Old Jun 20, 2004, 01:46 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
How to fix a sheet balsa wing warp?
Hey guys,
I have a balsa sheet wing ( Micro Pitts ) and need to fix a slight warp in the wing end which happened during construction.
I did a search on the board and found various recommendations on how to acheive this.
"Spray the wing using window cleaner and set. Apply ammonia ( which I dont have ) and lastly, apply hot water and set."
I dont want to steam as I dont have the best steaming application to get it right. Can anyone offer their comments/methods to steer me in the right direction, please? ( the wing is attached to the fuselage already - its the rear of the wing tip that is lifting up slightly)
Dave
NitroCharged is offline Find More Posts by NitroCharged
Old Jun 20, 2004, 02:05 AM
speeddemon281 is offline
Find More Posts by speeddemon281
Food For The Maggots
speeddemon281's Avatar
New Waverly,Texas
Joined May 2004
Your best bet is Ammonia,its what i use.
Are you able to take the wing off?If you are,then take a paper towel,get it wet,then rub down the wing with the ammonia,then lay it and have a electric fan blowing under the book onto the wing,Leave it like this for 2 hours.
then it will be straight as a board.(A non Warped board)
speeddemon281 is offline Find More Posts by speeddemon281
Old Jun 20, 2004, 02:09 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
For all responses - please note "I don't have ammonia"...
Thank you.
Dave
Old Jun 20, 2004, 03:00 AM
TimayTheToolman is offline
Find More Posts by TimayTheToolman
Kiwi's Can Fly's Son
TimayTheToolman's Avatar
New Zealand
Joined Dec 2003
Try holding it how you want it over a hot light bulb, and it will soften the wood then take it away and keep holding it until it cools then it should stay.
Tim.
TimayTheToolman is offline Find More Posts by TimayTheToolman
Old Jun 20, 2004, 06:03 AM
Graham Stabler is offline
Find More Posts by Graham Stabler
Sticky Shepherd
Graham Stabler's Avatar
Oxford/England
Joined May 2001
There was a time when I didn't have any ammonia either.
Just use water if you can't face the cost of buying some.
Graham Stabler is offline Find More Posts by Graham Stabler
Old Jun 20, 2004, 06:32 AM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
So your recommendation is to use Ammonia too, Graham?
Old Jun 20, 2004, 07:59 AM
Tim Wolff is online now
Find More Posts by Tim Wolff
Gravity is a harsh mistress.
Tim Wolff's Avatar
United States, MI, Temperance
Joined Sep 2002
Your window cleaner (ie Windex) should contain some ammonia. You will need to guess at how much opposite deflection to use and imobilize the panel until it dries throurghly-like overnight.
All you need to do steam is a small pot of boiling water. It may take several applications.
The warp sounds like washout which can be a good thing in moderation and if the other wing is warped in the same fashion. I'd prob. just try to reduce the warp a bit and add some to the other side too.
Tim Wolff is online now Find More Posts by Tim Wolff
Old Jun 20, 2004, 09:09 AM
gbarc is offline
Find More Posts by gbarc
gbarc's Avatar
Jackson, Michigan, United States
Joined Nov 2002
Try this...i use an ammonia/rubbing alcohol mix. I can't remember where i got the info from but it works great. Almost instant softening of the wood. Then just pin down the part on a warp free board.(But you already knew that).
Greg
gbarc is offline Find More Posts by gbarc
Old Jun 20, 2004, 10:53 AM
Sticky Shepherd
Oxford/England
Joined May 2001
Ammonia does seem to help but you can just soak the wood in water. So you don't HAVE to use it, but if would not be difficult to get some.
Graham
Old Jun 20, 2004, 10:58 AM
Tim Wolff's Avatar
Joined Sep 2002
I think the key is be able to guess how much to reflex the part when wet AND to leave it imobilized until it dries throughly.
I recently straighted a Diddlebug wing that was warped by the covering. Just shimming in some areas and weights in others straightened it out when I left it set 24 hrs. No moisture used (though that was my next option).
Old Jun 20, 2004, 08:41 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
Thanks guys. I'll let you know how it goes
Old Jun 21, 2004, 01:56 AM
Martin SJ is offline
Find More Posts by Martin SJ
Martin SJ's Avatar
Thousand Oaks, California
Joined May 2004
I had the same problem with a Lil Skeeter, especially after flying it in the early mornings and landing on grass covered with dew. I completely fixed the problem by attaching a pair of criss-crossed threads on the underside of each wing. The threads go from the leading edge at the root to the trailing edge at the single rib, and from the trailing edge at the root to the leading edge at the rib. The two threads on one wing should just touch where they cross - attach them there either with a spot of glue or with a small loop of thread. I got the tension on the two threads the same by tying a single crossed-over loop attached at the leading edge and trailing edge at the root then suspending a weight from the loop (probably needs a diagram), but however you achieve it you do need some tension on the threads. I believe the structure of the Pitts wing is the same so it should work for you too.
--Martin
Martin SJ is offline Find More Posts by Martin SJ
How to build a Depron/Balsa wing guide! tallflyer Foamies (Kits) 13 Sep 14, 2004 11:06 PM
How to fix Alfa Corsair Wing MadJocko Parkflyers 7 Jun 19, 2004 10:33 PM
35" sheet balsa wing......will it work? JWC Electric Plane Talk 2 Aug 14, 2002 12:16 PM
How to fix Omega wing ?? danny_isr Electric Sailplanes 17 May 30, 2002 05:04 PM
How to fix a crack of foam wing ? jnyoun High Performance 5 Jun 04, 2001 07:44 PM
