Old Jun 18, 2004, 06:17 PM
Mr.RC-CAM is offline
Find More Posts by Mr.RC-CAM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
Question
Upgraded SlowStick motor -- Goes slightly nose up under power.
I needed to increase the payload that I carry on my SlowStick (more gadgets). So I just upgraded it with a BL motor coupled with a EPS400C gear box. I mounted the 400C "inverted" -- that is, the motor is on the lower side rather than the traditional top side.
Now, under power the model goes slightly nose up. Relax the throttle and it flies true. It is irritating.
CG is correct. I have looked at the gearbox mounting and I cannot see a thrustline issue.
The model flew normally with the old power plant. Besides the motor change I now haul a small payload of stuff (about 20 oz AUW). Also, there is a camera mounted on a 6" pylon at the leading edge of the wing.
What might be going on?
RC-CAM
Mr.RC-CAM is offline Find More Posts by Mr.RC-CAM
Old Jun 18, 2004, 06:25 PM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
you ned more downthrust and/or less decalage with more power.
Question probably belongs in modelling science forum too...
Old Jun 18, 2004, 06:45 PM
Mr.RC-CAM's Avatar
USA
Joined Oct 2001
Thanks. I'll toss in some downthrust. I just have to figure out a decent way to do that.
RC-CAM
Discussion Multiplex Cargo-B17 nosing up under full power redtail Electric Warbirds 7 Sep 24, 2006 08:10 PM
Discussion Lifelike Glider: step up in power from 2x edf-50 motor with 3/2 prop? mike93 Pusher Prop Jet Models 2 Apr 24, 2006 08:48 AM
Downthrust causing "swimming" under power on Rascal Tim Jonas Electric Plane Talk 9 Jul 05, 2001 08:23 PM
$300 plane, $8 motor, WHat is the next step up? ezekiel Electric Plane Talk 11 Jun 02, 2001 01:37 PM
Will lead nose weight under motor affect the motor? Balin Power Systems 2 May 12, 2001 04:34 AM
