This thread is privately moderated by Ron van Sommeren, who may elect to delete unwanted replies.
Old Dec 27, 2004, 03:51 PM
Eljimb0 is offline
Find More Posts by Eljimb0
ni'ihau
Joined Nov 2003
tape a neo-dym magnet to the wire of your soldering pencil so it will stick to the arms of your flex light to get it out of the way if you need to use both hands for a second. Much better than laying it on the bench when you realize the holder for the pencil is covered up with meltables.
jimbo
Eljimb0 is offline Find More Posts by Eljimb0
Reply With Quote  (Disabled)
Old Dec 27, 2004, 10:00 PM
Bilbobaker is offline
Find More Posts by Bilbobaker
Bilbobaker's Avatar
United States, UT, Salina
Joined Apr 2003
Interesting tip on, "proper proping," of cd rom motors, (as well as other motors,) from Astro Bob.
http://www.rcgroups.com/forums/showp...7&postcount=30
This can really help with choosing the right winding per volt when building these cdrom motors.
I'll delete it if it doesn't belong here.
Bill
Bilbobaker is offline Find More Posts by Bilbobaker
Old Dec 29, 2004, 11:10 PM
klong66 is offline
Find More Posts by klong66
Joined Jul 2004
Bearing holder
I made this bearing holder from an aluminum archery insert for Carbon arrows. The outside diameter is 8mm. Used a 15/64 drill bit to ream out the inside. The result is a press fit for the bearings. This would probably work best using a drill press to get the proper alignment. YMMV... Cost, 0.25
Ken
klong66 is offline Find More Posts by klong66
Old Jan 20, 2005, 09:42 PM
bz1mcr is offline
Find More Posts by bz1mcr
AKA Don
United States, FL, Naples
Joined Dec 2002
CDROM Mounts
The Firewall mount sold by StrongRCMotors fits all 8 mm bearing tubes. Like those on Lens motors and even GoBrushless carbon tubes.
bz1mcr is offline Find More Posts by bz1mcr
Old Jan 21, 2005, 01:17 AM
AIR MOVER is offline
Find More Posts by AIR MOVER
Master of the Wind
AIR MOVER's Avatar
TEXAS
Joined Jun 2001
Here is a simple method for wiring up those 25mm 12pole stators ..use heat shrink.. allow to over lap the tooth .. once your done winding you can use a sharp razorblade and knock off the excess.. I like the heat shrink that leaves a hard plastic finish once your done heating up the tooth..
enjoy the pics guys and go wind a LRK or a simple ABCX4coils per phase for a real boost in power!
I used a 3stator stack of GB 25mm stators in the photos..
AIR MOVER is offline Find More Posts by AIR MOVER
Old Jan 21, 2005, 05:55 AM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
Flux rings
When using solid bar stock this may save a bit of time
olmod is offline Find More Posts by olmod
Old Jan 21, 2005, 02:58 PM
Charlye is offline
Find More Posts by Charlye
Charlye's Avatar
Maine USA
Joined Apr 2004
Stainless steel tweezers are a must for magnet placement. As you know stainless steel is non-magnetic.
Also before you attempt a tricky cascaded magnet arrangement NNSSNNSS with curved magnets for 100% coverage.. first try a NSNS configuration to see if they even fit!! Once in an while an out-of spec magnet will prevent them from fitting.
Welcome Frogger, better to post GBv questions on a gobrushless discussion thread
Charlye
Charlye is offline Find More Posts by Charlye
Old Jan 22, 2005, 08:14 AM
bz1mcr is offline
AKA Don
Joined Dec 2002
Charlye
Not all stainless steel is non magnetic. Less than half in my experience.
Attempts at 100% magnet coverage usually end up not fitting or with one space. Thats why I us 25 degree segments and use a magnet spacer to end up with even spacing all around. Also some have concluded magnets interfere with each other if too close together.
Old Jan 22, 2005, 11:05 AM
Rikidee is offline
Find More Posts by Rikidee
Muskoka
Joined Nov 2003
300 series stainless is non magnetic while 400 series IS magnetic. If it doesn't stick to a magnet....you know the rest.
Rick
Rikidee is offline Find More Posts by Rikidee
Old Jan 31, 2005, 02:21 AM
wnreynolds is offline
Find More Posts by wnreynolds
Joined Sep 2004
When winding a CCW-CW-CCW motor (eg for a 9 tooth stator and an 8 magnet can), be aware that counting turns of wire on the teeth will give you a bad wind. Depending on which side you are looking at, you will have to put on, or leave off an extra turn of wire on the middle (CW) tooth. The attached figure will hopefully clarify this.
The figure shows 3 teeth, each with one full turn of wire. Looking at the teeth from the front you count 2-1-2 winds on each tooth, looking at the teeth from the back you count 1-2-1 winds on each tooth.
wnreynolds is offline Find More Posts by wnreynolds
Old Jan 31, 2005, 06:49 AM
Gene Bond is offline
Find More Posts by Gene Bond
Crash Master
Gene Bond's Avatar
Indianapolis, IN
Joined Sep 2001
I'd call it balanced, at 1.75 turns per tooth
Really, the winds are the same, just one end turn missing on each. I wouldn't think there would be a problem, unless you are approaching saturation, in which case one end would saturate sooner... And, as the number of turns goes up, the error minimizes in percentage.
Gene Bond is offline Find More Posts by Gene Bond
Old Jan 31, 2005, 10:10 PM
KenSt is offline
Find More Posts by KenSt
Scratch builder
USA, PA, Telford
Joined Apr 2004
theaded bearing tube mounting system
I machine my bearing holders and only have about 1/2 inch or so sticking out behind my stator. There is a notched flange located about an 1/8 inch behind the stator. Behind that is the threads. 3/8-24 for 7mm od. bearings and 5/16-24 for 6mm od. bearings. The threads don't have anything to do with the bearings, that's just what fits inside of what. I use an electrical type hex nut (found on toggle switches or lamps) and re-tap them as required. (3/8-32 would work better, but I don't have that die) The flange mounts flush against a plywood firewall or tab and the nut is screwed on from the other side. A plywood key is glued into the firewall next to the hole and engages into the flange notch to prevent rotation while tightening the nut.
Wish I had a camera, then I wouldn't need a thousand words
KenSt is offline Find More Posts by KenSt
Old Feb 20, 2005, 03:26 PM
Ron van Sommeren is offline
Find More Posts by Ron van Sommeren
homo ludens modellisticus
Ron van Sommeren's Avatar
Netherlands, GE, Nijmegen
Joined Feb 2001
Winding tools:
http://www.rcgroups.com/forums/showthread.php?t=337381
Vriendelijke groeten Ron
diy outrunner discussion group
int. E fly-in & diy outrunner meet, June 26th, Nijmegen, the Netherlands
Ron van Sommeren is offline Find More Posts by Ron van Sommeren
Old Apr 14, 2005, 03:35 PM
quax is offline
Find More Posts by quax
quax's Avatar
NRW, Germany
Joined Apr 2004
I snatched a Ditto with 18 teeth and had lots of 5x5x2mm neodyms, but none with 2.5mm thickness.
Some trials with stripes of a tin can (formerly filled with beans ) to fill the missing 0.5mm were unsuccessful, because I didn't get the stripe close enough to the bell.
With this methode I had success at last.
The lower image shows the motor with some test-windings.
quax
quax is offline Find More Posts by quax
Old Apr 14, 2005, 10:34 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
The perfect packing material
Old transformer laminations are uaually made of E and I shaped pieces
the I shaped ones are grain oriented silicon iron and are perfect to line alloy bells or use as packing behind magnets, the grain is in the correct direction wich makes it ideal. cheers.
cd-rom motor conversion homepages/tricks/sources/discussions Ron van Sommeren Parkflyers 5 May 21, 2008 05:50 PM
32X CD-Rom Drives--FOR SALE kist2001 Aircraft - Electric - Airplanes (FS/W) 0 Apr 23, 2002 04:33 PM
Looking for dead CD ROM (36x or faster) Jim McPherson Aircraft - Electric - Airplanes (FS/W) 13 Apr 12, 2002 10:47 PM
Paul Matt on CD-ROM? tiggs Scale Kit/Scratch Built 2 Mar 26, 2002 08:07 PM
F/S Realflight Sim.. CD-Rom jfruge Aircraft - Electric - Airplanes (FS/W) 2 Oct 29, 2001 08:17 AM
