihau
Joined Nov 2003
this is how the drive shaft works
WimH is offline
Find More Posts by WimH
WimH's Avatar
Belgium, Flemish Region, Oosterzele
Joined Dec 2001
This is one I saw @ Aspach 2002:
WimH is offline Find More Posts by WimH
Old Jun 29, 2004, 04:50 AM
CANTZ506 is offline
Find More Posts by CANTZ506
CANTZ506's Avatar
Brescia, Italy
Joined May 2004
Very good job jimb0!
Have I any chance to find a slow flyer inverted pitch prop somewhere? I'm thinking about a twin, with counter rotating engines, but I've never seen an inverted pitch prop in any catalogue.
Thanks, Piero.
CANTZ506 is offline Find More Posts by CANTZ506
Old Jun 29, 2004, 05:47 AM
olmod is offline
olmod's Avatar
Joined Apr 2004
Jimbo
How about a black line on the rear drum to get the RPM ? mmm could fit one into a delta pusher , was there any make and model number on the units you salvaged ? is there an optimum distance between the props ? I wonder if it related to the air foil of the props. you got my attention
Old Jun 29, 2004, 07:06 AM
Petri Nygren is offline
Find More Posts by Petri Nygren
Senior Member
Finland
Joined Feb 2001
jimbo
Thumbs up to your efforts! Highly interesting.
If I may suggest further tests, it would be interesting if you could hook up another cc phoenix 10 and measure how much less current the rear motor draws in %. Then you could vary the speed of motors to see how much difference you need to cancel out all the torque -I would think holding a mounting in a hand (safely!) would tell you by feeling if there is a a measurable difference. Static thrust tests would be interesting as well -compared against the thrust by only one motor running.
RPM measurement: set you tach to 4 blades, it gives you the rpm of each motor (4 blade result multiplied by two divided by two). Since they run out of one ESC, the rpm is synchronized but current must be different.
Petri Nygren is offline Find More Posts by Petri Nygren
Old Jun 29, 2004, 08:38 AM
Art Newland is offline
Find More Posts by Art Newland
CD-ROM Junkie
Art Newland's Avatar
United States, WA, Bellingham
Joined Apr 2001
That's awesome Jimbo,
I like the way you think! Must be a common thing to banjo pickers!
Art Newland is offline Find More Posts by Art Newland
Old Jun 29, 2004, 08:44 AM
Robert May is offline
Find More Posts by Robert May
Joined Apr 2002
jimbo
??? Tried Googling, what are they?
Robert May is offline Find More Posts by Robert May
Old Jun 29, 2004, 02:16 PM
Eljimb0 is offline
ni'ihau
Joined Nov 2003
aero wanker birds ;
Hobby Zone- "firebird outlaw"
two props 4X4? $2.50 US. Part number HBZ 4540 Horizon Hobby
jimbo
Old Jun 29, 2004, 02:41 PM
Eljimb0 is offline
ni'ihau
Joined Nov 2003
Thanks for the compliments all.
"If I may suggest further tests, it would be interesting if you could hook up another cc phoenix 10 and measure how much less current the rear motor draws in %. Then you could vary the speed of motors to see how much difference you need to cancel out all the torque -I would think holding a mounting in a hand (safely!) would tell you by feeling if there is a a measurable difference. Static thrust tests would be interesting as well -compared against the thrust by only one motor running."
Peter
I will do a bunch of test on this thing after I get some sleep. The project from idea to product took about 10 hours most of that time should have been spent "counting sheep" .
With regards to RPM; because the props blades cross each other 4 times per
cycle the tach numbers wouldn't hold still. I figured it out at 10,000 rpm WOT
Question Contra-rotating vs. single prop? stangrob Power Systems 7 Nov 21, 2006 08:44 PM
Contra-rotating prop units? Angelo Scale Kit/Scratch Built 2 Feb 19, 2005 06:35 PM
Counter-rotating prop? f2racer Electric Plane Talk 1 Sep 01, 2002 08:00 AM
Rotating Can Brushless Motors bps Electric Heli Talk 4 May 30, 2002 06:31 PM
contra rotating blades help........pls! Devilfreak Electric Heli Talk 5 May 13, 2002 01:01 AM
