Forgot your password? Create a new account
Old Jun 22, 2004, 09:36 AM
cranium accessories
dustn's Avatar
Raleigh, NC
Joined May 2004
dustn is offline Find More Posts by dustn
semi-scale fff rutan quickie
Coming just as soon as i settle on my 3-views... quick question tho: how do you make airfoiled fff wings? i'm sure i could figure something out but i may be missing something obvious.
Old Jun 22, 2004, 10:19 AM
Arizona Rim Country
Joined Nov 2001
pcaffeldt is offline Find More Posts by pcaffeldt
Do you want double surface or single surface wing.
Old Jun 22, 2004, 10:21 AM
cranium accessories
dustn's Avatar
Raleigh, NC
Joined May 2004
double... and i'll have a balsa spar in there
should i make ribs? or just bend the top around and have a flat bottom... i guess i'd use packing tape on the LE to keep the foam from snapping from the tight bend.
i may even use split fff... the stuff i have has plastic in the middle so its easy to separate
Old Jun 22, 2004, 03:17 PM
cranium accessories
dustn's Avatar
Raleigh, NC
Joined May 2004
what plane plans could i look at for construction ideas? i've not made anything but flat panel planes of fff up to this point.
Old Jun 22, 2004, 06:58 PM
hardhats required
rchotrod's Avatar
ks, usa
Joined Feb 2004
rchotrod is offline Find More Posts by rchotrod
You can gently bend the fanfold over a counter top edge and make an airfoil. Just work slowly and check your progress as you go.
It is just that easy.
See ya,
Rod
Old Jun 22, 2004, 07:39 PM
Tampa, Florida
Joined Nov 2003
Marcuswhorley is offline Find More Posts by Marcuswhorley
Keep in Mind that the front wing is also the landing gear, so what ever you decide on make sure that the canard can take the stressof a landing with out flattening out.
Old Jun 22, 2004, 09:25 PM
willin's Avatar
In my Blu heaven! near Lincoln NE
Joined Mar 2003
willin is offline Find More Posts by willin
Very true marcus and unlike so many othermodels the Landing gear on this one may NOT be ommitted for simplicity or just to save weight. another problem with this particular model would be the wheels themselves. so many of the "park flyers" we have any more, while somewhat scale in apearance (such as the B-2N Islander just as an example) have greatly overgrown wheels to land on due partially to the models smaller size. This allows us as modelers to have a better flying experience as this improves ground handling immensely.
Such liberties will not be allowed on a Quickie and the resulting very small wheels on the original will translate to tiny in a model using fanfold I fear. Unless the model were to be made of a very large scale, they will certainly be tiny.
I look forward to this thread and the Quickie that hopefully will result from this. I love this model and though it is a difficult design to reproduce on a small scale, It is a design which I fell ion love with the first time I laid eyes on it.
It is both beautiful and graceful and that is just on paper. Put it on a runway and its beauty and grace are multiplied exponentially ( to me at least).
Good luck!
Old Jun 22, 2004, 11:57 PM
cranium accessories
dustn's Avatar
Raleigh, NC
Joined May 2004
thanks guys!
thanks for the comments! for the landing gear i'm considering a cf arrow shaft spar in the cannard, and I do not intend to use wheels, just skids on the cannard. I agree the quickie is gorgeous! its one of my all-time favorite airplanes. actually most of rutan's designs are up there on my list
Old Jun 25, 2004, 10:14 AM
cranium accessories
dustn's Avatar
Raleigh, NC
Joined May 2004
quixtards
man i'm really trying to shake this Quixtar (basically Amway) guy off of me... he's absorbed 2 of my evenings so far trying to recruit me into a marketing robot, anyhow, i'm a pushover sorta, thats why i agreed to meet him again the first time i met him, but i'm not gonna sign up... that aside, i'm saving up my roundtoits to begin this quickie, it always seems like i have other stuff to do when i try to sit down and start a full night of building
Old Jun 25, 2004, 11:42 AM
Micro Brushless crazy
Uttam1's Avatar
India, Bangalore
Joined Jul 2002
Uttam1 is offline Find More Posts by Uttam1
I'm offtopic here, but I've always wanted to build the Rutan LongEz, or the Varieze. Beautiful plane, just like all his other designs, has any one build it? I have plans for one, in pdf.
Uttam
Burt Rutan Quickie FFF Matt Chester Foamies (Kits) 10 Jul 02, 2004 01:12 AM
The kit is semi-scale although little modification is required for true scale CLARKE Aircraft - Electric - Airplanes (FS/W) 5 Mar 17, 2002 12:39 PM
Rave Whats a good semi-scale 3 channel aerobatic parkflyer???? mike93 Parkflyers 2 Mar 09, 2002 01:39 PM
Semi Scale twin bomber for GWS IPS DerekB Foamies (Kits) 3 Feb 07, 2002 10:15 PM
semi scale u-2? i-fly Electric Ducted Fan Jet Talk 2 Apr 27, 2001 10:35 PM
