Old Jan 15, 2002, 05:19 PM
PylonWorld is offline
Find More Posts by PylonWorld
Monroe, NC, USA
Joined Jul 2001
My V tailed Pico Stick with ailerons
This is my V tailed Pico Stick. It's not legal for the NIMPRA stock class, but it is for the indoor racing we do here.
You can see a little more detail at PylonWorld - Indoor Pylon
PylonWorld is offline Find More Posts by PylonWorld
Old Jan 15, 2002, 09:40 PM
Spaulding is offline
Find More Posts by Spaulding
Dangerous
Spaulding's Avatar
LA
Joined Nov 2001
Details? How's it fly? I have heard of people trying ailerons on a pico stik with no success.
Spaulding is offline Find More Posts by Spaulding
Old Jan 16, 2002, 09:01 AM
Greg Covey is online now
Find More Posts by Greg Covey
AMA 697691 / FAA 13675
Rochester, NY, USA
Joined Aug 2000
Don,
Nice job!
I like how the added fuselage fills the gap between the wings. It probably helps to add strength too.
Regards.
Greg Covey is online now Find More Posts by Greg Covey
Latest blog entry: Greg's Web Hangar
Old Jan 16, 2002, 12:55 PM
Monroe, NC, USA
Joined Jul 2001
It flies great. I have to use low rates unless I want to race or do aerobatics. Rolls are tricky with the full span wing, but we don't allow any wing area decrease in our racing class. It will do 8-10 ft loops on high rates.
On low rates, it's so gentle, but still responsive, my 7 year old son learned to fly with it. But he's been flying RealFlight for a while.
Even though there is no dihedral, it's very stable. In a high banked turn, it does lose altitude unless you make it a tight turn.
It uses Elevon mixing. When an elevator is up, the corresponding aileron is down. So it's got ailerons and flaperons.
It has carbon fiber laminate CA'd to the stick on both sides. The stick is turned sideways, and the prop shaft is above the stick. It was very easy to build, and things jut kinda worked out.
I disconnect the ailerons for the NIMPRA stock class, and it still flies fine, just not with the same roll authority.
It's been a fun plane.
Pico Stick with 7 X AAA nimh sail_power Parkflyers 1 Jan 05, 2003 01:02 AM
Pico F with ailerons FLYS! DeaninMilwaukee Scratchbuilt Indoor and Micro Models 2 Nov 07, 2002 04:21 PM
FS- GWS Pico stick with motor & GB Gonflyin01 Aircraft - Electric - Airplanes (FS/W) 5 Oct 31, 2002 02:10 PM
Blue Stick with ailerons flys Chuck Parkflyers 29 Sep 03, 2002 02:33 AM
FREE Pico-Stick with Tiny Purchase! :) Robert Parisot Aircraft - Electric - Airplanes (FS/W) 3 Apr 21, 2002 03:48 AM
