Go Back   RC Groups > Aircraft - Electric - General > Electric Motor Design and Construction
This thread is privately moderated by Ron van Sommeren, who may elect to delete unwanted replies.
Old Jul 22, 2004, 08:03 PM   #46
MorrisM's Avatar
If you are getting along in years like me, and your eyes aren't what they used to be, these magnifying goggles are a big help. I can't do a neat wind without them. Local Harbor Freight had these on sale less than $3.00.
Morris
  • Name: Magnifier.JPG
MorrisM is offline Find More Posts by MorrisM   Reply With Quote
Old Aug 09, 2004, 10:53 PM   #47
I originally posted this in another thread and someone suggested that it should also be posted here.
When mounting 5x4x2 magnets on the new GB custom flux ring I have found that they can be equally spaced around ring by cutting short pieces of 3/32 inch OD brass tubing and placing a piece between each magnet. It's a good tight fit and holds well. I don't leave the tube pieces in there permanently, just until the magnets are glued in.
Bill
Kinda Wild Bill is offline Find More Posts by Kinda Wild Bill   Reply With Quote
Old Aug 17, 2004, 05:21 PM   #48
Sussex, UK
RobinBennett's Avatar
Stainless steel isn't magnetic; so any pins, needles or tweezers made from it are great for pushing magnets around - much stronger than wooden toothpicks.
RobinBennett is offline Find More Posts by RobinBennett   Reply With Quote
Old Aug 17, 2004, 05:32 PM   #49
40%, 5% whats the diff?
TeamSME's Avatar
Send a message via AIM to TeamSME
One tip I have is to place the magnets on the bell then glue then when you satisfied with the gap.
My first motor
17turns newb wire
Star/WYE
N45's
Go Brushless Kit
hey its my 700th post 300 to go!
Sean
TeamSME is offline Find More Posts by TeamSME   Reply With Quote
Old Aug 17, 2004, 07:35 PM   #50
A simple test rig
The prop is mounted inverted, "pushing" down on the scales.
  • Name: DSCN0629 (resized).jpg
Amos is offline Find More Posts by Amos   Reply With Quote
Old Aug 20, 2004, 01:52 AM   #51
vox
Yet another winding tip.....
If you simply wind by hand and have trouble gripping the wire, I've had good results with using a latex rubber glove for the winding hand. It grips the wire extremely well and makes the job a lot easier.
A wittled down chop stick can help squish windings between stator winds to make extra room for more windings.
vox is offline Find More Posts by vox   Reply With Quote
Old Aug 25, 2004, 10:50 AM   #52
AKA Don
bz1mcr's Avatar
Magnet Spacers
The first photo shows the spacer in a can. It's fast, easy and precise.
EDIT 10/10/04 Production spacers now available! from Strong RC Motors
  • Name: Spacer in can sm jpg.JPG
  • Name: Spacer w can sm jpg.JPG
bz1mcr is offline Find More Posts by bz1mcr   Reply With Quote
Old Aug 25, 2004, 03:20 PM   #53
Stator plates alignment
If you still have a match you can use it for 25 mm plates alignment
The stators slots are aligned with groove in the bearing tube. A simple
pin locks them.
The matches are used to align the stator plates when gluing the hub to
the bearing tube.
  • Name: 5PSTATOR.jpg
  • Name: 5stat+bell.jpg
Old Aug 31, 2004, 06:07 AM   #54
Good Better Best quest.
olmod's Avatar
wind data
Interesting winding data for 20mm stators.
http://www.eflypower.com/modules/new...c_id=9&forum=4
olmod is offline Find More Posts by olmod   Reply With Quote
Old Aug 31, 2004, 03:35 PM   #55
Why not Delta?
rysium's Avatar
Originally Posted by Ron van Sommeren
Airgap, magnetwidth and -thickness, #magnets, stator- and rotor-diameter calculation:
Or this one, if you want it off-line using Excel. This one has all three GBL stators predefined, you can change all blue fields (number of magnets, thinckness, width, center airgap and bell thickness), and spreadsheet will calculate the rest.
RysiuM
  • Name: brushless motor calculation.JPG
rysium is offline Find More Posts by rysium   Reply With Quote
Old Sep 01, 2004, 10:16 AM   #56
Unicorn
Jay C's Avatar
Ok, I've used Richards Spreadsheet and added the spece between magnets and space for magnets calculations. I also fixed a bug and now it draws the number of magnets correctly (would only do a max of 12 before). Not sure why you would need or want space for magnets but there it is anyways
Calculator
I'll work on letting you specify multiple mags per pole.
Jay
  • Name: gb_calc_ex.jpg
Jay C is offline Find More Posts by Jay C   Reply With Quote
Old Sep 01, 2004, 11:42 AM   #57
Gord
flypaper 2's Avatar
One of the limits on how many amps you can draw is limited by how hot the coils get, so I used the three holes in the bell as a cooling fan. Before i glued the magnets in I drilled the holes out to 1/8 in. Put a small punch or drill shank in the hole and bend it in the direction of prop rotation to act like an airscoop. Grind the inside where it sticks out on the inside so it won't touch the coils or flatten the inside with a punch. Havn't tried with a temp gauge, to tell the difference but will do and let you know.
flypaper 2 is offline Find More Posts by flypaper 2   Reply With Quote
Old Sep 02, 2004, 07:15 AM   #58
homo ludens modellisticus
Ron van Sommeren's Avatar
You can try and use a battery or condensatorbank to 'blow away' a short between a winding and a statort. Connect one lead to the stator and another to the shorted coil for a very short time but be careful! See
http://www.powerditto.de/
-> tools
-> praktische Bautips
-> picture 5
Use http://babelfish.altavista.com for automatic online translation.
Ron van Sommeren is offline Find More Posts by Ron van Sommeren   Reply With Quote
Old Sep 02, 2004, 08:26 AM   #59
Removing insulation lacquer/resin can be tricky, especially when using thin or litze/multistrand wire. Just heat the end of the wire with a soldering iron on an aspirine tablet (acetylsalicylic acid). Nasty fumes you may have to take an aspirine yourself
Old Sep 02, 2004, 08:41 AM   #60
Why not Delta?
rysium's Avatar
I tried it with the tablets I had here. It didn't work because it looks like 90% of the tablet's mass is some kind of sweet filler (sugar ). Anyway, heated made a sweet fumes like burning sugar mixed with terrible odor (acetylsalicylic acid ). I had a big bubling goo on whe wire that didn't even touch the insulation.
I guess, I need to buy a Bayer
RysiuM
cd-rom motor conversion homepages/tricks/sources/discussions Ron van Sommeren Parkflyers 5 May 21, 2008 06:50 PM
32X CD-Rom Drives--FOR SALE kist2001 Aircraft - Electric - Airplanes (FS/W) 0 Apr 23, 2002 05:33 PM
Looking for dead CD ROM (36x or faster) Jim McPherson Aircraft - Electric - Airplanes (FS/W) 13 Apr 12, 2002 11:47 PM
Paul Matt on CD-ROM? tiggs Scale Electric Planes 2 Mar 26, 2002 09:07 PM
F/S Realflight Sim.. CD-Rom jfruge Aircraft - Electric - Airplanes (FS/W) 2 Oct 29, 2001 09:17 AM
Bored? Want to fight?
Join the RCGroups clan!
