Old May 29, 2001, 07:24 PM
adamkhwaja is offline
Find More Posts by adamkhwaja
Singapore
Joined May 2001
Help in trimming the plane
Greetings,
Whenever my instructor takes off the trainer, he trims the plane so that it achieves level flight before he hands over the transmitter to me.
Now, do I have to trim the plane in full throttle or half throttle ? An optimally trimmed plane should flight straight and level or straight and slightly ascending?
Any help would be appreciated. Tks.
adamkhwaja is offline Find More Posts by adamkhwaja
Old May 29, 2001, 08:23 PM
Sparky Paul is offline
Find More Posts by Sparky Paul
Ascended Master
Sparky Paul's Avatar
Palmdale, CA
Joined Oct 2000
Adam, the trim setting depends on the airspeed, which is a function of the throttle setting.
Most trainer type airplanes are fairly tolerant of power, and a trim setting will be good for most of the flight..
It is a good idea to learn how little you move the trim lever for a good "feel" to the plane.
Practice several mistakes high..
Sparky Paul http://www.angelfire.com/indie/aerostuff
PJB's Seriously Aeronautical Stuff http://www.networkone.net/~pjburke/index.html
Sparky Paul is offline Find More Posts by Sparky Paul
Old May 29, 2001, 09:53 PM
hoppy is offline
Find More Posts by hoppy
Space Coast USA
hoppy's Avatar
Space Coast
Joined Oct 2000
Straight, level, and slightly ascending. When you make turns or other manuvers, you'll lose altitude, if the plane is trimed for slightly ascending, it will gain the alitude back. You might have to adjust the elevator trim several times during a flight as the battery juice runs down to maintain that slightly ascending angle.
hoppy
hoppy is offline Find More Posts by hoppy
Old May 30, 2001, 10:47 AM
Singapore
Joined May 2001
Thanks for the help. Actually, I am purchasing a Zagi 400X. So will it be any different to trim than a Trainer?
Old May 30, 2001, 11:14 AM
Jensst is offline
Find More Posts by Jensst
Balsa Kamikaze
Jensst's Avatar
Germany, NRW
Joined Feb 2001
This was useful for me when trimming my plane:
http://denverrceagles.freeyellow.com...t_trimming.htm
_Jens
Jensst is offline Find More Posts by Jensst
Old May 30, 2001, 06:09 PM
Fred Bronk is offline
Find More Posts by Fred Bronk
Our Daddy and Heli Junkie
Fred Bronk's Avatar
In Heli Wonderland
Joined Aug 1999
A flying wing will not fly the same as a regular airframe. If you can handle a trainer though you should be OK with the Zagi.
Fred Bronk is offline Find More Posts by Fred Bronk
Old May 30, 2001, 07:21 PM
sblack is offline
Find More Posts by sblack
Scott Black, Montreal
sblack's Avatar
montreal quebec Canada
Joined Sep 1999
You should NOT trim the airplane to climb. YOu don't want it to automatically compensate for a turn - that's the pilot's job and that is what you are training for.
A student should practise figure 8s, concentrating on keeping the the aircraft at a constant altitude whether it is turning or flying wings level. This cannot be done properly if the airplane is trimmed to climb. The student should also concentrate on keeping the 8 symmetric and centered with the cross-over directly in front of him.
This does several things. It gives the student practice in turning left AND right, it shows him the airplane in all attitudes relative to him i.e. coming toward him an and going away turning left and right, and it makes the student place the airplane purposely in a specific place in the sky rather than following it around. The student has to fly the airplane - not react to it.
Any model or full sized airplane should be trimmed to fly wings level (not turning) and constant altitude with hands-off. The amount of trim required as power changes is directly a function of the static stability which is a function of cg location. This applies to a flying wing, canard or conventional layout.
The more stable the airplane (fwd cg) the more elevator required for a given speed (in reality Angle of Attack) change.
If you trainer is set up to be very stable (fwd cg), you will have to re-trim each time you change speed. The up-side is that the airplane will recover by itself from a dive.
Learning how to trim is a good skill to acquire. As you develop confidence you can move the cg back until the airplane is neutral, like most aerobatic ships are set up. Then you won't have to touch the trim very much. In the mean time, there is nothing wrong with learning how to retrim.
sb
sblack is offline Find More Posts by sblack
Old May 30, 2001, 08:06 PM
PunkerTFC is offline
Find More Posts by PunkerTFC
Old school newb
PunkerTFC's Avatar
Iraq
Joined Feb 2001
I do enjoy trimming with my flash 4, it's really easy with those digital trim buttons. The buttons are activated when the are pressed down, or moved to the side (like a conventional trim). So, I just hold down the correct trim key until the airplane is flying strait (or level), and then i release! easy as pie
PunkerTFC is offline Find More Posts by PunkerTFC
Old May 31, 2001, 12:41 AM
Paul Susbauer is offline
Find More Posts by Paul Susbauer
Balsa Builder
Paul Susbauer's Avatar
United States, OR, Hillsboro
Joined Apr 2001
The only problem with digital trims is that when you are test flying and a plane is way out of trim, you can't just slide a trim hard over, you have to wait for it to move all the way over, on a hot plane, that can be a white knuckle experience. (Did it on a Quikee 500)
Paul Susbauer is offline Find More Posts by Paul Susbauer
Old May 31, 2001, 09:43 AM
Singapore
Joined May 2001
sblack,
thanks for the detailed explanation. I will heed yr advice.
Discussion Help in choise a plane rogerio Electric Ducted Fan Jet Talk 2 Jan 10, 2007 05:02 PM
Discussion newbie need help in building plane and heli staphamou79 Foamies (Kits) 3 Oct 25, 2006 10:02 PM
Discussion Need help in finding a plane renerc 3D Flying 10 Sep 12, 2006 04:52 PM
need help in search of plane racer590 Fuel Jet Talk 1 Dec 16, 2004 11:55 PM
Help in identifying plane please. Al Dente Scale Fuel Planes 0 Feb 11, 2004 04:02 PM
