Dec 30, 2004, 01:36 PM
North by Northwest
Joined Nov 2003
Hey, Guys, Thanks so much for the advice and support! I'm sure you are all right about the rudder. Flew again this morning and tried to break old habits and use the rudder as the primary turning control, with just enough aileron thrown in to keep things reasonably balanced. Works a lot better when I can do it right! Maybe more practice will see some improvement. Had to shovel about 3" of new snow off the runway before I could fly. On the second takeoff, I got sloppy and let her drift over into one of the snowbanks, just before liftoff. The prop blew so much snow in through the cowl openings that it blew the skylight window right out of the top of the cabin!
The real surprise was that when I flew it without that top window in place, (bad idea), it was nearly uncontrollable! Wanted to dive like crazy, and the more throtle I gave her, the harder she tried to dive! Finally got the power down, flaps down, and some semblence of control, and managed to make a very good landing. Now I'm waiting for the glue to dry on the window again. I was amazed that having the skylight out would have that much effect! I built fairly large nose openings, and everything is wide open back into the cabin, so there is apparently enough pressure in there, that when there is an escape route such as the missing skylight, it really affects flight attitude.
Guess I could put in a servo controlled "lift door" somewhere in the bottom of the cabin and give the lift a real boost when needed, just by opening the "door"!
Here are some spec's:
All up weight: 30 5/8 oz.
Motor: Nippy Black 1210/100 (weighs 2.13 oz.)
Battery: Polyquest Li-Po 3s, 11.1 v. nom., 2200mah, (5 1/4 oz. w/connectors, etc.)
Prop: Master Airscrew electric, 10 X 7
Amp draw @ WOT: 18.1 amps, static
Wheels: Trexler 3 1/2", (weight about 2 oz. / pair
Covering: Solite, and Coverite Microlite, (same thing)
Power and climb are great, probably somewhat more than scale for a "hot" 180 Super Cub. The climb appears kind of funny too. Rather than pointing the nose straight up when the throttle is opened, she just noses up moderately, (well really pretty steep), but not nearly as much as many models, and begins to lift and gain altitude very rapidly. Almost looks like it's climbing steeper than the direction it's pointing, if you understand what I mean.
Tony, yes, I think I will try to mix in enough down elevator to balance the flaps, it will make for much easier handling, especially on climbs at high power settings. The trick will be to get the right amount for balance.
Happy Flying!
AmpAce
