Old Jan 15, 2002, 04:53 PM
Gman2 is offline
Find More Posts by Gman2
Gman2's Avatar
land of permaban
Joined Jul 2001
A skin[sprayable] for epp foam ?
I saw a scale glider with a foamy wing and fuse that was aerobatic and light. the only thing that detracted and very little was the tape. If anyone could figure a skin that could be painted for foamyflage ,we could have delicate ships that are crashable. A graphite rod could be placed at the leading edge and at the aileron split for spar. The one I saw the guy just filed and sanded the fuse.
Gman2 is offline Find More Posts by Gman2
Old Jan 16, 2002, 03:39 PM
tenover is offline
Find More Posts by tenover
Certified Slopehead
tenover's Avatar
San Diego, CA.
Joined Jan 2001
I just built one. Spraypaint your fuse/wings, get some Marine Goop, thin it out with Toulene and brush it on. Absolutley indestructible...
tenover is offline Find More Posts by tenover
Old Jan 16, 2002, 05:48 PM
Ben74 is offline
Find More Posts by Ben74
Ben74's Avatar
San Francisco, CA, USA
Joined Jun 2001
what's marine goop? is it Goop brand glue that says "for marine use" on it, or is it something else? does it come in a tube?
how smooth does the surface end up? is it transparent? got any pictures?
does painting with thinned goop add a lot more weight than tape or ultracote?
this idea intrigues me. i'd like to know more...
thanks,
ben
Ben74 is offline Find More Posts by Ben74
Old Jan 16, 2002, 06:38 PM
davidfee is online now
Find More Posts by davidfee
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
...but where did you get the toluene? I don't believe it's available to the general public anymore. At least, not in California.
davidfee is online now Find More Posts by davidfee
Old Jan 16, 2002, 06:47 PM
poobs is offline
Find More Posts by poobs
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
What is toulene? is it like MEK?
poobs is offline Find More Posts by poobs
Old Jan 16, 2002, 07:40 PM
davidfee's Avatar
San Diego, CA, USA
Joined Mar 2001
Yes, toluene is like MEK (in that it's a volatile organic solvent) but it's more toxic. The EPA/OSHA etc. have put it on the endangered organic species list.
Old Jan 17, 2002, 10:32 AM
tenover is offline
Certified Slopehead
tenover's Avatar
San Diego, CA.
Joined Jan 2001
"Marine Goop" comes in a tube. There's also "Household Goop" and "Plumbers Goop", but there's a UV protectant in the Marine stuff. Toulene is the thinning agent for it, and I mix it to a "chocolate syrup" consistency then brush on one coat, let it dry overnight, then do 2 more. It does add a little more weight, but it's bullet proof. I'm using this method on my slope planes. It also goes on clear, so you can get some pretty good paint jobs underneath....I'll post some pictures tonight.
Old Jan 18, 2002, 04:14 PM
tenover is offline
Certified Slopehead
tenover's Avatar
San Diego, CA.
Joined Jan 2001
Gooped Fuselage
Here's a picture of the Gooped fuselage. I painted it first, the thinned out some Goop and did 3 coats.
Old Jan 18, 2002, 04:28 PM
poobs is offline
poobs's Avatar
oakdale, ny, usa
Joined Aug 2000
We are not talking about gooping regular foam here - right? only the type of foam use in something like an FMA Razor
Old Jan 18, 2002, 04:29 PM
Ben74 is offline
Ben74's Avatar
Joined Jun 2001
looks pretty good. not super smooth, but close enough. i wonder if something like spray foam would work. you know, the yellow stuff in an aerosol can that expands after you spray it. maybe you could spray it on, let it expand, smooth it out with a spackle knife, let it dry, then sand it smooth. i may give it a shot, just for kicks.
i've heard of people covering EPP with light spackle, but that obviously would not be very durable. the spray foam might be a bit tougher...
Old Jan 19, 2002, 09:37 AM
tenover is offline
Certified Slopehead
tenover's Avatar
San Diego, CA.
Joined Jan 2001
Poobs....Right, you mean like EPP? Well this IS EPP.
Old Jan 19, 2002, 10:05 AM
J Morgan is offline
Find More Posts by J Morgan
Now in TN!
J Morgan's Avatar
Chapel Hill, TN USA
Joined Apr 2001
Be careful on the quanities of Toluene that you buy. It is registered with the DEA as a substance used in making crack cocaine. We use it in cleaning and stimulating oil wells. We buy it in truckloads and are registered and regularly inspected by the Feds. They track even small quanities of it pretty closely.
J Morgan is offline Find More Posts by J Morgan
Best glue for epp foam: test results Brian Courtice 3D Flying 21 Jul 17, 2014 03:29 PM
Would Monocote require too much heat for EPP foam? bluesilver30 Foamies (Kits) 4 Nov 09, 2004 11:51 AM
Source for EPP foam? Slope Nut Foamies (Kits) 2 Dec 22, 2003 07:51 PM
Glue for EPP Foam rtp70 Parkflyers 8 Jul 21, 2003 05:58 AM
