Old Jun 22, 2004, 08:46 AM
meteor is offline
Find More Posts by meteor
meteor's Avatar
Ontario, Canada
Joined Nov 2002
Wattage F-22 with mixed surfaces & 208 watts/lb!! (video)
Here's a really effective modification of the Wattage F-22 using "linked" surfaces a-la the Wattage F-86.
This mod makes for much more roll authority (speed) and removes the noticeable axial-roll "wallow" that the fully-flying stabs had. (the nose tended to follow a small circle in a roll)
Also, the stock set-up always had some slop in the linkages to the stabs, so this would mean that it was always hunting a little in roll, as the surfaces twitched with varying aerodynamic loads. This set-up is rock-solid
Other benefits are substantial weight savings from the tail by removing all the useless linkages and servo mounts, as well as moving the servos closer to the CG, making balancing easier. (or to add a larger motor!)
This model uses a Mega 16/15/4, APC 6x5.5 and a 3S1P 2600mAh Poly-Quest pack.
It pulls about 27A static (270W!), and the AUW is a hair over 20 oz.
This ship gives new meaning to "vertical" performance! (you can punch it from a near-stall, and it will accelerate vertically 'till it's a dot!)
Here's a video (more to come, this one is kind of repetitive!)
http://meteor.rchomepage.com/mig-15_f-22.wmv
Fun!
meteor is offline Find More Posts by meteor
Old Jun 22, 2004, 12:55 PM
rcguy01 is offline
Find More Posts by rcguy01
Permanently Banned
Joined Apr 2003
awesome vertical performance and rolling rate.
few questions:
1/ can the 2600 fit in the F22 cockpit? (spelling)
2/ I doubt those two tinny servos will stand the torque on both 4 control surface for very long?
3/ are those control horns from GWS?
I love the Video, great.
rcguy01 is offline Find More Posts by rcguy01
Old Jun 22, 2004, 02:09 PM
monkamarm2000 is offline
Find More Posts by monkamarm2000
smug in granny panties
monkamarm2000's Avatar
NorCal Silicon Valley
Joined Aug 2002
wow very axial!
Barry
monkamarm2000 is offline Find More Posts by monkamarm2000
Old Jun 22, 2004, 02:18 PM
meteor is offline
meteor's Avatar
Ontario, Canada
Joined Nov 2002
Answers...
Yup, the 3S 2600 Li-Po easily fits under the canopy by cutting a slightly deeper (3/4") channel in the existing battery bay.
I think a lot of people overestimate how much torque is actually applied by aerodynamic forces...
These "normal" hinged surfaces will load the servo far less than the stock arrangement of a fully-flying stab, and don't forget that the Wattage manual suggests CS-10 (GWS Pico) servos for the flying stabs!
We intentionally used very thin music wire to allow a little bit of flex under extreme load situations. (sort of a "servo-saver" effect) Also, music wire is hardened so it'll flex and bounce back without permanently bending.
Yes, the aileron horns are stock GWS horns, and the elevator horns are Robart "hinge-points", kind of overkill, but it's all we had!
All in all, very successful.
Old Jun 22, 2004, 08:56 PM
Lv2Fly is offline
Find More Posts by Lv2Fly
RC-Nut-Job!
Lv2Fly's Avatar
New York
Joined Jul 2001
very very nice.....
Lv2Fly is offline Find More Posts by Lv2Fly
Old Jun 22, 2004, 09:53 PM
Arbo is offline
Find More Posts by Arbo
Joined May 2000
wow... very very impressive....
Paul
Arbo is offline Find More Posts by Arbo
Reply With Quote  (Disabled)
Old Jun 22, 2004, 10:52 PM
BING! is offline
Find More Posts by BING!
BING!'s Avatar
usa
Joined Mar 2003
Wohohooooo! Nice. Must be lotsa fun. JT
BING! is offline Find More Posts by BING!
Old Jun 22, 2004, 10:55 PM
darren jakel is offline
Find More Posts by darren jakel
darren jakel's Avatar
Maricopa, AZ
Joined Jan 2004
Awesome plane and Video Meteor! I have one of these sitting in the closet waiting to be built. I got an astroflight 020 direct drive system in trade and thought this would be the perfect plane for it. I may have to bump it up a notch or two on the priority list after watching the video.
Darren
darren jakel is offline Find More Posts by darren jakel
Old Jun 22, 2004, 11:19 PM
Darren Hintze is offline
Find More Posts by Darren Hintze
Tight is Right
Darren Hintze's Avatar
Lehi, Utah, United States
Joined Dec 2001
I just pulled my very similar set up off the line (after 323 wonderful flights) and am converting it into a semi-scale F-35 with a single 65mm fan (Wattage housing probably with a Kyosho rotor cut down).
I was flying 3s with a 5T though at about 180W on a 6.5x6.5. Mine would not quite go unlimited veritcal and wasn't as fast. I decided to go EDF with the new batteries coming out though.
Awesome plane Meteor.
I need to get another one of these airframes though before they disappear. I paid $22 for mine used as a Christmas present 18 months ago. Needless to say it was far and away the best bang for the buck I've ever gotten in 15 years of RC flight.
Darren
Darren Hintze is offline Find More Posts by Darren Hintze
Old Jun 23, 2004, 12:25 AM
bipeflyer is offline
Find More Posts by bipeflyer
My cat up close
bipeflyer's Avatar
England
Joined Feb 2001
My God, that is quick!
Worthwhile modifications I'd say,interested in the prop size too, might give it a go over the 6 X 4 APC prop in my mini Cat,which has a pretty much identical power train to yours, except my AUW is 35 oz..
20 oz, it's got to be a winner, and it shows in the video!
Nicely done,
Matt
bipeflyer is offline Find More Posts by bipeflyer
Old Jun 23, 2004, 12:44 AM
Joined Aug 2002
I just buy them by the parts now. I have a template for the wings that came from my Wattage Mirage(same wings) so I just buy the bodies and make my own surfaces.
Barry
Old Jun 23, 2004, 01:00 AM
My cat up close
bipeflyer's Avatar
England
Joined Feb 2001
Barry- subliminal message follows:
B-U-C-C-A-N-E-E-R, repeat over and over to yourself 5 times an hour.......
I had a Wattage F-22 and sold the kit- kinda wish I hadn't now!
Good idea on just buying the parts and cutting the rest though.
Mat
Old Jun 23, 2004, 01:22 PM
rcguy01 is offline
Permanently Banned
Joined Apr 2003
Folks;
It sounds like Wattage again is pulling the plug on the F 22? Is it true?
Gosh... what the hell are we going to?
First, they killed their mirage 2000 (one of the best pusher jets out there)
Now, they are pulling the plug on the F 22
I am confused? Are we supposed to fly Slowsticks, Piper Cubs only???
If it is true then This world is becoming very weird???
Old Jan 20, 2005, 11:17 AM
Ralph Brekan is offline
Find More Posts by Ralph Brekan
a really nice guy, really
Ralph Brekan's Avatar
Phoenix Intl, Arizona, United States
Joined Jul 2004
Man. I wonder if I can do this to mine w/o messing it up
Ralph Brekan is offline Find More Posts by Ralph Brekan
Old Jan 20, 2005, 12:33 PM
Aero-Nuts is offline
Find More Posts by Aero-Nuts
Scotty..more power!!
Aero-Nuts's Avatar
Pakenham Ontario, Canada
Joined Oct 2003
If you want to see a little more video of that ship go here ...
http://aircraft-world.com/prod_datas...cer/bl4-15.htm
and click on the "3-turn motor in a F22 foamie pusher jet" link (BL4-15-3, PQ-2600-3S, GR 5.5x4.5 speed prop). I needed a test bed for the motor..
This test was done with Polyquest 10C batteries, I would like to put some new 12C to 16C into this and "prop up". Over 310 to 410 Watts should really make her "Scoot"
If you are wondering why I am replying to this thread... Meteor helped me get this uploaded to the groups...I'm not a big poster
Aero-Nuts is offline Find More Posts by Aero-Nuts
FS- Wattage F-22 Raptor with servos and BRUSHLESS - all new and MAY seperate. Etonic Aircraft - Electric - Airplanes (FS/W) 3 Feb 10, 2004 05:33 AM
Anyone try this with a Wattage F-22?? Etonic Parkflyers 10 Jun 25, 2003 06:06 PM
Wattage F-22 with ducted fan The Blue Max Electric Ducted Fan Jet Talk 11 May 10, 2003 01:13 PM
Needed: Video of Wattage f-22 and GP simprop Cap232 Mike Parsons Parkflyers 2 Dec 04, 2002 04:15 PM
Wattage F-22 maiden flight video posted steve neill Foamies (Kits) 5 Sep 22, 2001 02:53 PM
