Old Jun 27, 2004, 05:14 PM
naX is offline
naX
Find More Posts by naX
naX
naX's Avatar
United States, CO, Grand Junction
Joined Jun 2004
First Build!!!! (Slow Stick)
Well, most of you experienced peeps won't be too impressed, if any at all, but I'm proud of myself. Now I just have to get the electronics in! The pics didn't turn out well, but oh well. I didn't put decals on because I'm going to 'brush it later tonight. ***Question regarding paint: should I remove all the tape before masking it off and spraying?*** I cut my bevels out too far so a lot of white foam is visible, but I still get awesome range of motion. I may have to make a new vertical stabilizer 'cause the foam came out of the box a little warped. I'm going to try the kite string trick and see if that will straighten it out. Anyway, here are the three pics (cut down to fit)...
naX is offline Find More Posts by naX
Old Jun 28, 2004, 07:24 AM
uglystick is offline
Find More Posts by uglystick
Arnold , Maryland, United States
Joined Nov 2002
Nice job. Keep in mind that, by positioning the electronics, and especially the battery, you can make your planes center of gravity be right at the spot it should be. You could rubber band, or tape the electronics in place and see where it balances. Then move things around until it does balance where it should. Then you can mount them where they need to be.
Mmmm paint huh. Well, that would make it a one of a kind. Paint adds weight though, so don't use too much. And use foam safe paint.
uglystick is offline Find More Posts by uglystick
Old Jun 28, 2004, 08:02 AM
RobinBennett is offline
Find More Posts by RobinBennett
Sussex, UK
RobinBennett's Avatar
Crawley, West Sussex, UK
Joined Jun 2004
You don't need to use every elastic band in the box to hold the wings on, they are supposed to allow the wing to move when/if you crash.
You can colour it in with a red pen, if you're bothered.
Robin
RobinBennett is offline Find More Posts by RobinBennett
Old Jun 28, 2004, 12:27 PM
Tommy D is offline
Find More Posts by Tommy D
Hooper, full throttle!
Tommy D's Avatar
USA, NY, East Islip
Joined Feb 2004
just my 2cents
NaX
Before you do anything make sure the wings are true on your SS. It seems to be a common overlooked area to have a TE on one wing to flair upwards while the other wing is flat and true. I had just that on my SS and it drifted left so badly at first I really had to trim it like heck to get it to fly straight.
Also considering by the photos you used the aluminum joiners <instead of the suggested brass ones> it would be in best interest to use a fair amount of packing tape on that wing. It would help keep the flexing to a minimum.
Foam safe paints like testors brand are a must. They work great when you paint per the directions. Many times it’s the paints propulsion NOT the paint itself that will melt the foam. Paint is also a fast way to add unwanted weight to a plane. If your looking for red touch up the sharpie pen as mentioned is the way to go. But if you want a completely different color then just don’t get to crazy with the number of coats you use painting.
My SS painted and with LOTS of packing tape is still only about 17.5 ounces. I also have lots of other mods.
Lastly if you are going to go through the trouble to mod the tailfeathers use tiny carbon fiber rods. I have tried fishing line and the way I had it rigged it would only add support if you tried to pull something apart. If you pushed it together it just collapsed. Also I used tiny aluminum rods but they did weigh considerably more then the carbon fiber.
Best of luck to you and propsaver…. propsaver…propsaver!
Tommy in NY
Tommy D is offline Find More Posts by Tommy D
Old Jun 28, 2004, 03:29 PM
LcJ is offline
LcJ
Find More Posts by LcJ
LcJ
Forever TMWT Pilot #11
LcJ's Avatar
United States, LA, Monroe
Joined Mar 2003
Nax,
Tommy was too nice to tell you, but it appears that the leading edge at the tip of your right wing (pilots view) appears to be higher than the leading edge of your left wing. This will may your plane go in a constant circle to the left. You may want to check it. It could be just the camera angle.
Enjoy your plane,
LcJ
LcJ is offline Find More Posts by LcJ
Latest blog entry: RC Logger's Eye One Xtreme Quad
Old Jun 28, 2004, 03:56 PM
naX is offline
naX
naX
naX's Avatar
Joined Jun 2004
LcJ,
While it is a bit higher on the right, it's not that high. I just threw the landing gear on for the pictures and wasn't put on straight so it made the plane slant. Also, because I don't have all my electronics in yet, I haven't balanced. I just threw the wing on for the pics as well. I did take the wing off and re-inspect though and as a result, I redid the dihedral and epoxy'ed the fiberglass rods with extra packing tape around it.
Thanks!
Old Jun 28, 2004, 03:58 PM
naX is offline
naX
naX
naX's Avatar
Joined Jun 2004
Oh yeah, one more thing. Should those reinforcement rods go below the wing, on top of the wing, or right smack at the front/back? I've currently got them on the top of the wing...
Old Jun 28, 2004, 06:23 PM
LcJ is offline
LcJ
LcJ
LcJ's Avatar
Joined Mar 2003
Nax,
I put mine right at the leading edge of the wing. You might want to use really goot n sticky tape. You might also want to use a dab of alcohol to remove any residue from the foam that might prevent the sticky from sticking.
Good luck, it will be a blast.
LcJ
Old Jun 28, 2004, 07:50 PM
flyboy2610 is offline
Find More Posts by flyboy2610
Mumbling in the corner.
flyboy2610's Avatar
Lincoln Municipal, Nebraska, United States
Joined May 2004
Solder a piece of wire between the landind gear legs to keep them from doing the splits.
flyboy2610 is offline Find More Posts by flyboy2610
Old Jun 28, 2004, 09:32 PM
Dynofly is offline
Find More Posts by Dynofly
Southern Man
Dynofly's Avatar
Olive Branch, Mississippi, United States
Joined Jun 2004
Propsaver
Since Tommy mentioned this, how do propsavers work? I've seen pictures of them but couldn't figure them out.
Dynofly is offline Find More Posts by Dynofly
Old Jun 29, 2004, 07:19 PM
flyboy2610's Avatar
Joined May 2004
When using a propsaver, it is the nut recessed in the back of the prop which actually turns the prop, not the rubber bands holding the prop to the propsaver.
You want to cut the prop shaft down to about 1/4 inch in front of the nut. That will let your prop slide off the propsaver, which is really what saves the prop. Having the shaft too long will cause the prop to hang up on it and increase the likelihood of bending the prop shaft, as well as possibly breaking the prop.
How hard is it to build the slow stick? corrington_j Parkflyers 4 Jan 23, 2005 04:02 PM
$15 DIY easy-to-build Slow Stick wing with better wind-handling characteristics pfm Aerial Photography 23 Nov 01, 2004 06:24 PM
Does anyone build the slow stick STOCK??? soholingo Beginner Training Area (Aircraft-Electric) 34 Aug 02, 2004 10:48 PM
Alert what materials do u need to build a slow stick coolman01231 Beginner Training Area (Aircraft-Electric) 4 Feb 09, 2004 07:44 PM
Yippee! First Flight! Slow Stick Maiden + Carnage. Mindblade Beginner Training Area (Aircraft-Electric) 14 Nov 12, 2003 12:28 AM
