Old Jun 19, 2004, 05:36 AM
surfimp is offline
Find More Posts by surfimp
Piscine Promulgator
surfimp's Avatar
United States, CA, Santa Barbara
Joined Feb 2003
Sanity Check: Axi 2820/10 w/ 2s iRate 2600 Lipos?
I've been fiddling with Motocalc and maybe it's just side effects from my insomnia kicking in, but it seems like I could run my Axi 2820/10 on a 2s iRate 2600 pack if I used a Graupner CAM 12x6 folding prop. This would pull less than the iRate's max 26A and would give me some really great weight savings and seemingly pretty long duration. Am I reading this correctly or have I gone off the deep end?
Steve
surfimp is offline Find More Posts by surfimp
Old Jun 19, 2004, 06:21 AM
benlo2d is offline
Find More Posts by benlo2d
Aberdeen, WA
Joined Sep 2001
Steve
As long as you don't need over about 180 watts.
Ben
benlo2d is offline Find More Posts by benlo2d
Old Jun 19, 2004, 08:34 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
Sure. No reason not to run down low. The motor will be at or near max efficiency, and will probably rn as cold as a...very cold thing
The same would no be true of the cells tho. Sounds like you are going in for short burts in a sailplane. That's fine.
But personally I wouldn't run ANY LIPO at 10C for any length of time. Recipe for possible problems.
Old Jun 19, 2004, 10:58 AM
surfimp is offline
Piscine Promulgator
surfimp's Avatar
Joined Feb 2003
Thanks both of you. The 26A draw would only be at full throttle and thus would not be continuous. I could also use an 11x6 prop and draw even less (around 18A), but--according to Motocalc--still deliver sufficient performance with my airframe. Motocalc indicates static duration with that second setup to be around 7min. if I remember correctly--is there any reason to believe that? Understanding that I won't be getting full performance, if the performance I get is adequate--a nearly 1:1 power-weight ratio--should there be any other reason for concern?
Thank you again,
Steve
Discussion AXI 2820/10 burn out on 3s Lipos leccyflyer Power Systems 10 Jul 24, 2006 08:34 AM
Sold Axi 2820/10 w/ radial adaptor $75 shipped xterra Aircraft - Electric - Power Systems (FS/W) 0 Jan 29, 2006 01:37 PM
FS...Axi 2820/10 w/ TMM 4012-3s Brushless SC..10 Cell 1700scr Pack kindjordan Aircraft - Electric - Airplanes (FS/W) 8 Oct 10, 2004 06:32 PM
Axi 2820/10 w/Matts Belt Drive=Smooth gyrodude Electric Heli Talk 20 Feb 22, 2004 07:50 PM
Jeti 30-3 or AXI 2820-10 w/8 cells in Bandit ? Al P Power Systems 2 Sep 28, 2003 11:10 AM
