Old May 29, 2001, 02:43 PM
atckirk's Avatar
Poway, CA USA
Joined May 2001
Folding Prop or Fixed???
I'm new to electric and am going to use my Quickie 200 ex-cox soon to be speed 400 powered plane as my first try. I think I'm set on everything but the prop. Do I need a folding prop without landing gear or do you need to put some kind of skid on it. I'm used to engines so you can adjust the prop so it rests against tdc in a nice flat position. Is there a way to do this with electric? Thanks for any info. Kirk.
atckirk is offline Find More Posts by atckirk
Old May 29, 2001, 05:01 PM
Swedes don't grow on trees
Jonas Leander's Avatar
Sverige, Stockholms Län, Stockholm
Joined Jan 2001
Hi,
I can think of three options for you:
1) Use a Gunther push-on prop. They are cheap and flexible. I have never broken one on landing (we're talking 100+ flights on the same prop)
2) Use a folder. A 6x3 should be fine. You really can't go wrong with a this either. More expensive if you crash, though.
3) Use a fixed prop, but use a rubber band type prop-adapter. Works well too, it allows the fixed prop to fold if needed.
There is no shure-fire way to get an electric to stop with the prop in a horisontal position. You can try to blip the throttle a few times on your final approach, but this does not always work. It also depends on how the brake on your ESC works.
Good luck!
/ Jonas
Jonas Leander is offline Find More Posts by Jonas Leander
Old May 29, 2001, 05:12 PM
Motors beat engines!
Milwaukee Wisconsin, United States
Joined Feb 2001
") Use a fixed prop, but use a rubber band type prop-adapter. Works well too, it allows the fixed prop to fold if needed."
Where the heck can I get one of these adapters? I'd really rather purchase one than try to make one. HELP!
DeaninMilwaukee is offline Find More Posts by DeaninMilwaukee
Old May 30, 2001, 09:06 AM
Master
ChrisP's Avatar
Weilbach, Germany
Joined May 2001
You can make one of these in 5 minutes. And you don't need a lathe. Honest !
Buy an aluminium prop adapter for a fixed prop which has two grub screws to attach it to the shaft. The versions with one screw won't work.
Cut the threaded portion short (where the prop goes on) so that the length of the stub left over is about half the thickness of the prop hub. Round off the corners slightly so that when you tilt the prop it slips off the stub.
Replace the two grub screws by two allen screws of the same thread size and about half an inch long. Cut from longer bolts if necessary.
Wind two (for safety) rubber bands around the two screws over the prop to fix it.
Finished !!
ChrisP is online now Find More Posts by ChrisP
Folding prop blades -Graupner or Aeronaut? Megatron Power Systems 2 Nov 05, 2002 07:56 AM
It is me or what ? folding prop... Baveux Foamies (Kits) 8 Aug 16, 2002 01:05 PM
Source of 10x10 or 10.5x10 folding prop? rparigoris Power Systems 4 Dec 02, 2001 05:44 PM
Motor brake on or off for non folding prop? Grant Smith Sport Planes 5 Sep 09, 2001 06:31 AM
Using an ESC without Brake Disable with A Fixed Non Folding Prop/ Safe? Joe Elston Electric Plane Talk 4 May 10, 2001 10:35 PM
