Old Jun 24, 2004, 01:59 PM
It's a Great Day to Fly
LenBFP's Avatar
Melbourne Beach, Florida
Joined Jan 2002
4mm pager motor actuator?
I see references to 4mm pager motor actuators, but is there a thread somewhere here that explains how they work or how to construct one? Search has not helped me here.
Len
LenBFP is offline Find More Posts by LenBFP
Old Jun 24, 2004, 02:20 PM
gbarc's Avatar
Jackson, Michigan, United States
Joined Nov 2002
Check out www.Smarttoolsinc.com
Greg
gbarc is offline Find More Posts by gbarc
Old Jun 24, 2004, 03:39 PM
Cannes Mandelieu, France
Joined Jun 2003
motor actuator
it's clear on the pic:the 4 mm,40 ohms didel pager is on the fix stab,and the axle on the moving part,and connected in place of standard actuator
cheap,simple and efficient!
patrick .
bleriot 11 is offline Find More Posts by bleriot 11
Old Jun 24, 2004, 03:43 PM
Joined Jun 2003
i forgot:hinges are the pink thin rubber treads.(fishing shops)
Old Jun 24, 2004, 03:49 PM
LenBFP's Avatar
Joined Jan 2002
Thanks! - incredibly simple
Old Jun 24, 2004, 04:14 PM
Dave Wulff's Avatar
USA, FL, Fort Lauderdale
Joined Feb 2002
Partick,
Just for the record, if those motors are 4mm that would make the foam you used about 2mm. Correct? I am still learning about foam thickness and it's uses. Thanks.
Dave
Dave Wulff is offline Find More Posts by Dave Wulff
Old Jun 24, 2004, 05:19 PM
Custard fuelled
epilot's Avatar
Faroe Islands, Sandoy, Sandur
Joined Nov 2000
Looks like Selitac to me. In that case it is 2mm.
Michael
epilot is offline Find More Posts by epilot
Old Jun 24, 2004, 06:48 PM
United States, NC, Burlington
Joined Jun 2004
I would like to try and construct one. I have quite a few pager motors that need a good project!
hogan is offline Find More Posts by hogan
Old Jun 24, 2004, 07:10 PM
I'm Me Again!
Jerry Rose's Avatar
Joined Feb 2002
Can you tell me more about those hinges? Do you have a closeup photo showing how they are used? Thanks, Jerry
Jerry Rose is offline Find More Posts by Jerry Rose
Old Jun 24, 2004, 07:33 PM
Micro Brushless crazy
Uttam1's Avatar
India, Bangalore
Joined Jul 2002
Nice Patrick, cant get more simler than that!! How much torque does the 4mm have?
Uttam
Uttam1 is offline Find More Posts by Uttam1
Old Jun 24, 2004, 08:37 PM
Frequent Poster
Pete P.'s Avatar
South of Boston
Joined Mar 2004
I have a Zip-Zap steering 'servo' for an actuator. I made centering action by use of a security-tag strip-spring. Works nice, too much power tough. 6mm short 30 Ohm. From CVS 1ch IR car.
Pete P. is offline Find More Posts by Pete P.
Old Jun 24, 2004, 10:34 PM
Murphy,NC
Joined Feb 2003
patrick .
But how do you keep it from just spinning and reaming out the hole the axil is connected to if you happen to hold the stick in one position too long ?
It would seem that you could only use it in a "tapping the radio stick" sort of way,or do you have some kind of stops to keep the motor from making a full revolution ?
Randy
elroy is offline Find More Posts by elroy
Old Jun 24, 2004, 11:27 PM
I'm Me Again!
Jerry Rose's Avatar
Joined Feb 2002
Aren't these "servos" going to be Wham-Bam ... full extreme up or down only? Or is tapping the stick actually going to get partial movements?
And, would it ever be possible to get them to center?
Old Jun 25, 2004, 12:19 AM
Uttam1's Avatar
India, Bangalore
Joined Jul 2002
I wouldnt want to answer on behalf of Patrick, but I'm quite sure the servos are not "bang-bang". You just connect the motor in place of the actuator and get the same proportional movement. You center them just like all actuators, just use a rubber bands like Patrick has used to center back, the 4mm motors move very freely and even light rubber "springs" should work.
Uttam
Old Jun 25, 2004, 12:32 AM
Joined Jun 2003
it is selitac 2 mm foam from a danish people in germany!!
just one hinge on rudder glued with ca,and 2 on the elevator(glued to have neutral position)
the motor torque is equal rubber one at about 30 ° angle.
a bit less torque than strong actuators but no problems in flight.
motor axle glued in a hard balsa piece.
patrick.
How To Reduce The Weight Of A 4mm Pager Motor... ALOT! TimayTheToolman Indoor and Micro Models 20 Jul 03, 2006 05:27 PM
Pager motor actuator cmartin Indoor and Micro Models 71 May 04, 2004 09:00 AM
efficient 4mm pager motor ? bmaaa Indoor and Micro Models 23 May 03, 2004 11:52 AM
My First Home Made Prop For bitG Rudder Steering 4mm Pager Motor jas_Qfix Indoor and Micro Models 11 Jul 27, 2003 07:20 PM
RFFS100 & 4mm pager motor Andycart Indoor and Micro Models 6 May 13, 2003 04:49 AM
