| Thread Tools |
| This thread is privately moderated by MassiveOverkill, who may elect to delete unwanted replies. |
Whoops!
Stop The Eeeevil Motor Bolts!!!!!!!!
In our effort to stop the senseless killing of inanimate objects
, we continue our series of saving more innocent victims of our precious hobby. Many motors come with multiple sets of motor mounting bolts. Most of you who've never done this before will gravitate towards the longest bolt sets because as many of us are males, we will cater to our machismo. Some will select the longest bolts simply because our mechanical experience tells us it will give a better anchor. Arm widths can vary in thickness so that's why multiple bolts are supplied to accomodate. You should ALWAYS check to make sure when your bolts are tightened all the way down they're not trying to impale the hard-working and very innocent motor coil. Here you can see a bolt that's too long installed: ![]() And the resulting damage and slaughter of the innocents: ![]() If you're lucky, and you didn't actually sever the coils like in the above photo, you can possibly still salvage the motor by making sure that the short only existed when the bolt was touching and you didn't damage the stator tooth, reapply some nail polish or shellac to the coils to re-insulate them and apologize profusely for your transgression. |
Comes down to common sense, and sadly you can't buy that.
But it also means manufacturers cannot alter what they give you - because it is not known to them what their application is, so longer/shorter bolts than provided maybe required! |
I have seen this mistake made a time, or three. Fortunately, I've always had the foresight, to check to be certain that my motor screws don't interfere with the windings. LoL
Latest blog entry: TheCrashCast.com - Episode 339
eVILE screws anyway . Color me guilty on this one . Been there and done that . Once !
As for markkona's comment above , Why would the manufacturer want to fix this design anyway . They are out to sell more motors ! Just my opinion . |
Blind holes are harder to make than through holes, and given the size of these motors, the amount of material left would either be small & weak or unnecessarily large to prevent some gorilla from just forcing the screw through it anyways, which is the kind of thing you guys would probably do anyways.
The intelligent thing to do is prior to putting your motor on, put the screw in and measure just how much it sticks up through the mount, and then refer to the motor dimension diagram. If it's too long, then grind it or use a washer (since you should be backing most of these screws against washers anyways to spread the load). |
Newark UK
Joined Jun 2004
hi
the way I decide what bolt to us is to some degree observation, I look at the motor where the bolt holes are and see how thick the metal is I then put the bolts I have through the arms and choose the ones with the same amount of thread showing as the thickness of the metal is maybe 1 mm longer, if the windings are close and there is no bolt short enough I get out the washers at least on per bolt is a good idea anyway to spread the load. Use the same principle on the prop mount if there is one finding the metal thickness may be a bit harder so put the bolt through the hole in the prop adapter and make sure there is about 2 mm of thread showing you will find that a standard bolt has about the same amount of thread on it as everyone will say don’t forget the threadlock. Kendrick |
| Category | Thread | Thread Starter | Forum | Replies | Last Post |
| For Sale | Brand New CY F260 26cc , 4 Bolt Motor w/extras | bfloyd1095 | Cars - Cars and Parts (FS/W) | 1 | May 16, 2015 11:47 AM |
| Discussion | Those who do not confront evil resent those who do. | MtnGoat | Life, The Universe, and Politics | 0 | Mar 03, 2015 10:39 AM |
| For Sale | Brand New CY F260 26cc , 4 Bolt Motor w/extras | bfloyd1095 | Cars - Trucks and Parts (FS/W) | 0 | Feb 17, 2015 01:34 PM |
| Discussion | Looking for quad motor with replaceable prop collet/bolt directly on motor housing? | Harry_RC | FPV Equipment | 0 | May 25, 2014 01:20 AM |
| Discussion | Oranator is EVIL and he must be STOPPED!!; | an85yalie | Trader Talk | 69 | Sep 01, 2007 07:11 PM |
