This thread is privately moderated by Ron van Sommeren, who may elect to delete unwanted replies.
Old Sep 29, 2004, 10:39 AM
Eljimb0 is offline
Find More Posts by Eljimb0
ni'ihau
Joined Nov 2003
how to glue magnets in pairs end to end
Squeeze the pair into a small "O" ring. Ca glue the ends together . Gently remove the "O" ring to use it on the next pair. Voila' one magnet from two.
Eljimb0 is offline Find More Posts by Eljimb0
Reply With Quote  (Disabled)
Old Sep 29, 2004, 11:08 AM
Eljimb0 is offline
ni'ihau
Joined Nov 2003
How I drill even spaced holes in the bell
Machine a "plug" to fit perfectly in hole of drill press plate (pic 2). Notch disc with evenly spaced intervals. 5,6,13?. Drill a corosponding hole in the base of your harbor freight $39. drill press. Tighten plug, disc and bell together with drive shaft diameter bolt. Hold disc still with C clamp.
Fast easy dependable.
jimbo
Old Sep 29, 2004, 06:40 PM
olmod is offline
Find More Posts by olmod
Good Better Best quest.
olmod's Avatar
Australia, VIC, Langwarrin
Joined Apr 2004
re flux rings
Some sizes in car exhaust pipes are usefull,go raid the cut off bin at your local exhaust centre,they only throw them out anyway
olmod is offline Find More Posts by olmod
Old Oct 08, 2004, 12:00 PM
bz1mcr is offline
Find More Posts by bz1mcr
AKA Don
United States, FL, Naples
Joined Dec 2002
Soldering Jig
I needed soldering jigs to solder setscrew hub on cans and to make extended cans for double stator motors. When making the second jig I realized it could be modified to do both jobs. It's easy to use and results in true running cans and the lightest double cans (8g) available. It's easy to make if you have a lathe and can be purchased from Strong RC Motors if you don't. Hubs and can extensions cut from standard cans are also available.
bz1mcr is offline Find More Posts by bz1mcr
Old Oct 08, 2004, 11:14 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
Recycle use for old speakers
This is a scource for motor builders for flux ring material,a speaker manufacturer here in melbourne imports very special magnetic iron wich machines very nicely,to make pole pieces used in his speakers,so save any old speakers the centre pole piece in particular.
Old Oct 10, 2004, 10:06 AM
Hogster is offline
Find More Posts by Hogster
HeliAP'er!
Hogster's Avatar
Surrey, UK
Joined Aug 2003
Removing enamel on wires
Having briefly skim-read this thread I see people have found quite a few methods for removing the enamel from copper wire to allow them to solder to it. Here's my method! Put some solder on the end of a hot soldering iron so it forms a big molten blob. Hold the end of the enamelled copper wire in this blob and wait for the enamel to burn off - you can tell when this happens because smoke is given off and the solder then sticks to the copper.
Job done
Hogster is offline Find More Posts by Hogster
Old Oct 12, 2004, 01:26 AM
olmod is offline
olmod's Avatar
Joined Apr 2004
Re flux rings
I just pulled apart an old magnavox 10" speaker ,the centre pole piece measures 38x23mm with a 10mm hole a nice lump of the right kind of metal thinking on about machining flux rings, what do you think about on one end of the flux ring if one turns down it to half thickness a 1.2mm length male shoulder and on the other end a female so if you want a double or a tripple ,just loctite as many as you want together ? as this is not a chat thread ,any pms' answered.
Old Oct 12, 2004, 08:41 PM
olmod is offline
olmod's Avatar
Joined Apr 2004
try again
ill get it right
Old Oct 12, 2004, 10:58 PM
cfischer505 is offline
Find More Posts by cfischer505
Albuquerque NM
Joined Jul 2002
Well here is one tip, not sure if its been posted yet, I didnt see it.... when you have to fit a GB custom Endbell into a GB custom Fluxring which almost needs a press to do this, put the endbell into the freezer for an hour and the flux ring in the oven at 200 degrees for 15 min. Use an oven mit and assemble the parts which should go together pretty easy... also when you heat the flux ring lay it on its end not side...
cfischer505 is offline Find More Posts by cfischer505
Old Oct 14, 2004, 11:25 AM
SoMoney is offline
Find More Posts by SoMoney
SoMoney's Avatar
San Diego
Joined Nov 2002
I was wondering, wouldn't angled holes offer better ventilation to the interior than this? When those motors get spinning fast every little cooling trick helps
jimbo
SoMoney is offline Find More Posts by SoMoney
Old Oct 16, 2004, 11:38 PM
Albuquerque NM
Joined Jul 2002
another cdrom tip
I found that some cdrom drives have a small belt and motor that operates the tray. Some of these small belts are just the right thickness and diameter to serve as a spacer at the bottom of a 22mm can to keep the magnets from sliping to the bottom of the can.
Old Oct 20, 2004, 05:18 PM
SMaric is offline
Find More Posts by SMaric
Poole, Dorset, UK
Joined Mar 2004
Magnet placement
48mm Inside diam Can with 10 magnets
Draw a circle, with 10 spokes (36 degrees apart) - I used a CAD package (but lots of other ways)
Cut it out, put it in the Can and mark the inside walls with a marker pen
Position the first magnet
Let the 2nd magnet attach to the first - now flip it over and slide it around to the next marker
Repeat around the can
BEFORE you glue them in place - use a small Bar magnet to check that you have got the correct NSNS....
Now glue them in place
SMaric is offline Find More Posts by SMaric
Old Oct 20, 2004, 08:12 PM
rysium is offline
Find More Posts by rysium
Why not Delta?
rysium's Avatar
Sacramento, CA
Joined Jun 2003
It has been only once when I messed up the polarity of the magnets. After I implemented simple method I have always magnets the way they ahould be.
1. Lay all the magnets side by side on the flat steel bar (I use old caliper). Make sure every mognet repeals it's both neighbors - they just don't want to stick to each other. This is 100% proof that all magnets have the same pole up.
2. Use permanent marker (or any marker that will stay for a while) and "paint" all magnets from the top.
When I install magnets in NSNSNS pattern I always set every other magnets with painted side up. It is easy, as they don't want to stick to each other. Then I tack glue them in place so they don't move. Then I install remaining magnets this time painted side down. I use a toothpick to position them in place.
Easy, and you don't need a lathe to do that.
RysiuM
rysium is offline Find More Posts by rysium
Old Oct 20, 2004, 11:17 PM
Uttam1 is offline
Find More Posts by Uttam1
Micro Brushless crazy
Uttam1's Avatar
India, Bangalore
Joined Jul 2002
For magnet placement, just place the magnets so that the "sides" of the magnets ( The thickness ) attract each other. If they repel each other, you've got it wrong, flip the magnet and it should get fixed.
Uttam1 is offline Find More Posts by Uttam1
Old Oct 21, 2004, 02:49 AM
SMaric is offline
Poole, Dorset, UK
Joined Mar 2004
Fitting for a 3mm shaft
My Floppy disc motor had a 4mm shaft
Rather than trying to make a shaft coupler
(only found a Meccano 3mm - 4mm coupler & that was 20mm long with a 10mm OD)
I have found that you an get some plastic tube/pipe connectors (for Homebrew/chemistry piping)
In the UK they're sold as 'PolyPipe' connectors
You need to run a 3mm drill through them - but that's easily done - then they are a good snug fit (tapered) into the 4mm hole in the Can
cd-rom motor conversion homepages/tricks/sources/discussions Ron van Sommeren Parkflyers 5 May 21, 2008 05:50 PM
32X CD-Rom Drives--FOR SALE kist2001 Aircraft - Electric - Airplanes (FS/W) 0 Apr 23, 2002 04:33 PM
Looking for dead CD ROM (36x or faster) Jim McPherson Aircraft - Electric - Airplanes (FS/W) 13 Apr 12, 2002 10:47 PM
Paul Matt on CD-ROM? tiggs Scale Kit/Scratch Built 2 Mar 26, 2002 08:07 PM
F/S Realflight Sim.. CD-Rom jfruge Aircraft - Electric - Airplanes (FS/W) 2 Oct 29, 2001 08:17 AM
